Question about Dell Inspiron 8500 Notebook
Inspiron 8500 - Display issue
My Inspiron 8500 boots up sometimes and comes up into XP, but then the display (LCD) has flickering lines but you can still see the screen and after a minute of this the machines locks up and the screen goes black. After, that I try to turn off and then on and I get vertical lines sometimes in color and sometimes in white. I try connecting an external monitor and nothing. I can never get the display to work.
Could this be a mother board or a video card?
Any ideas?? Your help is really appreciated!!
Thanks,
Rey
  • reinaldom May 29, 2008
    Thanks... I try the fn-F8 and toggle, but nothing....
    Where are the ground screws you are talking about?
    Found a problem: The FAN is not turning...
    Genius:
  • 1,027 Answers
With the external monitor attached press <FN><F8> to toggle between internal and external display. if still nothing then it sounds like the video card.
MANUAL
Check all the connections (especially the ground screws) that was a problem with one I worked on last year.
Posted on May 29, 2008
  • Mark Williams
    Mark Williams May 30, 2008
    The laptop I worked on was given to a friend of mine, he had it for 3 months not being able to power it up. I bought a new power supply "brick"...nothing, I disassembled via the link I sent you for MANUAL and was able to get it to boot after removing and replacing the CPU. but still no LCD display. I found the board was not seated all the way in place then when i tried again still no display. While everything was powered up I put a jewlers screwdriver down one of the screw holes and when i touched it to the video card it lit the display. I then replaced all the screws holding the video card in place as the old screws were covered with locktite and not getting a good ground.
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
My laptop emachine g720 screen flickering
Windows XP:
Windows Vista:
Windows 7:
I hope you find it very helpful. Thank you for using fixya.com
Aug 19, 2011 | Computers & Internet
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
I have a dell inspiron 15 when I turn it on the dell symbol and insprion page comes up then goes to a black screen. When I press F8 I get black screen with white bars at the top and bottom and a white bar...
You are having a display problem with the LCD, so kindly have it checked from dell and get the LCD display replaced from them if your laptop is under warranty
Nov 18, 2009 | Dell Inspiron 8500 Notebook
Inspiron 8500 99% dead
your laotop problem most from display unit (ATI MOBILITY RADEON 9000), you need consider
1) first you need to make sure the EXT VGA diaplsy is ok or not, if both display are same problem, please do next
2) if the display card is separat to motherboard you need check the card connection with the motherboard, there is pair plug/socket
clean it and set back. still bad, need to change one
3) if the display card is on board chips you cant change it, you have to find a special technician to do BGA repair
4) if EXT VGA display normal you need check LCD cable connection and LCD panel, this step please keep in touch me
hope help you to deal well
May 14, 2009 | Dell Inspiron 8500 Notebook
Flickering screen on startup
Sounds like hardware. Several possibilities come immediately to mind:
1) Backlight is going bad. (It's a fluorescent light).
2) Bad inverter
3) Loose or bad cable in laptop hinge
If the picture is OK using an external monitor, it's probably one of those three.
I've used these guys before for screen repair: Unknown document title.
http://www.notebookmechanix.com/
Feb 06, 2009 | Acer Aspire 3003LCi Notebook
Dual boot
There's probably a problem with your display drivers in XP.
Try booting in Safe Mode (F8 on startup). Now your display should work.
If you boot in safe mode with networking, you can visit the graphics-card manufacturer's website and download the latest drivers. After installing these, try rebooting normally...
Dec 11, 2008 | Dell Inspiron B130 Notebook
Dell inspiron 8500
could you possibly take a picture of the laptop screen?
Apr 03, 2008 | Dell Inspiron 8500 Notebook
Laptop display goes black and then rebuilds each window
this is problem with operating system or with the RAM,Try re-installing Operating system..If still Happens Change the RAM
Apr 01, 2008 | Dell Inspiron 8500 Notebook
Computer Boots but There is No Display
Make Sure wires of moniter is properly plug in , check specially VGA cable  and it can be because of RAM .
Gizmo1
Oct 14, 2007 | Dell INSPIRON 6000 CENTRINO...
Open Questions:
Dell Inspiron 8500 Notebook Logo
356 people viewed this question
Alun Cox
