Question about Bosch Garden
My turbo wand for my bosch pressure cleaner is not working properly, it only sprays in a straight stream instead of going in a circular motion as usual how do I fix it.
  • 760 Answers
That nozzle actually rotates by water pressure. This allows the 0 degree nozzle (which has the most pressure) to rotate and therefore make a larger pattern. The rotating mechanism is not turning. Most likely it is corroded. If you're handy you might be able to disassemble it and clean it. If not that try soaking in something like CLR to clean it.
Posted on Oct 08, 2010
The turbo wand and nozzle connection on my Pressure washer Model 580.752070 How to restore seal between Wand and nozzle? Please point me in the right direction to resolve this problem
the seal is normally a "O" ring that is available from a good hardware shop or bearing supply shop
basically the same set up as your garden hose "O" ring but with a pressure wand there is a thread nut to hold the bits together.
If it is not that then the threaded section of the connection in the wand or hose mat be loose or broken at the thread
Jun 12, 2015 | Garden
I accidentally cleaned my samsung led monitor with windex. there are streaks all over the monitor. i used a soft cloth to try and clean off the streaks and it did not work. Is there anything I can do to...
Hello mrm552,
The best possible case is to use to a proper tv screen cleaner, ex. monster screen cleaner. The solution comes with a cloth. Spray the cloth with the solution first with one or two sprays. Then in a circular motion wipe the screen. You can get this solution at most electronic stores where they sell TV's. Hope this helps, good luck.
- Joe
Aug 28, 2011 | Samsung Televison & Video
Wii is working fine but when disc is put in it will not play
I see this problem all the time, here are a few things you can try before sending it to www.risingsonltd.com for repairs:
"Cleaning Game Disc
  • Use only: straight strokes when wiping the disc (do not use a circular motion).
  • Use only: a clean, soft, cotton cloth (do not use paper towels, facial tissue, etc.).
  • Use only: water (do not use soap or any other cleaning solution).
  • Do NOT use: solvents such as: benzine, window cleaner, paint thinner, anti-static aerosol spray or abrasive cleaners.
  • Properly cleaning a game disc:
  1. Dampen a portion of a clean, soft, cotton cloth, using only plain water.
  2. With the damp part of the cloth, use straight strokes and wipe the bottom of the disc (non-labeled side) from the inside rim to the outside rim.
  3. After all of the water has been removed, let the disc sit for at least two minutes to completely dry before inserting it into the Wii console.
  4. Try to play the game to see if the problem has been resolved."
If this fails the Optical drive needs to be replaced.
Jun 28, 2011 | Nintendo Wii Console
I have an Audi A4 1.9 TDI. Motor code: AWX. 2003 Prb: When accelerate, the turbo worked properly but after 120 km, the turbo cut off and when i switch off and on the engine, the turbo restart to work. Can...
In your case the turbocharger is responsible for engine losing power.
The car goes in "limp home" mode!!!
After scan the EDC-15P engine control unit with a VAG or KTS -BOSCH diagnosis tool you will find this: Fault code: P1557-Turbo Boost pressure control exceeded
1. Engine stopped and ignition switch off. Check all pneumatic connections and hoses between turbocharger actuator = pressure unit for boost-pressure control, boost-pressure control solenoid valve, vacuum reservoir, EGR control solenoid valve, intake-manifold flap solenoid valve, EGR valve with throttle - part of intake manifold. Also the vacuum connection between tandem pump and brake booster. If you find something wrong replace parts. If not go to step 2.
2. Extract the hose of the turbocharger actuator = pressure unit for boost-pressure control part of turbocharger. Instead of the original hose you must place another 1 meter long hose with the same inside diameter, and then you check to inspire yourself the air from the other one extremity of this hose. The mechanical connecting rod of the turbocharger actuator must have a smooth and whole motion. If you can do that with your mouth, then you must replace the boost-pressure control solenoid valve. If you can not reach this with your mouth, then you go to step 3.
3. This is the most difficult work. The problem is that the soot particles deposits inside the turbocharger plugging the variable nozzle geometry mechanism = adjustable vanes of the turbine. If the turbocharger actuator is not able to adjust the turbine vanes the charge air pressure increases too much and ECU (engine control unit) goes in "limp mode" = engine protection software. As a result the "limp home" mode engine still running until you turn the engine off (ignition switch off) and back on when the "limp mode" is deactivated, but the fault still remain in ECU memory!
4. You must be able to extract the turbo from the engine and then to disassemble the turbocharger, clean inside adjustable vanes mechanism and refit all.
Mar 16, 2011 | Audi A4 Cars & Trucks
My Northstar Turbo nozzle emits a solid stream of water without any turbo action.
NorthStar Pressure Washer Turbo Nozzle --> --> Turbo nozzle sprays up to 3.1 GPM at 2300 PSI and 194°F. Unique design delivers 0° high pressure impact with wide angle spray coverage.
The point of the Turbo is that it is a solid ( high pressure stream of water )
Oct 19, 2009 | Northstar Pressure Washer Turbo Nozzle
Add fluid to tank but it never goes down no matter how long I spray, is it a product fluke?
Your pressure washer has a knob on the front that lets you choose between tank 1 or tank 2. Tank 1 is the larger of the two tanks. Make sure you have the knob set to position 1. Also, you will find that when you have the wand set to high pressure, the tank will not work as well. When you want to spray soap, spray with the low pressure setting. You can set the pressure to low by pulling out the nozzle on the front of the wand. Pushing it back in is high pressure.
Aug 09, 2009 | McCulloch FHH18A Electric Pressure Washer
I own a 2000 audi a4 1.9tdi 115 se salon which has done 125000 miles. during driving the turbo seem to loss its thrust during some of the revs. its very strong when the boost comes in but falls of after a...
I guess your car goes in "limp mode". If you scan the EDC-15P engine computer with a VAG or KTS -BOSCH diagnosis tool you will find this: "Fault code: P1557 - Turbo Boost pressure control exceeded"
You must try follows if you are able to do this:
1. Engine stooped and ignition switch off. Check all pneumatic connections and hoses between turbocharger actuator = pressure unit for boost-pressure control, boost-pressure control solenoid valve, vacuum reservoir, EGR control solenoid valve, intake-manifold flap solenoid valve, EGR valve with throttle - part of intake manifold. Also the vacuum connection between tandem pump and brake booster. If you find something wrong replace parts. If not go to the step 2.
2. Extract the hose of the turbocharger actuator = pressure unit for boost-pressure control part of turbocharger. Instead of the original hose you must place another 1 meter long hose with the same inside diameter, and then you check to inspire yourself the air from the other one extremity of this hose. The mechanical connecting rod of the turbocharger actuator must have a smooth and whole motion. If you can do that with your mouth, then you must replace the boost-pressure control solenoid valve. If you can not reach this with your mouth, then you go to the step 3.
3. This is the most difficult work. The problem is that the soot particles deposits inside the turbocharger plugging the variable nozzle geometry mechanism of the turbine.
4. You must be able to extract the turbo from the engine and then to disassemble the turbocharger, clean inside and refit all.
Success !
Jul 19, 2008 | Audi A4 Cars & Trucks
Got a karcher 410 water pressure passed down to me without directions need help working it
Fairly simple to opperate. Connect water supply hose. Connect wand hose. Plug in, turn on water supply and turn on. Then squeeze the wand handle to spray. With mine, there are times when the unit looses pressure, but if you leave it running, it seems to recover. Also note that you can turn the flare at the end of the wand for a soft stream versus pressure spray. I have had mixed results with the pull out clear tube that is supposed to siphon liquid soap into the mix.
Apr 05, 2008 | Washing Machines
Garden Logo
56 people viewed this question
Top Bosch Garden Experts
roeb
cwradio73
Are you a Bosch Garden Expert? Answer questions, earn points and help others
