Hi, My SAHARA laptop get heated when it's being charged and also it's battery charge is losing in 30 minutes.what should i do to resolve this problem?
  • 97 Answers
Basically Sahara Laptop heats more. As battery charge concerned it is depends upon your battery life check weather your Laptop is under warranty if it is their mince you will get the battery replacement.If it is not their mince you need to go for new battery.
Posted on Oct 08, 2010
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
Hp pavillion zv6233nr
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged state for long periods.
May 05, 2013 | HP Pavilion Computers & Internet
Batter wont stay charge
Most laptop batteries have a life expectancy of two years or 400 to 450 charge and discharge cycles. After this time, the battery may lose the ability to charge or to hold a charge for substantial periods of time. When this happens, it's likely the battery needs replacement. However, troubleshooting can narrow the problem and ensure you are not wasting money on a battery replacement.
Check Power Adapter Turn the laptop off. Remove any power cords or power sources. Separate the battery from the bottom of the laptop. Slide or press the locking mechanism to unlock the battery. Slide the battery out of the battery compartment. Plug the power adapter into an electrical outlet. Insert the opposite end of the adapter into the charging outlet on the side of a laptop. Power on the laptop. If the laptop does not turn on, the power adapter is not correctly working. If the power adapter is not working, the battery can not charge. Replace the power adapter. If the laptop powers on, the power adapter is properly working. Clean Battery Contacts Turn the computer off. Remove any power cords or sources. Take the battery out of the battery compartment. Dip a cotton swab in isopropyl alcohol. Rub the dampened swab on the battery compartment and battery contacts. Dust and buildup can prevent battery contacts from properly charging. Slide the battery back into the battery compartment. b> Charge and Test Battery Plug the power adapter into the laptop. Charge the battery for six hours. Remove the power adapter. Turn the laptop on. If the laptop turns on and stays on for at least 30 minutes, the battery is holding a charge. If the laptop doesn't turn on or the battery doesn't power the laptop for at least 30 minutes, the battery should be replaced.
Battery Won't Charge Or Short Power Life In Notebook
http://www.daileyint.com/hmdpc/battery.htm
Laptop Battery Depot http://www.laptopbatterydepot.com/problems.asp - clean
Feb 24, 2013 | Computers & Internet
HP Pavilion dv5 overheat
Your computer needs complete service, you may contact your nearest authorized service center for solution.
Apr 15, 2012 | HP Pavilion Computers & Internet
My laptop won't turn on, even I try to plug the charger it won't charge. and the light indicator if it's charging is not on. The problem start when I using it while charging and it's...
Remove the battery and check the voltage on the battery, if low try to JUMP charge, if not replace. Also check the charging voltage with the adaptor connected to the latptop. If there is no voltage then the charger must be checked.
However if the battery and adapter seems good then the mother board is a suspect and it is ideal to get the help of Tosibha service for estimation.
Jun 25, 2011 | Toshiba Satellite L500 Series Notebook
Hi my laptop presario v3500 turn off after 10-30 minutes...my laptop battery is dead...i using power a/c only...what wrong with my laptop..i saw this model always have same problem...thnx u
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Mar 20, 2011 | Compaq Presario V3500 Series Laptop...
Hi i have a sony dcr-pc3 my wife bought it in 2000 and it never holds a charge the longest we get is about 10 minutes we bought a new battery and have just bought a new charger same old...
Well if you have bought the right battery and the proper charger this sounds very odd, did the amp hr and every say the same details on the battery & charger as the old one? when you charge the camera how long was it till you used the camera? as Sony cameras lose around 30% charge per week, I know because I have a Sony still camera and movie, both lose charge, my still camera goes flat in 3 weeks after a full charge with no use at all, so they are never good bits of equipment with batterys.
Jun 20, 2010 | Sony Handycam DCR-PC3 Mini DV Digital...
Casio Exelim EX-Z77 battery will not charge, charger light flashes on and off.
Your battery maybe drained, you can try to leave it in charger for hours( it will take long for a drained batt to start charging) blinking led may indicate that charger is trying to supply current to batt, anyways I strongly suggest you to buy a new one
Apr 14, 2010 | Casio Exilim EX-Z77 Digital Camera
Battery meter is low, even though computer is always plugged in
Hi, I recommend you to try refreshing your battery by doing this step for 3 -5 times 1.Make a fully charge it take around 10 Hours. 2.Unplug your adapter and use the battery until it fully finish.Off by itself. 3.Repeat step1-2 for 3-5 times and see it again
Oct 07, 2009 | Acer Aspire 6920 Notebook PC
Acer 3680 will not charge while powered on
The batteries are a lithium ion and tend to lose charging abilities. Youll need to replace the battery
Jan 22, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
David Payne
David Payne
