Black screen &my laptop fan is runnig - Computers & Internet
    Scholar:
  • 181 Answers
Good day.
Black out monitor can be cause by number of reasons and errors. If you are feeling that the laptop's fan is working, then the power supply adapter and the battery is good. You may also try to use only the adapter by removing the battery or the other way around. This will isolate problems with the source of power.
Second, at the back of your laptop, you can see a removable panel cover (using an ordinary screw driver). Inside that panel is the memory. Try to eject/remove the memory module by exerting a light force on the knob at each end of the memory socket. Remove the memory module and try to clean the contact points using a pencil eraser. Corrosion and dirt may result in a poor contact with the socket. Re-seat the memory module and power on test.
If you still have a black out screen, the sad part is, the remaining culprits are the LCD monitor, the LCD hinge/contact points, the on-board video card and the motherboard/CPU. These parts are not user-serviceable and you need the help of a service man to disassemble and check the parts.
Good luck.
Tedmac
Posted on Oct 08, 2010
Compaq pressario v 3000 v3424au amd turion64 mobile technology nvidia graphics my laptop on runnig fan and harddisk bun not on disply and not load hard disk, no load light on. i checked hp service...
I think Nvidia Grapichs Chip Over Heating & Dry Solder Problem,
Lot of Compaq Laptop Facing Same Problem.
BGA Rework Solving This Problem Watch this Video
But Only 3 to 6 Months.
Agaian using Games Or Hevay Graphics Works Facing Same Problem Again.
Apr 18, 2011 | Compaq Presario Notebook
I have a dell vostro 1000 and when, i turned it on it seems to be runnig, but gives a fully black screen...
ok.Tell me more about this problem.
Have you tried to connect an external monitor to the laptop?
Nov 23, 2010 | Dell Vostro 1000 Laptop
My Eee netbook just shuts off, the fan keeps running untill i get the black screen which can mean its overheating because the fan is constantly running. Please help me fix this problem ive spent way too...
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 20, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I'm facing this problem since a few time now, when i start using my laptop say for after 20-30 mins the screen goes all black and after 20-30 the computer shuts down automatically. what can be the problem?...
Sep 08, 2010 | Compaq Presario CQ60-220US PC Laptop
My msi u100 notebook is runnig slow how to fix it
Sep 05, 2010 | MSI Wind U100 Netbook
Toshiba Satellite a135-s4527 shuts off itself. And when I restart, I'm getting black screen right after Toshiba logo. It starts eventually.Anything I can do?
you dont say how long it was runnig when it shut off,,nor did you say if or not it shut off again after you eventually got it giong again,,,,a lappy will generally shut down for no reason if the cpu gets hot,,this is caused by the amount of dirt and dust in the cooler fins and fan,,,
Jul 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
Gateway M-7315U "Major Fan Error" will not boot up, This is what it says on black screen when I turn on the laptop "Major Fan Error" and the fan is not spinning at all, How do I fix this problem? What is...
no need to buy a fan if u can uncover your laptop spin the fan through yr finger is it spin smothely or not & also check the fan jack inserted properly or not clean the fan with brush repack switch it on if problem persist contact me
Feb 24, 2010 | Gateway M-7315U Notebook
Hp Have black screen & 2 beep sound
Motherboard/fans/loose wiring
Oct 01, 2009 | Computers & Internet
Can't boot up my acer 290 notebook as the screen is
Hi,try making sure your heatsink is properly seated on your cpu chip with some cpu compound between them......I had a laptop that did the same & when i checked the cpu heatsink & fan i noticed the screws holding down the heatsink onto the chipset had come away so i applied some compound to the centre of yhe chip reseated the heatsink with longer screws & i also gave the heatsink & fan a good clean,put it all back together & it worked fine...goodluck
Jun 06, 2009 | Acer TravelMate 290 Notebook
Taking a long time to cool down and when does the fan kick on
the evaporater fan should be opperating when the compressor is runnig ,as well as the condenser fan if you have one
May 19, 2009 | Oster 12-Bottle Wine Cellar - Black
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
