Question about Mtd Garden
My MTD Sprinto was happily mowing away until i stopped to empty the grassbox. When i returned, it would not start. It has a new battery which reads 11.97 volts, so no probs there and the spark plug looks ok. It sounds like it is turning and turning but with no eventual fire up. Is it possible that the carb has blocked. If so, is ther a quick fix?
  • 10,865 Answers
Remove the air filter and take a close look at it with a bright light. It may be clogged. IF so, replace it. Also get a can of starter fluid and a helper. Have your helper squirt a little starter fluid into the air filter opening while u start it up. IT will start. Then keep it running by adding more starter fluid until the problem clears, usually within a minute. Joe
4 thumbs up please. ty
Posted on Oct 08, 2010
WHERE CAN I GET A MA-628837 JAPAN PART FROM TO FIT THE MTD SPRINTO 6.5 KAWASAKI
Try Amazon search. Or Google your info for it. That's what I do.
Apr 24, 2016 | Mtd Garden
How do I tune the carb on a Kawasaki 6.5HP engine (fitted to a MTD Sprinto mower? The carb is marked 'LMJ' and has a sprung adjusting screw with a slotted head. It also has a black plastic adjuster that...
the pin is the needle & seat / start the engine & warm up the spring loaded one ideling screw / black one fuel/air turn this in until almost stalls then anticlock wise till is running smoothly
Aug 11, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I just bought a used mtd sprinto. The previous owner seemed very genuine and said he hadn't used it for a while (a few months, I think). The mower is very clean all over and looks in good condition. The...
If there is an anti fire solinoid on the base of the float bowl you need to check it functions ok, unscrew it from the float bowl, switch the ignition on, the centre pin should retract fully into its housing, if not it will shut off the main jet in the carb and cause all sorts of problems.
Aug 10, 2013 | Mtd Garden
I have a 6.5 self propelled Lawnman by MTD . It will start but will not stay running.
is the handle hard to pull?or pull back at times?any way pull the flywheel off and check the key that aligns the crank and flywheel in time they shear when you hit rocks
May 08, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Dec 06, 2009 | Marantz CC-4000 5-Disc CD Changer
Installing lawn mower battery
I have Yardman, MTD, 13 HP, 38", 6 speed. Put in new spark plug and new battery. Started first time and successive times (2), battery is completely drained. Can be jumped and started and will mow, but when it is shut off, there isn't any battery to restart. What would be draining the battery or not allowing it to recharge????
Sep 09, 2008 | Garden
Garden Logo
351 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
