Question about Belkin F5D8631-4 Router (F5D8631au4A)
Power light blinks three times then is completely blank for a few seconds then blinks three times and so on in a loop. Will not boot up and no other lights come on.
  • Paul Lyman
    Paul Lyman Oct 08, 2010
    Are you referring to your PC or your router?
Sorry I should have been clearer, the PC if fine and up until last night the Router was fine but tried to boot up the Router this morning and the above problem is happening on the router. Tried a reset but still get the problem
Posted on Oct 08, 2010
  • Advent85
    Advent85 Oct 22, 2010
    Hi All, In the end I had to send this back to Belkin who are replacing it under the lifetime warrenty.
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
Jan 03, 2017 | Hisense Televison & Video
ACER EXTENSA 5420 BIOS Alteration Problem
restar the computer HOLD the key CTRL +F2 and ready.
God bless you
May 22, 2013 | Computers & Internet
Asus p5lp-le no display
If it seems like the computer completed the boot process but the screen is blank, try the steps below.
The problem will either be the monitor or the video card inside the computer. Connect another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays and works ok, then your original monitor is bad and the video card is good. If the Borrowed monitor does not work then the video card inside the computer is bad.
If the computer did not complete the boot process then try the steps below.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 05, 2012 | ASUS Computers & Internet
HP Compaq 6735s Laptop screen was blank when turned on
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Mar 26, 2012 | Computers & Internet
Toshiba a210: Powers up on both battery and power source. When powered on the caps lock blinks green most of the time but not always. Display does not come on at all, no blinking, flickering, or...
Just out of curiosity, you haven't got a usb device plugged in as you are booting the laptop have you?
If not, try this:
Remove battery, unplug power, hold power button for 60 seconds, turn on computer with power plug only, then shutdown, add battery and restart
If that fails to work, check that the charger indicator light is not flickering, this indicates that the power is not completing the circuit (damaged power capacitors/ fault on motherboard.
Are you using a genuine Toshiba charger, these laptops are prone to breaking down if an aftermarket one is used, a non-genuine one can damage the motherboard as well.
How many blinks does the caps lock make? Flashing caps lock is usually a sign that the Ram may be failing. You can try replacing the Ram modules to see if it boots, also, a dying hard drive will prevent booting, remove and see if that allows the laptop to power up
After that, I'd suspect the motherboard is damaged and will need replacing
Jun 15, 2011 | Computers & Internet
Push power button and lold it in green light blinks one time and then nine times fast and then cuts off light try a few seconds later and green light comes on for a few seconds and off it does this three...
Hi:
You are in HV shutdown mode, Have the Horizontal output transistor replaced as well as the Horizontal output transformer. These are the most common failure for this problem, The three blinks indicates Delfection problem, and these parts are part of the main High Voltage Deflection circuits.
Dec 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The set does not come on. The red power indicator blinks on and off for a few seconds, stops for a second or two, then blinks again for a few seconds, stops again, etc...
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Jul 10, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Laptop will not boot
ok, take the battery out and leave it unplugged for a few hours.  Only plug the ac adapter in after.  Press and hold the power button for 10 seconds.  Does it still do it?  If it does work, then chances are your mobo has bit the dust or you have knocked loose an internal charging part.
Mar 09, 2009 | Compaq Evo N410C Notebook
Open Questions:
Belkin F5D8631-4 Router (F5D8631au4A) Logo
63 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
