Question about RF225 Remote Keyless Entry Car Alarm Vehicle Security System
Why don't my parking lights flash when I lock and unlock my car with remote? It did when I first had alarm put in
Security light flashes and it won't start
top
CODE ALARM SYSTEM
information is always subject to change and correction Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm only Press the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter “UNLOCK” button once OR turn the ignition switch to the “ON” position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button
Press lock (left) button the remotes to be programmed. The door locks will cycle one time.
Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
top
Jul 10, 2008 | 1996 Subaru Legacy
I have DRL on my car and with the factory alarm remote when you press either the lock or unlock the head lights or the parking lights come on. With my Viper 2 way remote no lights come on when pressin
The Viper alarm (and most other alarms) are designed to be connected to the parking lights.The headlights are not meant to be flashed continuously, as when the alarm is triggered. If you want the headlights to activate with the alarm then, the parking light wire from the Viper needs to be connected to the headlight wire instead. NOT RECOMMENDED.
Although the Viper alarm may or may not have a horn output (you didn't mention the model) ,it can be connected and it can be programmed to sound either when the alarm is triggered or all the time(depending on the model).
By the way, the Driving while Running Lights are seperate from the Sentry Illumination Lights. The Sentry Illumination Lights are designed to illuminate the area in front and around of the vehicle before and after entry. They can be programmed for the time that they will illuminated before and after entry.
Aug 25, 2012 | Remote Start System
Parking and cab lights don't flash where arming or disarming. Also Lights don't say illuminated when remote start is on. Did i turn this function off?
It's possible that the parking kight wire is no longer connected or, the (alarm's) fuse for the parking is blown. The parking light fuse for the 5701 is located behind the door on the alarm module.
Jul 20, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a Viper 5301. Just recently the blue light on the valet stopped blinking when the car is locked with the remote. It just stays on all of the time, no blink. At the same time, the remote started...
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Apr 14, 2011 | 5301 LE 2 Way Car Remote Starter System
Just notice blue lights flashing in the car. I unlocked, from inside the house, and manually locked from the lock on the inside door. That stopped the flashing blue lights. What has caused...
Do not be alarmed; the blue light is flashing because you used the remote to lock/arm the vehicle. It is a visual theft deterrent, even if you do not have an alarm. It's normal. The reason the light stopped flashing is because you unlock the vehicle with the remote and locked it with the door switch.
Feb 11, 2011 | 5301 LE 2 Way Car Remote Starter System
I bought a 1996 Subaru Impreza L 4dr 5speed AWD that runs and starts fine but when I was installing fog lights i noticed that there appears to be an alarm hooked up (it says "code alarm elite DM...
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
CODE ALARM SYSTEM
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
Open driver's door.
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
Jan 05, 2011 | Subaru Impreza Cars & Trucks
My car alarm will not work (disarm) with the remote. when I use the key to open the door the alarm goes off and car won't start. I've repleaced the remote battery, with no luck. The red light on remote...
Here's how you fix this:
- Open the remote, and take a piece of paper (something small, I used a crushed straw wrapper) and put it on top of the battery. It needs to make the remote somewhat difficult to close, but it needs to close.
- Make sure the red light flashes EVERY time you press unlock/lock. Your car might lock/unlock now. If it doesn't, move on.
- Get into the car somehow. Yes, the alarm might go off. Ignore it, put the key in the ignition and turn it to ACC. Then and hold both buttons for a few seconds. The light should continuously flash.
- Turn the key off, and wait for the alarm to stop. Then press unlock. If it works, congrats! No more issue! If not, you may need to take it to the dealer for service.
I just fixed my remotes this way. The contacts wear out, and the battery box literally fell off of one of the remotes. Forcing the battery box against the circuit board is the free way to fix it. Remotes aren't too cheap! Good luck!
Sep 02, 2010 | 2003 Hyundai Tiburon
Lost original car alarm control... need to reset a new one...
programing a Nissan remote , is hidden secret by Nissan Dealers. As a Nissan Technician i will share it.
Just get in your vech , close all doors. Using your power lock switch , lock all doors. After doors are locked take your Ignition Key and insert it and remove it from ignition switch in a slow fashion , but consitant pace. (97 and earlyer are fast) When you see the hazzard lights flash, put key in ignition switch and turn to the On postion .. Do NOT CRANK or you will have to Start over .. After in the On postion .. Hit the Lock button on remote... Hazzard lights should flash..( note..you have to reprogram all remotes when adding a new one , if you don't your old remotes will not work ) If your doing just the one , turn igntion switch off and unlock door and get out and try it. If you are doing more than one. While still in Vech with Key on . After you hit the Lock button on Remote and hazzard light flashed .. with key still on .. use master lock switch unlock doors and relock and then hit Second Remote, Lights should flash again , repeat if adding a 3rd remote.. after done just turn key off and unlock door and get out and try.
Oct 29, 2009 | 2002 Volvo S40
I have a DEI 471T remote start/lock. The parking
There is a white wire coming from the alarm, there should be a blue 15 amp fuse in that wire, close to the brain for the alarm. It sounds like you have blown that fuse.
Aug 10, 2009 | Directed Dei Valet 561r Remote...
RF225 Remote Keyless Entry Car Alarm Vehicle Security System Logo
185 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
