Question about Watches
How do you remove wristwatch back covers? - Watches
  • Watches Master
  • 19,396 Answers
Hi.
The back plate of most watches is unscrewed by clasping it with a special tools and rotating anti-clockwise. In absence of the special tool a common pair of tweezers will do the job. Once the tweezers tips stick into the marks in the backplate circular panel all you have to do to remove the plate is rotating counterclockwise.
Once the back plate is off, extreme care must be taken with the rubber seal, running around the edge of the case opening. This is very delicate, and damaging or kinking the seal may result in the watch loosing its water proof capacity. For this reason battery replacement is better done at the shop.
Posted on Oct 08, 2010
My Abacus Fossil AU4005 110504 wont charge any more,wen i put it on the charger nothing happen,it does not light up any more,do i need a new battery and where do i get it?
I had the same problem but easy fix.
first make sure you put the watch on charger for a few hours first-- the problem is not the battery not taking charge it is the watch that is not turning on probably.
After a few hours on the charger, remove the four screws on the back cover-- WARNING- remove cover carefully. there are two thin copper wires attached to the cover to the charing coil. set the cover aside. remove battery back (unplug tiny connector). WAIT a10 minutes-- this is to discharge any remaining charge that may be held by capacitor in the watch. plug the battery back in. Voila! working now. This is my way of resetting the watch to factory setting. Isn't it almost always work when you remove power to electronic device to reset it?
Nov 09, 2012 | Fossil Abacus AU4002 wristwatch
How do I remove the back cover of a Fossil JR-8096 (Big Tic) wristwatch?
when you look at the back are there three small rectangular indents evenly spaced on the edge on the back? If so you'll need a special tool for opening waterproof watches. the tool adjusts to fit the three indents then press down as you turn counterclockwise. you can find the tool on amazon.com or your local jewelry store. make sure the gasket is in place and not damaged before screwing the back on.
here is a link to the tool
http://www.amazon.com/Pavilion-Professional-Waterproof-Adjustments-Caseback/dp/B000K3SK0Y
Jul 31, 2012 | Fossil JR8096 Wrist Watch
How do you remove the rear cover to replace the battery on a rado ceramic mans watch ?there doesn't appear to be any access slot, where on many other watches a small grove allows a tool to be inserted...
the cover doesnt appears on the back side of the watch it is engraved with the main body of the watch,take it to a sevice centre they have tools through which the back cover gets separted with the main body of the watch
Feb 26, 2011 | Rado Maxi R21347712 wristwatch
How do you open the back of the Timex Ironkids wristwatch in order to replace the battery? It has four small screws and part of the plastic wristband keeps me from prying off the back to replace the...
mcdevito75 here, Those 4 screws hold the back onto your Timex. Do not try to pry off the back cover, rather you"ll need jewlers screwdrivers to un--screw that back cover to replace the battery.
Jul 31, 2010 | Timex IRONKIDS 70491 wristwatch
I've got the back cover off....how do you remove the inner cover to get to the battery?
If there are screws holding the contact - just unscrew them. If there are no screws - contact legs are clipped and you have to undo them by bending them off the hooks. Rate me, plz.
Feb 02, 2010 | Timex Expedition 84601 Wristwatch
How do I change the battery in my Timex Iron Man Triathlon? I removed the 4 screws in the back but cannot remove the cover because of the overlap of the wrist band.
You will need to remove the wrist first before the cover will come out.Else pull the wrist out and allow it to leave a gap and then you can move the cover out.
Dec 19, 2009 | Timex Sports Ironman Triathlon 100-Lap...
REMOVE BACK COVER
If caseback is without grooves, it is snap on caseback and you have to insert openers blade under the lip and pry up. Lip is the tiny gap between the case and caseback.
If you have groves in caseback, it is screwdown caseback and you will need special opening tool. Insert the blades in to the grooves and unscrew the caseback.
You can find this tool on eBay.
Rate, please.
Mar 23, 2009 | Timex Expedition 40141 Wristwatch
How do i change the battery in a timex wr 30 m watch
remove back cover plate- inside you will need a jewlers screw driver- install new batery in reverse. install screw- and snap cover back in place.Make sure battery is new.
Dec 31, 2008 | Timex 27191 Wristwatch
Watches Logo
59 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
