Question about Vehicle Parts & Accessories
My rmote control will not work on garage doorbut it will open with switch also remote will not work in garage but will work on the street can you help
    Sergeant:
  • 347 Answers
Make sure that the garage door opener receiver (generally attached to the motor) is securely mounted and not loose as this can cause internittant operation. Also make sure that if there is an anternna wire from the receiver that its fully stretched out and pointing to the floor. Last thing is the remote's batteries - could be some corrosion or they simply just need replacing.
Posted on Jun 02, 2011
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
The frequency of the garage door opener is the same as the one down the street. Is there a way to change frequency on the Lift-Master Professtional Line Garage Door opener?
This appears to be your problem.Your door sometimes is opening unexpectedly and inadvertently when a seen or unseen neighbor uses his or herremote door opener; or a neighbor wonders why his/her own door always seems to open shortly after you drive by; and you wonder if her and your remotes should not be transmitting each at its own unique frequency level. Or in the worst case, someone, possibly a prankster, possibly someone more nefarious, is driving through neighborhoods punching a remote to see if any garages respond (and if any indoor occupants respond).
Its transmission radio frequency is not what sets one garage door remote apart from any other. Instead, each door remote controller transmits in rf adigital codeinto the air near your house, and any door opener power head set to the same code recognizes the code and is commanded to energize its power head motor to raise or lower the attached door in reverse of its last most previous transport direction. The chance, probabilistically speaking, of any two near-neighboring houses' garage doors (or even a random, travelling remote) being set at the exact same code among the large number of available alternative codes is quite remote, but it can sometimes happen.
The solution is for the house owner--that is you-to change the reception code in your door opener power head unit by repositioning small selector contact switches in a code pad situated on the power head, typically behind a plate or cover of some kind--or you might have to remove the power head cover. Once found, it is fairly easy to do by setting the numbered or lettered switches to form a multi-digit code, much like a digital padlock combination except in binary or some base other than decimal. Next, record the new code, and change the code by the same means and method on all associated remote control instruments. It is not a bad idea to change garage door remote access code from time to time simply as a matter of routine garage door and door opener maintenance. Check for code switch location and setting procedure for you power head in user manual or on line. That should be the end of the problem and also discourage anyone casing your neighborhood for potential unlawful entry vulnerability.
Feb 18, 2015 | Building Materials
Why wont my 3 remotes (hand held factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain driven garage d
SOUNDS LIKE SOMEONE MAY HAVE PRESSED THE LOCK / VACATIONS SWITCH ON YOUR WALL CONTROL. IF STILL NOT WORKING AND THE LED IN THE WALL SWITCH IS NOT FLASHING TRY AGAIN TO PROGRAM YOUR REMOTES.
GOOD LUCK
STEVE
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
I have a Merlin Powerlift model 430R roller door. The battery went flat in the remote and I replaced it. Now the door will not work via the remote.Works ok from red button on unit. I have tried to reset...
If the LED is flashing rapidly when the button on the remote is not pressed you have interference from something. Check for old remotes stored in a drawer somewhere or some new electric item nearby. Start unplugging things until that rapid flashing stops.
Apr 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
I live in a 4-unit condo building constructed in 2008. Recently, after I trained/programed a garage door opener incorporated in a new car I purchased, I discovered that my garage door started to be...
I would recommend this. I'm not sure this will work, but I think it will.
Try starting from scratch. Reprogram the unit to the car again, I think the codes change each time it is done. If not, it's not too difficult to try.
Jan 01, 2011 | liftmaster Chamberlain Garage Door Opener...
Universal remote does not work
Posting your garage door model would help, but there may be a button close to the LED on the garage door opener that you have to depress to allow the two to pair up. Assuming that this is the similiar to my garage door control mechanism, if you have the dip switches set correctly you need to depress the button mentioned above and then depress one of the buttons on the remote.
Aug 18, 2009 | Chamberlain KLIK1 Remote Control
How do I re-code my Raynor Garage door opener Model 61 rdg (on Remote) Serial # 17592 (on opener) Year 1992? I am a new resident in the house with this garage door opener. The remote control opener worked...
on the back of your garage door opener there is a colored learn button--press and release-the learn indicator light will glow for a short time usually 30 seconds. within thirty seconds press and hold the buton on the hand held remote that you wish to operate your garage door. release the button when the motor unit lights blink. if you don;t have a light, two clicks will be heard. it has learned the code. procedure will be different for multi function control.
Apr 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Inside light on garage door opener blinks twice when remote contr
YOu will need to explain the problem for an accurate answer. Thanks BB
Mar 12, 2009 | liftmaster Chamberlain Garage Door Opener...
Remote will not open garage door but the door still works
CHECK TO SEE IF THE LED ON THE WALL CONTROL IS FLASHING.
IF IT IS THE LOCK / VACATION SWITCH HAS BEEN ACTIVATED. THIS IS USSUALLY A SMALLER BUTTON ON THE WALL CONTROL OR A SMALL SWITCH ON THE WALL CONTROL.
WHEN THIS HAS BEEN SET TO UNLOCK THE UNIT, ALL OF YOUR REMOTE FUNTIONS SHOULD WORK.
Nov 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Key Pad
Assuming, from what I read, the remote works..The inside switch is just a doorbell switch which will wear out or have the contacts get bent or dirty. Take off wall, and change for new one or see if the contacts can be cleaned or adjusted. If the pad is electronic (coded) the wires may be bad or the control defective. Usually momentary contact of the two wires will cause the door to actuate.
Apr 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
