Question about Maytag Washing Machines
I have a 5year Maytag washer,the agitator completely lifts out of the washer machine
  • 1,122 Answers
Posted on May 29, 2008
I have a Maytag Washer Model LAT9206BAE, I have cleaned the washer but my clothes are still getting a lint like substance on them. Is there a screen or something on the discharge that may be blocked.
There is no filter. You may have something that is hung up under the agitator. To remove the agitator, remove the fabric softener cup, then the bolt that holds the agitator on and lift the agitator out.
Nov 22, 2012 | Maytag Washing Machines
Maytag washer agitator is lifting from male portion during wash cycle
6_21_2012_6_30_07_pm.jpg6_21_2012_6_30_37_pm.gif6_21_2012_6_31_00_pm.gifyou must examine every part, may be the drive shaft the bolt is broken you need to replace and dissasembly the machine. God bless you use the logic sense
Jun 21, 2012 | Maytag Washing Machines
Maytag washer agitator lift from male assembly when washing
use the logic sense see the diagram the shaft can be loose, or the bolt is broken, you must dissasembly the agitator see the parts carefully. God bless you
/There is a gold chain necklace wedged under the agitator. How do I loosen the agitator so it will lift up just an inch or so?
remove center downy cap on top of agitator get a 7/16 socket and long extension and hold base of agitator and loosen screw in center of agitator pull up agitator out of washer...
Jan 27, 2011 | Maytag Atlantis MAV6000 Top Load Washer
How to remove the agitator from a Maytag Washer PAVT-1 in order to untangle caught cords
Open the lid, remove the Fabric dispenser, then you will see a nut in the agitator, remove it and lift the agitator out.
Nov 20, 2010 | Maytag Performa PAV2200
Maytag MAV5000 washer will not agitate
Lift the washer up and see if drum drive belt is broken or direct drive coupler is defective.
Mar 29, 2010 | Maytag Atlantis MAV5000
Agitator noise in maytag performa machine
The noise in your washer tub could be caused by some object lodged under the agetator. Lift off agetator and check. Or somthing could have gotten into the sump tub. this could be a major job as you would have to remove the complete inner tub assy. One other problem I can think of it could be worn tub bearings. If the washer is 10 or 15 years old I would replace it,
Dec 03, 2008 | Maytag Performa PAV2200
If you suspect the leak is from the main drum seal.
To remove the agitator, remove the softener cap by pulling, look inside the agitator, undo the bolt (4) with long socket extension and then lift out.
5e90500.jpg Not sure if you can see the seal ("O" ring at this point, you may need to remove the inner drum.
Isolate the supply.
Lift the top cover by inserting a flat blade approx 4" in at each side at the front to release the two top clips, top cover will lift and hinge backwards out of the way.
To remove the top ring (13) from the drum, unclip each clip around the top untill released, then remove.
to remove the inner drum (10) , unbolt (7) from the inside, lift out inner drum.
Seal (1) should be visible.
Mar 24, 2008 | Maytag PAV2300 Top Load Washer
Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Nov 28, 2007 | Washing Machines
Washing Machines Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
