Question about GE Quiet-Aire Ductless Heat Pump Split System AS1RD09AA0/AS0RD09AA0
GE SPLIT UNIT
Hello, I have had a GE split air conditioner for about 6 years. The unit has started to leak water in the last 3 summers. The drain seems to be clear. I also have a problem in that the unit does not rest against the wall (flush) The install was by the book but we couldn't seem to get it "tight". Seems like there is not enough room for all the piping and "padding " in the channel. Could this be causing the water not to go into the pan properly? If so, how can I getthis unit to hang flush. thanks, Randy
  • hazimhaj Sep 08, 2008
    I have installed 12000 BTUH split unit AlC a couple of months ago. I've been suffering from water leaking from the wall unit since tha last week. The maintenance company won't come to fix it before 14 days. Befeor that date, the unit was performing satisfactorily without any leak. I doubt the possibility that drain pipe is clogged since the ALC has not been in operation for quite a long period to cause clogging.
    The drain pipe cannot be raeched without a rope- ladder.
    How can I solve this problem?
    Champion:
  • 254 Answers
I would check the unit to ensure that it is draining towards the pan assy. should be 1/4" per foot.
Posted on May 30, 2008
I have a panasonic split system in the kids bedroom its an ECONAVI indoor unit is CS-E9NKR we have not used this A/C since last summer, now the compressor will not start, only the indoor unit operates
Typically on a mini split the outdoor unit is powered and the indoor unit gets its power from the outdoor unit. If the unit is a year old you might have lost your charge. Look at the connections at the indoor unit and outdoor unit. You will typically see oil or a dirty area on your copper were there is a leak.
Nov 16, 2013 | Panasonic Heating & Cooling
My outside toshiba split system is leaking a lot of water
If the unit is on heat mode, the outside unit is the "cold" end... Sometimes if the ambient air temperature is very cold ( Under 5 degrees C), the outdoor unit can start to ice up. If it ices up too much, the air con will automatically go on to a defrost cycle where the outdoor unit will heat up and melt the ice. Water is then drained out the bottom.. its the opposite of what happens in the summer when the indoor unit has water running out of the drain hose. Especially on humid days..
Jul 16, 2011 | Fujitsu Heating & Cooling
Leaks water inside
Water leak is the common problem in split air conditioners.. It happens due to:
1. Air filter block 2. Evaporator coil Block. 3. Less rpm of blower motor. 4. Drain line blocked.
To rectify, service the unit completely. If blower motor less rpm, replace motor capacitor.
Dec 18, 2010 | Sanyo Split System Air Conditioner
Hi, i have kelvinator split system in my house.but...
Sounds like a clogged drain pan. You will need to have the unit professionally cleaned.
Hope this helps I take the time to answer your question so please rate me
May 19, 2010 | GE Zoneline AZ38H12DAD Split System Air...
SANYO SPLIT TYPE AIR CONDITIONER LEAKING
The leakage is probably from condensation and there should be some sort of drain for it. You should check to see if it is clogged or partially clogged. Also since you say it does it when it hasn't operated for a while you may want to check out where the lines pass through the wall and make sure that it is sealed up there so you don't get leakage from out side.
May 04, 2010 | Sanyo Split System Air Conditioner
Samsung split systim leaks water from inside unite
when ambient air goes across your evaporater it causes it to condense check your drain hose it may be clogged up not allowing the water to drain properly
Feb 06, 2010 | LG LSC121PMA Split System Air Conditioner
Delonghi split system (inverta) leaking
clear drain line with air or water. If unit is really old possibly drain pan rusted with holes. make sure to change air filter this will cause coil to ice up if restricted.
Jan 23, 2010 | Heating & Cooling
MY split ac is leaking water from the wall unit, it has been doin
Usually an AC unit builds up condensation. If you have a drain hoole or hose that is clogged up therefore not allowing the build up to drain off it will spill over the top of whatever housing the condensation goes into. If you can look for that issue first.
Aug 03, 2009 | GE Quiet-Aire Ductless Split System Air...
LG Split Ac-Sprinkles water in roomafter a while of cooling
first check to make sure that the indoor unit is very slightly off level sloped to the drain area also turn off power and inspect the indoor coil with a flash light to make sure all the fin area is open the drain pan has two possible drain connections if they are both hooked up then the primary "lowest"
could be stoped up a blast of water or air to the drain line should clear out slime also make sure their is a trap in the drain line or the water will only drain dwhen unit is off hope this solves your problem thanks
May 15, 2009 | Heating & Cooling
GE Quiet-Aire Ductless Heat Pump Split System AS1RD09AA0/AS0RD09AA0 Logo
169 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
