Question about Delta Enterprise Snoopy Deluxe Crib
How do you take the covers off
We are trying to take the cloth covers off to wash them and can't figure out how to get the canopy off to take the rest off
There are two screws on the sides, you might want to unscrew them, after you do so the thin bar should snap off if u give it a little tug..then you can remove the canopy and the rest of the covers..make sure you remember how it looks before you take everything off..because it could be trick putting it back together, thats my problem now i cant remember how the canopy gpoes back on...?
Posted on Aug 31, 2009
  • jaysiona
    jaysiona Dec 17, 2013
    i no i need to go there
    New Friend:
How do yp change a babys diper
Posted on Dec 17, 2013
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Regards
Sep 28, 2011 | Dryers
I can not get the cloth off the top part to wash it... i got the cloth off the middle and i got the net off to wash. but i cant get the canopy/visor thingy off.
Please check your bassinet for recall at this link. You can also check with Walmart by
calling the local store and have them lookup your model and date of manufacture.
http://www.cpsc.gov/cpscpub/prerel/prhtml08/08381.html
The canopy has to be washed in the sink. The rivets dont come off. Air dry should work.
Feb 28, 2011 | Simplicity for Children 4-in1 Convertible...
I want to take off the cover to wash it but I can't figure out how to take the canopy off.
Yes I figured it out all by me self. Just need some elbow grease to pull on the bonnet tabs that are snapped onto the bassinet. All clean and back together. The bonnet isn't dirty but if I want to clean it one of these days I will take out the stitches clean it and then decide if I can Velcro it back in place or hand stitch it. The connection on the bonnet is riveted on so not an easy fix.
Thanks for checking up on me.
Kathalynn
Sep 30, 2009 | Kolcraft Cuddle 'n Care Bassinet
Love the Venezia stroller but can't figure out how lower back res
On the back of the backrest there is a **** in the fabric with a metal handle/lever. Pull up on this lever to adjust the backrest in numerous positions, including laying flat.
Jan 12, 2009 | Peg Perego Venezia Single MT Blu Moon...
Dismantleing canopy
If this is for the Graco Snugride (I have the Windsor model from the Quattro Travel System), this will work:
1. Push the Graco canopy to one side, exposing the plastic support bars that hold the canopy in place.
2. The center of the support is where the canopy comes apart. Using both hands, pull the canopy support
bar apart (as if you were playing tug-of-war). It's best to grab the curved ends and pull HARD (and point it away to the side so that you don't hit your face).
3. Once the support bars are apart, remove the old Graco canopy and slip on the new/freshly washed canopy.
4. Secure the support bars by snapping them shut, and then slide the canopy into place.
Aug 26, 2008 | Graco SnugRide - Clover
Cosco Eddie Bauer Stroller Canopy
the lower frame bar locks the canopy onto the frame. Remove this and remove the brackets from the frame. drill out the rivit on one side (take note of the location of the snap and washers) and then remove the frame from the bracket and canopy. you then use a 1 inch 5/32 rivit to reassemble.
Jun 22, 2008 | Cosco Eddie Bauer Lightweight - Blanchard...
Stroller pad cleaning
You can remove the seat pad by unsnapping the two straps on either side of the bottom of the pad (where it covers over the metal frame). Then just thread the buckles through it. As far as the rest of the fabric such as canopy or fabrice sides, no luck. I got this stroller used and wanted to wash it all. I ended up just putting it (minus the removable pad) into my shower and washing it with the shower head. Then I got a Mr. Clean magic eraser and cleaned up the plastic parts. Now it looks so good!
Hope this helps...
Jan 03, 2008 | Evenflo Aura Traditions Travel System...
Graco bassinet model 3300
http://www.babyage.com/icons/localhost/products/multimedia/10186_RocknRollBassdir_12_17_03.pdf
Dec 01, 2007 | Graco Simplicity Rock n Roll 330 Crib
Kolcraft Bassinet
Hello
I too have this bassinet and went looking online for a 'how to' on removing to wash. What I found was the manual, I will post the link below. In the manual it does say that the fabric cannot be removed from the canopy frame.
you have to either turn off your pop up blocker for this manual or hold down "control" when clicking the link for it
http://www.kolcraft.com/Media/B22-R2.pdf
Apr 29, 2007 | Kolcraft Light Vibes 18270 Crib
Need help
https://plweb.evenflo.com/faq_detail.aspx?faqid=4990 Question: How do I care and clean for my PortAbout 3/PortAbout V infant car seat? Answer: To clean pad slide the elastic loops of the seat pad off of the seat shell. Remove the harness system. Cloth pad, canopy, and head support may be machine washed separately cold water, delicate cycle, tumble dry 10-15 minutes, low heat. Wipe straps, buckles, and harness adjusters with warm damp cloth and mild soap. Air dry. NOTE: DO NOT submerge harness assembly in water. To help protect the vehicle upholstery, place a towel beneath and behind the child restraint.
Feb 23, 2007 | Evenflo PortAbout 5 Infant
Delta Enterprise Snoopy Deluxe Crib Logo
628 people viewed this question
Top Delta Enterprise Baby Gear Experts
Dorel UK
Dorel UK
Are you a Delta Enterprise Baby Gear Expert? Answer questions, earn points and help others
