Question about Sport & Outdoor - Others
Need service manual for 2009 SKI DOO SUMMIT 800 R
djxtreme979
  • 151 Answers
SOURCE: whats the chances of getting
Chances are good here.
Posted on Dec 28, 2008
  • 65 Answers
SOURCE: 1982 kawasaki 550 stand up ski-doo,starving for fuel
fuel pump ? checked pop off presure in carbs?
Posted on May 07, 2009
drolllord
  • 9 Answers
SOURCE: I am looking for an owners manual for my Ski-doo
Google, "ski-doo grand touring 1995 owners manual. it's a long search term but it helped me. (i had the same problem.)
Posted on Jun 19, 2009
  • 85 Answers
SOURCE: I have a Ski doo 583 RAVE motor theat backfires
It sounds like you have a reed problem they should be in a "cage" just behind the carbs on the cylinder and if they were missing a piece or if they were cracked it would cause the engine to backfire. If they are in good condition they should close against the cage and stop the back pressure coming through the carbs.
Posted on Jan 21, 2010
SOURCE: i am replacing the pistons in my 1997 583 ski-doo
Its not that hardof a process,provided you spend a full day o it and just work through it. You really wont need much more than basic tools. The easiest way wold be to pull the engine.Which is alot easier than it sounds. Once thats out you take of the cylinders and top end.You will have the exposedpistons and rings.From here you will remove the pistons, and you should score the cylinders. Then it requires a little annoyance and time to get the cylinders back over them because of the rings, but after this its just as easy topo the engine abck in and you are all set. And btw while you have it apart you might as well replace all the seals and orings. Hope this helps.peace
Posted on Mar 05, 2010
My 2002 ski doo summit 800 will not start
check spark, check fuel, are the plugs wet, does it start on spray starting fluid?
Dec 11, 2016 | Winter Sports
Im installing a new motor in a 2011 ski-doo summit 800r powertek, and have 3 plugs coming out of the stator only could find where two go is the 3rd for nothing or am i missing something
You are missing something. It's been a year or so since I've done this but all three of those plug back into the main stator connector that is on the right side of the machine behind the exhaust if it was installed. I thought they were all the same color though. Reply here If you haven't solved this and I'll take some pics to help you out.
Feb 13, 2015 | Ski-Doo 2011 Summit Everest 154 800R Power...
Not getting gas to fuel pump
Make sure your hose inside the tank is not broke or cracked.
Mar 21, 2014 | Ski-Doo 2005 Summit Fan 550
Chain adjustment
The Chain is adjusted by way of an Internal Chain Tensioner located inside the Chain Case. Be careful it is full of oil....
Jan 04, 2014 | Ski-Doo 2009 Summit X 154 800R Power T.E.K
2009 SUMMIT SKI DOO WILL NOT START
Ski Doo's are known to have BAD KILL SWITCHES
DPM going bad
Dec 24, 2013 | Ski-Doo 2009 Summit Everest 146 800R Power...
04 summit adrenaline dies every time i put it in reverse what could cause this to happen
This happens with my 800 HO, I replaced the Plugs and Viola... Problem is now gone
Mar 23, 2013 | Ski-Doo 2004 Summit Adrenaline 600 H.O
My 04 skidoo summit 600 HO dies every time i try to put it in reverse what would cause this to happen
my 800 Summit does this also, it is my sign that I need to change my Plugs. and EVERY TIME, it works...
Sport & Outdoor - Others Logo
286 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
