Question about Kodak EasyShare C315 Digital Camera
Need to replace battery comparment door
Battery door compattment broken
  • 3 more comments
  • D-LOWE Jun 01, 2008
    I have a c530 and my battery compartment door is broken . I tried duct tape but that didn't hold.
  • Anonymous Aug 05, 2008
    need to replace battery door
  • HeatherJean Oct 17, 2008
    I actually purchased the replacement door directly from Kodak but they never told me how to install it. The pin does not seem to move. Do you have to take the entire camera apart to install the new door?
  • Anonymous Jan 13, 2009
    I have the same problem. I can find the door, but not instructions as to how to replace it. Do I have to take the camera apart?
  • James Troske Jun 06, 2017
    Life the metal tab on the inside of the cover. Pull off plastic cover. Slide new plastic cover in place. Done.
    New Friend:
I have a c143 and my battery compartment door is broken . I tried duct tape but that didn't hold.
Posted on Dec 27, 2012
  • cskumar01017
    cskumar01017 Dec 27, 2012
Kodak Easyshare C530 Battery Door replacement can be purchased on ebay. Search: Kodak Easyshare C530 Battery Door
Posted on Jun 24, 2008
Vaio replacement battery "plugged in. not charging"
For this kind of issue, you may try the following troubleshooting steps for confirmation:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure your vaio vgn-cr510e power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Dec 24, 2012 | Sony VAIO VGN-CR510E/P 14.1" Laptop
Powershot sx20 battery cap lock got broken now the cap will no longer close
Use electrical tape for holding the door or you need to visit service center for replacing the complete door.
Aug 07, 2012 | Canon PowerShot SX20 IS Digital Camera
Need to replace battery door.
i have not replaced the battery door but have disassembled an S5000 following the service manual
it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
Nov 29, 2011 | Fuji FinePix S5000 Digital Camera
My battery door is broken I have to put a rubber band around it to hold the batteries where can I find the battery door
Battery doors are almost impossible to find online. I'd contact Fuji by telephone to see if they retail themselves, if not, i'd try and use the broken battery door to somehow replace the elastic band.
Nov 22, 2010 | Fuji FinePix S5000 Digital Camera
Does not power up when plugged in suspect battery needs replacing
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
5. The power button could be bad.
Sep 12, 2010 | HP Compaq nx9030 Notebook
My tr3a reboot like every ten minutes when i am using it with the battery?
4. The motherboard could be defective & needs to be replaced.
Sep 10, 2010 | Sony PCG-TR3A Notebook
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
C530 battery door broken
battery door broken can you assist in my replacing the door or camera dummy
Jan 08, 2008 | Kodak EasyShare C315 Digital Camera
Broken battery compartment cover
The doors are about $20 on ebay. Heres a link for you:
http://cgi.ebay.com/KONICA-MINOLTA-Z6-BATTERY-DOOR-CAP-COVER-REPAIR-PART_W0QQitemZ170153738005QQihZ007QQcategoryZ64352QQrdZ1QQssPageNameZWD1VQQcmdZViewItem?_trksid=p1638.m118
Jan 03, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Kodak EasyShare C315 Digital Camera Logo
1,360 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
