Question about Nokia 5310 Cellular Phone
My Mobile God Hang.Keypad Not Working - Nokia 5310 Cellular Phone
    President:
  • 1,118 Answers
My Dear Your Phone Keypad IC Fault SO Please change Keypad IC
And Key pad Problem will Solved
Posted on Oct 08, 2010
Everytime i open my cherry mobile D11 phone, it always hanging and then automatically shutdown. what is the solution for this?
it is possible that you are in need of a new phone battery. if not properly cared for, smartphone batteries die out rather quickly due to the overwhelming work that its producing to keep up with all of the programs that you are feeding into your phone constantly. it may help for you to take the battery out of your phone for a little while to give it a rest then place it back in your phone and reboot it. that may buy you a small window until you are able to buy another battery. I hope this helps.. god bless..
Oct 22, 2013 | Cell Phones
The key pad on my Motorola V3s RAZAR doesn't work the only button that works is the power button. All the other buttons don't work, how can i fix it myself.
If you're going to do it alone,follow this steps.
1. try to check if the volume up or down is working,if not, remove the battery cover and dismantle the lower panel at the back using a T6 precision screw,unscrew 2 screws and by using your thumbnail look for edge cover,insert and lift it up gentle (remember that a flex connector is attach on the right side If done,check the volume switch and remove the circular metal (keypad membrane) that is volume high and low apparently.clean it and align it when returning back before assembling it(might some shortage or hang buttons that's why keys are not working).,also try to check if the flex connector or socket is clean as well as the board socket connector cause keypad function has the line with it.assemble it and try if its working.
2. If the method above fails,need to replace the keypad flex cable.it maybe to risky for you to do cause the keypad connector is connected at the upper flip panel.i maybe reliable if you continue and there's a chance to break the lcd cause upper portion is to hard to dismantle.better bring it a mobile service center for keypad flex replacement.
hope this simple solution helps.
Jun 19, 2011 | Motorola Mobility RAZR V3
Buttons(keypad) are not working?
I thinh its keypad ic is damaged or may be you have flash it by some mobile expert in case of hang fault
May 22, 2010 | O2 Xda Atom Exec Smartphone
My nokia 3110c mobile hanging when i satrt the mobile
Check the keypad for stuck, Or reinstall software with Nokia software Updater
Jun 09, 2009 | Nokia 3110 Cellular Phone
HASH KEY ON NOKIA E50 WORKING AS CANCEL KEY
I removed some intalled appliacations from file manager and the problem was solved !
Jan 11, 2009 | Nokia E50
Hang up button not working
you will need to take the phone to a mobile repair center and have the keyboard replaced or service
Dec 21, 2008 | Sony Ericsson K850i Mobile Phone
Keypad doesn't work
good morning ! the problem of your 6233 nokia is keypad main brain or keypad crystal ic ,,,,try to clean the keypad mainbrain or replace the keypad ic ! thanks ! good luck ! ......
Sep 07, 2008 | Nokia 6233 Cellular Phone
Reformat
you need to have the firmware on the phone reflash to have it working again.
Jun 30, 2008 | Motorola Mobility RAZR V3
Comdial 7260-00
This will fix your issue
Do this:
Feature # *
Hit # (8) times
Hit show
Enter 04-05-101~156 (101~156 is whatever extension number you are trying to change)
Press chg
Use the keypad to change the name pressing # after each letter
When you are done entering the name make sure you press # after the last letter or it won't show
pick up and hang up the handset
DONE
Apr 04, 2008 | Comdial 8324S-PT Corded Phone
Nokia 5310 Cellular Phone Logo
81 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
