Question about HP DeskJet 5652 InkJet Printer
Hp 5652 error code 905D0001 - HP DeskJet 5652 InkJet Printer
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
Hp deskjet 5652 not printing, orange light flashing continuously
1. Check to insure the cover is shut down completely.
2. If the "Ink Drop" Icon is blinking you are either out of ink, or there is a problem with the cartridge carrier. So open the cover - the carriage should move to the middle, if not it is bound up somewhere. Check the guides and around the carriage area for gummy labels etc..
3. If the carriage moves to the middle, release the ink cartridges and replace.
4. If the "Arrow" Icon is blinking, this could be a result of a paper feed error. Remove the paper from the tray, open the cover and insure no jams are in the rollers. Shuffle the paper lightly and place back in tray. Check to make sure the tray is pushed completely forward and then press the "Arrow" Icon button until a sheet is fed into the printer.
* * Note: When you are replacing the Ink cartridges and before you remove the tape from the bottom heads, give them a shake to lossen up the ink before installing.
This link will take route you to HP's support and more troubleshooting techniques for your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&lc=en&dlc=en&cc=us&product=304442&rule=35720&lang=en
Hope this helps..
God Bless.......
Jun 18, 2009 | HP DeskJet 5652 InkJet Printer
HP deskjet 5652
Well, one way is to just take the paper out when it tries, and when it gives you an error message tell it to abort the print. Another way is that the second it starts printing press the power button, or cancel button if it has it, that will tell the printer to stop printing.
Aug 02, 2007 | HP DeskJet 5652 InkJet Printer
HP DeskJet 5652 InkJet Printer Logo
459 people viewed this question
Seeker5211
Seeker5211
