Lg hd hd lst 54039 I have sink problems with sound & pickture to a Pioneer pop. have tied anouther hd tuner and have no problems, can you advise!
  • 1 more comment
  • denmul Oct 08, 2010
    tryed that no good
    Works but same problem, tried it on 4 different flat screens
  • denmul Oct 09, 2010
    Picture is fine sound is delayed . I have tried another brand of HD setbox on pioneer (ok)!
    Tried lg box on latest samsung 3D plasma (same result as pioneer) tried lg on panasonic plasma
  • 4,889 Answers
Sink problems? Never heard of that. Can you please elaborate?
Posted on Oct 09, 2010
    President:
  • 2,777 Answers
Please explain a little further, what do you mean you have "sync" problems to a Pioneer "pop"? Please explain a little more and I can definitely help.
Thanks
Tim
  • 11,800 Answers
Simple test - connect the lg to another tv. If it behaves the same then it's defective, if not then the cable used to connect it is bad, replace it.
Posted on Oct 08, 2010
  • 1 more comment
  • Azrael SRL Oct 08, 2010
    So when you plug the LG in another tv it doesn't work? Then yes, the LG is defective. Unfortunately no parts are available for it on the market, you will have to take it to a dealer, they are the only ones that can fix it.
  • Azrael SRL Oct 09, 2010
    If the LG works in another tv, just not in that Pioneer, then it outputs a signal in a resolution that the tv can't support. In that case plug it in another tv and reduce the output resolution until the tv works - most likely the Pioneer is an old one that accepts only SD signal, not HD.
    This is a hardware fault in the LG - the processor inside it can't process the sound fast enough. The only thing you can do is to find and install a new firmware. If you can't do that then return it to a dealer, it's defective and should be replaced.
How comes that my LG TV 32" model 32LC20 has problems sound and pickture with ABC channels all other Channels are OK ?
If the audio is distorted to certain channels only, it is due to improper AGC adjustment. Weak signals won't processed well. You have to enter the service mode to the set, and have to adjust this value. This is somewhat skilled work, that a user can't do. It will be best to contact any service technician, in this case. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 20, 2014 | Televison & Video
I have a Chimei 19 " monitor. I have connected it to an LG LST-4100P HD digital tuner via the VGA connections. When I power the tuner on, all I get is a message on the monitor that indicates *OUT OF...
You need to read your HD digital tuner and see if you can lower the video resolution to the maximum the monitor can handle, right now it is too high for the monitor to display. If the resolution is OK then the problem is in the monitor logic board.
Please post back and leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jan 30, 2011 | Microsoft ChiMei CMV938D 19" Widescreen...
Lg 37lc7d with no picture or sound but green light comes on . popping noise preceeded problem. no obvious blown capacitors
Ur tuner board is dead.Replaced this board to get picture back.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 10, 2010 | LG 37LC7D 37 in. LCD HDTV
Pickture is shown 2 sekunds, then it go black. power on LG RD-JT30 and see a pickture thru RGB-signal and after 2 sek the pickture go black
if the lamp is still on and no picture transmits, reset the settings to factory default. the resolution doesn't match or the signal is lost. if the lamp goes out, you may need to replace the lamp. check the lamp for bulges, black spots or fogging. if the lamp is ok, check the colorwheel. if you hear squealing or chirping and it stops when the lamp goes out, replace the colorwheel. if that is ok, replace the ballast.
Dec 03, 2009 | LG RD-JT30 Multimedia Projector
RCA ports on back of a Pioneer cd player
Well you should have two sets, front and rear. Either of those sets can be used to go to the amp and it should work fine bridged. If your problem still exists then either you are getting a bad signal form the RCA outputs on the deck or have anouther problem somewhere in the system like in the amp or amp connections. What exactly does the amp do?
Mar 02, 2009 | Pioneer Car Audio & Video
Bought a used lg ru52sz51d
It sounds to me as though your old HDTV has a HD tuner built in. Not all HDTVs do and unfortunately your LG does not (I looked it up).
If you want to get free over the air HD you will need to buy a HD digital tuner box and an HD antenna.
Jan 07, 2009 | LG RU-52SZ61D 52" TV
Pioneer DEH P6000 screen reads "tuner er"
try disconecting your battery while its on then reconnect
Jan 01, 2009 | Pioneer DEH-P7000BT Car CD/ MP3 Player
Popping and fading of sound
The "popping" sound could be electricity jumping from one place to another.An internal SHORT in a transistor, an internal OPEN in a resistor.Intermittent [sometimes it does,sometimes it dose not] arcing electronic parts.
Dust [metal filings,very fine hair that burns like a fuse] & dirt [anything metal], arcing (shorted) capacitors.Bad connections on ANY ground connector.
Possible:: your surround sound MASKED the popping sounds by acting like a FILTER.Which lets me to think that your problem is in the audio section.
Jun 24, 2008 | Samsung DLP HL-P5663W 56" TV
LG HD Digital Video Recorder LST 5402P has stopped displaying menu onscreen
first i assume you are trying to watch the unit through AV. If this is the case, turn on unit, press "Display Format" on the front of the unit, keep press it till you have "YPBPR" displaying, press select on front panel, next press "Display Format" again till you come to 576i, press select. Now press menu and it should display. If this problem occurs with HDMI, simply change the display settings to HDMI, and 1080i. Hope it helps, Murder-face.
Jan 13, 2008 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
