Question about Kenmore Elite 45986 Front Load Washer
Dispenser motor The maintenance man did what you advised. Motor spins but won't stop. Then the code flashes.
  • 5,911 Answers
Did the repairman replace anything? Do you still need assistance? If so...the dispenser motor and switch can be checked by removing the connector plug from the Central Control Unit (CCU). This is the 4th connector from the Left in the front of the control board. A resistance reading across pins 1 & 3 on the connector should read 1400 ohms. Readings across pins 5 & 6 should read 0 ohms. If any of the readings are abnormal, replace the dipenser motor and switch assembly. If the readings are normal, you may have an actuator cam on the dispenser that is not functioning properly. Or, spring lever & connection lever that are broken. All the parts combined would cost you less than $60 if you pursue the option of repairing this yourself. Searspartsdirect.com has the parts you need. Just type in your model number and the parts will be listed as items 11, 12, 13, 15 and 16 under the "Dispenser" heading. More than likely the motor is good and you have something wrong with either the switch or the spring lever and/or connection lever. I hope this helps you.
Posted on May 29, 2008
F-30 code the wash water distribution lever is getting stuck over the dispenser during cycle stopping washer. Is the lever out of time?
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Jun 02, 2015 | Kenmore HE2 Plus Front Load Washer
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
Softener does not dispense and we get a code F 30
This error code F30 flashes when the central control unit (CCU) cannot drive the dispenser motor to the proper dispensing position and hence the softener dispensing problem. Disconnect power then remove the top panel and check the dispenser motor assembly for damage or broken parts. You may run a diagnostic test then take a look at the dispenser motor and observe how it behaves. Replace the dispenser motor assembly if damaged.
Click on the link below for the troubleshooting details of this problem and instructions on how to run a diagnostic test.
Troubleshooting Error Code F30 on Whirlpool Duet and Kenmore Elite Front Load Washers
Jun 19, 2011 | Kenmore HE2 Plus Front Load Washer
AWOE9558 Whirlpool Washing machine is displaying a F13 code! Please Help! It wont open the door or finish the wash, what do I do? Thank you
F13 is usually a dispenser circuit error, which means the dispenser motor is not able to move to its proper position.
This maybe because the dispenser motor has failed or the mechanical link from the dispenser to the motor is broken or the wiring to the dispenser motor has become detached.
Try pushing the dispenser door closed more and see if that has any effect otherwise i think you will need a repair man.
Nov 30, 2010 | Whirlpool GHW9400 Front Load Washer
F30 code? Makes a weird noise and drains the soap from dispenser but no water is added and won't spin.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 06, 2010 | Kenmore Elite 45986 Front Load Washer
My Whirlpool washer flashed F30. Not filling up with water.
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus 110.47512600 Error Code F30 = Dispenser System Error. Have reset CCU multiple times. When cycle starts, dispenser motor runs for 3 minutes (~11 revolutions) then stops with F30 error
Sep 19, 2009 | Kenmore HE2 Plus Front Load Washer
CODE 130
Jun 26, 2009 | Washing Machines
Whirlpool frontload duet washer F 6 problem
hello cjkcp
Welcome to Fixya
You said, your washer (now 4 yrs old) occasionally stops mid cycle flashing F 6 code. Is this something we can fix or do I have to call a repair man?
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
I believe this needs a hands on tech to daignose this. Unless you feel you undrstand the problem your self?
Thank you for using our service for advice.
Please remember to leave a rating!
Huuum
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F 13 code
"F13" is a "Dispenser Circuit Error". If the dispenser motor cannot move to its correct position, the error code is generated. You will need to check the following:
- Check the mechanical linkage from the dispenser motor to the top of the dispenser. NOTE: 9 times out of 10 the small spring that connects the motor to the armature comes off and needs to be reconnected.
- Check the electrical connections from the Central Control Unit (CCU) and the dispenser motor. NOTE: The CCU is the Main Computer located directly behind the wash tub.
- Check to make sure the dispenser motor is running.
In order to see all of this you will need to remove the top panel of the washer. Remove the three screws holding the top panel in place in the rear. Once the screws are removed, the panel slides back then off. Locate the dispenser. Make sure there is a small spring attached from the dispenser motor to a small plastic armature on top of the dispenser. Without it the dispenser will not function. Place the washer in diagnostics mode by performing the following:
Select DRAIN/SPIN, NO SPIN and press any key under OPTIONS (must be the same key) 4 times. "C00" will be displayed on the console as the washer enters a series of diagnostics tests. The first portion of diagnostics tests the operation of the dispenser. You should see the armature moving as the different compartments of the dispenser are being tested. If not, I would suspect a possible dispenser motor failure. As a long shot, the CCU can also fail, but may cause different symptoms and multiple error codes. Press PAUSE/CANCEL twice to exit diagnostics.
I hope this information is helpful to you. Please post back if you need further assistance.
May 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
47 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
