Question about Nokia 5310 Cellular Phone
SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted!
    President:
  • 2,360 Answers
It may be due to network lock, contact service provider , else you can get unlock codes here http://www.unlocking4u.com/supported-phones/rs6wp7/
Posted on Nov 29, 2010
Nokia 3110 10 second auto off solutions
If the phone restart itself after few seconds frequently this problem occur due to enable or Watch Dog Timer (WD timer) so at this stage we need to repair Super Doungle by using some repairing tools likeMX KEY/Turbo flasher etc.To fix this if you are not a mobile tech better to contact mobile repairing shop.Good luck "Thanks for visiting fixya"
Oct 20, 2011 | Nokia 3110 Cellular Phone
My nokia 6500 slide phone getting switch off automatically every five minutes.. pls give solution
When we do check bus with MXkey this message will show. SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. This error can only repair with MXKEY via internet.So the best way to solve this problem is to concern a good mobile tech.Without going to repairing shop it cannot repair.In case if you are a mobile tech pl reply let me give you the procedure.
Aug 02, 2011 | Nokia 6500 Slide Cellular Phone
Phone Type: RM-635 (Nokia 2690)\r\nSW Version: V 10.10 22-04-10 RM-635 (c) Nokia Imei plain: 35430504997723-9 Battery voltage: 4709 mV, current: 53 mA Language Pack: - not available. SIMLOCK...
We could not repair this problem because 2690 is Sim lock (sl3).the only way to solve this problem is to buy RPL file and write it.Like the heart of human beings this file is the heart of every phone.Anyway I'll help you to find out the solution in case if I found.Thanks
Jul 26, 2011 | Nokia 2690 Cell Phone
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
I cant switch on my phone nokia3110c , every time i tried to switch on it says CONTACT SERVICE
hi,
your phone have a software problem and its cause is "security test failed"thats why it has a contact service status...by fixing that you need this gadget ...
1.mx key activated dongle with ufs interface
2.3110c fbus cable (same as 3500c and 6300
3.)modified pm 1 and 309 of 3110c
procedure...
a)open mx key
b.)connect the phone to mx key using fbus cable
c.)in mx key select bb5
d.)bus check and you you will see this logs
SIMLOCK seems to be valid
SUPERDONGLE_KEY seems to be valid
CMLA_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
in this logs you will noticed that security _test is the only failed...
e,)we will continue by selecting PM then thick PMM authentication
f.)then your pm now is authenticated ,write the modified PM (by writing modified pm ,thick load from file ,then write)
g.)after writing PM here now is your phones logs...
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
h.)now you need to unlocked the phone by clicking ,SERVICE ,IMEI and SECURITY then INIT SIMLOCK...and you phone is done
always remember ,when doing software action to your nokia phone ,always back up the rpl to prevent more damage..thanks for trusting fixya..
Jun 19, 2010 | Nokia Cell Phones
I have an 3310 with trouble sim card not accepted
maybe your phone is locked by operator.
if your phone network is open lock or not locked by operator it may come from the phone security validation.
3110c is Base Band 5 series or we usualy call BB5.
this phone have security inside the Rap3G and the Nor Flash.
if the data inside the Nor Flash not match with the data from Rap3G then the phone imei will be 1234565454
321?
but the phone should be accept the sim card if only the imei is corrupt.
why? cause the simlock data is writen in the Permanent Memory or PM group 308.
so if the phone reject the sim card maybe the PM 308 is corrupt.
forcing erase phone can make the data inside NOR flash like MCU and security (IMEI and the PM 308) erased from the phone.
after refaslh the phone, the phone will alive but the security data is removed.
and when the watchdog inside the phone found the phone dont have the correct data, then the phone will automaticly shut down in 30 minutes. if you put charger on phone, it will faster the WatchDog timer to 3 minutes, or you play the music from the phone it alsi faster the WD timer to 3 minutes.
how to recover the security data?
read ASK data (Ask Security Key) and send it to the Nokia and it will be RPL data and write this data to your phone.
this ASK to RPL services is not free, and you need dongle to make this job.
Sep 23, 2009 | Nokia 3110 Cellular Phone
Help openline..or remove sim lock for Nokia N73
removing a nokia simlock.. did u simlock it yourself or you forgot the simlock code. any way if you still cant get through with the simlock.. i will sugetst you hard format your nokia through this procedure...have u tried the hard formating.. the hard formating will remove the code and activate the nokia default code for you.. switch off ur fone, then press and hold *+3+(send key) 3-5 mins without removing ur hands,.. then ask someone to help you switch on the fone still dont remove your hands off the key till the fone restats.. this shuld help.. thanks
Dec 21, 2008 | Nokia N73 Cellular Phone
Forgot my lock code
remove the sim and enter *2767*3855# then wait for 1 minute your phone gone restart him self then your phone is free
Apr 05, 2008 | Cell Phones
Nokia 5310 Cellular Phone Logo
302 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
