Question about Samsung YP-Z5 MP3 Player
Low battery usb disabled - Samsung YP-Z5 MP3 Player
    Guru:
  • 200 Answers
Ipod 30GB unlocking free code
In order to get rid of the forgotten code and disabled message, we must restore the device.
In this case when the iphone or itouch or similar is giving you a message that its disabled, then we have to first force the device into recovery mode, from which we can do a normal restore.
Note that this removes all the content from your player.
Basically the steps are
1. Take out the usb cable, connect it to the computer, but not to the device.
2. Turn off your device
3. While pressing and holding the home button, reconnect the usb cable to the device, when you reconnect the usb cable the phone or itouch should power on.
If you are low on battery let it charge for a while, then start from the beginning (unplug the usb from the device)
4. While still holding the home button, until you see a message about "Connect to Itunes" then let go.
5. if not already open, open itunes, you should receive a short warning about recovery mode.
6. do a normal restore from itunes, it wipes the devices and the disabled message and the forgotten code are removed.
Mar 20, 2011 | Apple iPod MA446LL/A MP3 Player
My Samsung YP-Z5 player wont respond to charging. Tried plugging into several USB ports on different computers but wont charge. Its constantly displaying .... Low Battery & USB Disabled. I was...
Yes, they only last two to three years.
A search of eBay, a place i look to check availability gives a number available.
Search "Samsung YP-Z5 battery"
If you are able to open up the case You could cut off the existing battery leads close to the battery and join the two wires. Soldering is preferred if you have an insulated tip soldering iron.
Otherwise twisting the wires together is probably good enough.
Tape the joins to strengthen and insulate them.
Feb 08, 2011 | Samsung YP-Z5 MP3 Player
Won't print...say's the printer is not-connected.
Try a new USB cable and switching the cable to a different USB port on the laptop. Check if a known working device will work on the laptop. Make sure that you aren't getting a low power situation (low battery, battery not charging properly). If the power adapter is unplugged, see what happens when the computer is attached to the adapter and getting power from the socket.
USB ports can be shut down for power savings so double check that your computer isn't doing this. (This is an advanced portion of the power savings settings and can be found via the Screen Saver Panel in Windows.)
Check the computer's hardware (Windows Device Manager) to check that the USB ports haven't been disabled by a driver problem or any other issue. Control Panel, Device Manager and scroll down to the USB device controller (Windows)
(the most common problem is the USB cable causing an issue.)
Apr 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
AFTER BIOS UPDATE PROBLEM
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
apolpo-
24
Jul 27, 2009 | Intel Motherboard
Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Oct 11, 2008 | Samsung YP-Z5 MP3 Player
Shutter Disabled
i was quated £250 to replace a buckled shutter unit can this be done any cheaper
Jul 02, 2008 | Nikon D40x Digital Camera
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
Samsung YP-Z5 MP3 Player Logo
100 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
