Question about Dyson Slim DC18 All Floors HEPA Bagless Upright Vacuum - Iron/Titanium/Yellow
My Dyson Slim vacuum makes a burning smell when turned. It functions normally but I'm afraid the motor is being damaged.
SOURCE: Dyson DC07 burning smell.
sounds like it is on the way out this may be because 1, you need to clean the filter cos when its dirty it stop air from going around the motor witch makes it get hot and overheat 2, also if you allow the bin to get to full this will also stop the motor from geting air to it so a good clean on your filter and bin will allow air to the motor then no overheating should accur
Posted on Jun 17, 2007
chrispurs1
  • 372 Answers
SOURCE: Dyson DC07 Vaccum - brush will not turn
Hi.
Your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive & try the machine.
If you still have no brush rotation after doing all this then UNPLUG machine from mains supply.
Now lay machine on its side & remove the sole plate, This is the cover over the brush roller.
Turn the 3 plastic screws to unlock postition & lift sole plate off.
Now try to yurn brush roller using your hand. It should turn freely if it is difficult to turn look for any foriegn object obstructing the roller.
If no obstruction found then remove the brush roller from the machine & check the bearings in the ends of the brush roller one or both may be siezed up if they are then new brush roller will solve the problem.
If bearings are good then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
It is difficult to fully explain the clutch removing procedure,
But there are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/
Posted on Jul 05, 2008
  • 5 Answers
SOURCE: dyson 18 losing suction
Check the HEPA filter if it has one. This bit of foam gets clogged over time and significantly reduces the suction especially if you've been vacuuming a lot of very dusty areas i.e. dust from building work etc. Just wash the filter with lots of water and leave to dry before reinserting.
Posted on Aug 12, 2009
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Posted on Oct 04, 2009
Samyfam
  • 379 Answers
SOURCE: When I turn on mt dyson is sounds normal. once I
With the DC14 in its upright position, and looking from the back, there is an access hatch just to the right and bottom of the dust canister. Remove this and check for any obstruction. With the hatch still removed, tilt the handle back (as if vacuuming a floor), and you should spot that the mechanism in to which the access hatch fits changes over from one hole to another. This is how suction is transfreered from the telescopic arm to the brush bar when the unit is taken out of the upright position.
With the handle tilted back, the hole you can see is one end of a flexible pipe that leads to the brush bar. Check for any blockage and/or foriegn objects. If there is no obvious problem, you'll need to check the other end of the pipe. You can do this by removing the toe plate on the bottom of the brush bar area. The plate is held by 3 or 4 half turn fasterners - a 5 pence piece is ideal for undoing these.
If still no joy, the only other thing it might be is that the brush bar isnt spinning - this isnt actually lack of suction, but without brush rotation any upright hoover is far less effieicnt at picking up bits from the floor. Brushes not spinning on a DC14 is quiet a difficult thing to fix on a DC14 as there are two separate rubber belts, one of which is hidden under a plastic cover. There is also a clutch mechanism between the belts that can cause problems some times.
Posted on Oct 09, 2009
D25 ball motor screaming noise burning smell and smoke coming from ball. Extended warranty expired recently!
The motor has seized and burned up. Its going to need professional repair as those motors are electrically controlled and not normal 120V motors.
Oct 16, 2016 | Dyson Dc 25 Animal
How do i fix dyson DC41 Animal vacuum upright cleaner it has burning smell coming from motor and it blew the fuse box when i WENT TO VACUUM. the wire flex is a bit over twisted
You most certainly shorted this out and will need a new cord. Easy fix but you will have to take it apart and find where it failed. I doubt the motor fried but it is possible. When you take it apart look for the burn mark left by the electrical arc. That is the point you fix.
Dec 26, 2015 | Dyson DC41 Animal Bagless Upright Vacuum...
Moter is smelling like it's burning
Hi there, it's Jack at Dyson.
If your DC19dB's motor is making a burning smell in use, please do not continue to use your machine until we can arrange for a qualified Dyson engineer to inspect and repair your vacuum.
When you have your DC19dB easily to hand, please contact the freephone Dyson UK Customer Helpline on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
We'll look forward to speaking with you. Once we've taken some additional details we should also be able to confirm if a repair is covered under your free 5-year Dyson parts and labour guarantee.
Mar 12, 2015 | Dyson Dc19db Multi Floor Cylinder Vacuum...
Dyson not working making a loud noise and smelling of burning
This is probably due to the motor going bad. Before purchasing a new vacuum, get an estimate for replacing the motor.
Feb 16, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
HI , I REPLACED MOTOR BRUSHES ,BUT MOTOR IS MAKING A FUNNY NOISE ,AS IF MOTOR IS LOOSING CONTACT ,LIKE A BURNING SMELL. CHEERS
Most likely you have a damaged commutator. I used to change the brushes on the dyson vacuums but what i found is that it is almost never completely successful. THe Dyson motor is not as good quality as say a miele and when the brushes go they normally cause damage to the commutator. THe best bet is to replace the motor. If you were able to swap the brushes a motor change will be easy for you. If you are in Australia you can get the motors from VacuumSpot or Nelson Vacuums.
Dec 25, 2010 | Dyson DC08 Cylinder Bagless Canister...
Motor is making a knocking noise with a burning smell and sparks can be seen when switching on
Sounds like ur FiLTER is CLOGED!
Air was blocked going in the motor thats why ur smeling smething burning, means ur motor is starting to overheat!
Spark in the motor is NORMAL when the CARBON BRUSHES is touching the ARMATURE!
My suggestion is to CLEAN & WASH the filter or buy a NEW one!
Hope that cleans evrything on ur probs!
Dec 04, 2010 | Dyson DC08 Cylinder Bagless Canister...
We have a DC14 burning smell then not working
i am afraid that is ur motor that has blown this can be easily repaired by dyson ring the no. on the vac full service and repair only £60
Mar 20, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Dyson DC07 keeps cutting out and smells of
does it smell like an electrical burning smell? sounds like your motor has went bad.
Mar 06, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc14 died, no power after burning smrll
It sounds like the motor has overheated and has now been irrepairable damaged.
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Won't Turn On
If you are getting a motor smell, then either something got into the fan and stalled it, or the motor went bad. Afraid it will have to be taken apart and checked. Can you turn the brush roll, if not there maybe a problem there.
Feb 18, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson Slim DC18 All Floors HEPA Bagless Upright Vacuum - Iron/Titanium/Yellow Logo
87 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
