Question about Cameras
My son is in the middle of Australia and dropped his Canon powershot sx130 camera. How do you reset it? He has no computer access.
    Brigadier General:
  • 3,006 Answers
You haven't said what the fault is with his camera, but it's most likely that his camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the speedy and free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 08, 2010
The lens is stuck when trying to start the camera -
In many cameras the lens is moved through a tiny right-angle gear having a counterhold that is fixed with a tiny screw. That screw can loosen and fall out - and the lens is then stuck.
When the lens is stuck find a place with absolute silence and gently shake the camera close to an ear. Maybe you can hear a faint noise from the loose screw and maybe not - the screw is very tiny.
Now decide whether you will do it yourself or not. Any warranty is lost if you open the camera yourself. I have successfully done the below repair on a Casio EX-S10 - a camera in the size of a business card.
Make sure you have the right tools - mostly tiny screwdrivers that fit the screws in the camera and a pair of tweezers. Use a clean surface for the opening of the camera - could be a large sheet of white paper. Gently open the front of the camera and locate the right-angle gear. If that gear is in good order - no loose counterhold - try to find the tiny object that blocks the lens and remove it. Be very gentle and very carefull.
If the counterhold is loose find the tiny screw and clean it then using a needle fill the threads of the screw with a tiny drop of "Locktite" or a similar type of glue. "Open" the gear and move the lens to its resting position. Then close the gear and fasten the counterhold correctly and reassemble the camera. Try to start the camera again and if it works let it - if possible - rest an hour or two before you use it again to let the glue harden. If it still doesnt work consider changing the battries.
Good luck.
SLYS
Posted on Jun 26, 2011
Tip
Canon PowerShot SX130 IS
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.usa.canon.com/cusa/consumer/products/cameras/digital_cameras/powershot_sx130_is#BrochuresAndManuals">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
on Dec 07, 2010 | Canon PowerShot SX130 IS Digital Camera
How to transfer photos from my canon sx130 to computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Apr 02, 2014 | Canon PowerShot SX130 IS Digital Camera
How to reset sx130
Remove the battery for 15mins, replace the battery and go to the camera's menu and set the Date & Time.
Sep 30, 2012 | Canon PowerShot SX130 IS Digital Camera
Software for transferring photos from canon powershot sx130
You don't need any software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as Picasa.
Mar 19, 2012 | Canon PowerShot SX130 IS Digital Camera
I bought a Cannon powershot SX130IS and didnt get a users manual. I shouldnt have to buy one. can you help......
Google it. Type in Canon PowerShot SX130 IS Digital Camera manual.
You will get a list of sites but the Canon site will most likely have your manual although you may need to follow a few prompts to get to that level.
Jul 10, 2011 | Canon PowerShot SX130 IS Digital Camera
Lost my manual! Want to buy another. don't buy internet. Will pay
Hello Heknpat,
Please download the Canon PowerShot SX130 IS Digital Camera from the link below :
http://support-in.canon-asia.com/P/search?model=PowerShot+SX130+IS&filter=0&menu=manual
After opening this link please visit the second option PowerShot SX130 IS Camera User Guide.
Choose the option I have read and understood the information above, and wish to download the designated software. The the manual is available for downloading.
Jul 04, 2011 | Canon PowerShot SX130 IS Digital Camera
I am in need of a instuction book for my canon powershot SX130 digital camera.. Thank you! Patricia Leger Email: mariopatty1@hotmail.com
Welcome to Fixya.
You can view/download the instruction manual through the link below :
Canon Powershot Manual
Just scroll down under "Brochures and Manual", pick the language of your choice and you're good to go.
Thanks for using Fixya.
Jun 26, 2011 | Canon PowerShot SX130 IS Digital Camera
How do i reset my canon powershot sx130 IS camera?
the menu's last tab has a last but one option where you can take all your settings to default. use it to reset your camera.
Dec 28, 2010 | Canon PowerShot SX130 IS Digital Camera
Cameras Logo
198 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
