Can someone please help me load a rexel giant stapler - it loads from the rear but I can't remember how to do it?
2 Suggested Answers
SOURCE: We have a Swingline Giant
The triangular plastic section at the rear is the end of the staple tension/feed assembly. Grasp it, push inward and lift upward to release it, then pull it rearward and out of the stapler. Insert staples and reinsert the feeder and lock it in place again.. ready to go!
Posted on Jun 02, 2011
I cannot get my stapler to work. I got it last year for christmas and have never been able to use it. Can someone help?
What is the make & model of your Stapler (should be written under the bottom). The obvious question is, are you sure there's staples loaded in it? When you say you can't get it to work, does that mean you try to staple something but, it doesn't staple? Or, something else?
Dec 04, 2014 | Swingline 87875 Optima Desktop Stapler,...
How to load staples into rexel easy touch stapler
If you imagine that the end that the staples come out of is the front, then the back is where you load the staples. Your picture shows a small black bit at the very back of the stapler. You have to remove this, usually by pushing it in and lifting it up. Once loosened, it should pull out from the back of the stapler. You should then be able to reload. Finishing is the reverse process.
Nov 05, 2012 | Tools & Hardware - Others
My rexel stapler does not work, any help[
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Sep 11, 2012 | Office Equipment & Supplies
How do I open up a rexel stapler?
There's a plastic button on the back of the Rexel stapler that says "press."
May 04, 2012 | Tools & Hardware - Others
I have a Stanley Heavy duty stapler Model# TR250 and for the life of me I cant load the staples. Please help!
Most staplers load from the rear, but not the TR250 Sharpshooter.
With the stapler upside down and the sliding rail out drop a whole strip of staples in the channel upside down (points up) and then push the slider back in making sure it locks.
Aug 03, 2011 | Stanley Hvy Duty Staplenail Gun Tr250h
I have a rexel odyssey heavy duty stapler but the spring has popped out, how and where do I attach it back on?
Rexel Odyssey heavy duty stapler: The pring that pushes the staples into position can come losse if the stapler iss dropped. It's difficult to work out how to replace it! However, there are only two "lugs" that will take the circular ends of the spring. One obviously fits to the sliding staple retainer. The other to the back end of the pressed-metal inner body. However, to work, the spring must be threaded from this point along the pressed metal parallel-sided inner body back through a slot and over a rounded bent piece (shiny from prvious friction) and back down to the sliding staple retainer. It's trickey to do, but that's where it has to go in order to provide forward tension when the Stapler is closed.
Aug 02, 2011 | Office Equipment & Supplies
We have a Swingline Giant 660 HD stapler and we can't figure out how to open it to load staples. Unfortunately, we have no idea where the instructions are.
May 10, 2011 | Office Equipment & Supplies
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
Hi Guys Rexel Cosmos 210 Stapler (Staple Gun - Mk II) I have a Rexel Cosmos 210 Stapler that has a broken white plastic bit. I have had it and used it at work for about 25 years. How can I get a...
I have one equally old and my plastic bit broke off many years ago.
I just get used to using it without.
It sticks but it's such a good stapler I forgive it.
Jun 12, 2010 | ACCO Brands Office Equipment & Supplies
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
5,435 people viewed this question
jasbo
jasbo
