Question about Cameras
I own a TOP torch/flashlight (LX6AK2). It stopped working after I dropped it once. I have replaced the batteries and tried everything I could think of - to no avail ...... I can only think that it must be the globe unit - Model L6X80. I live in Pretoria, South Africa and can find no supplier of this unit !! What can I do or who can I contact to get hold of this replacement unit ? sincerely, Dan Hugo. +27 82 8881 841
  • 490 Answers
SOURCE: z600
u need to unlock the phone software of z600...this can b done frm any care centre of sony.....then it will b solved and no further problems.
Posted on Oct 18, 2007
SOURCE: Maglite 3 D-cell Flashlight -- with D in front of Serial #
I ordered a replacement switch.
Posted on Aug 29, 2008
  • 3 Answers
SOURCE: Little orange plastic piece no longer holds battery down
Place folded thick papers on the side of battery, which will hold the battery down. works fine.
Posted on Nov 25, 2008
Joe Onley
  • 363 Answers
SOURCE: Please provide details of Pfaff agents in Pretoria
the only information i can find for you on SA Pfaff is a dealer, here are the particulars If you call them, they can instruct you better what to do :)
Joe
info@intersew.co.za
68, Voortrekker Street
321 3rd Floor Navada
New Redruth, Alberton
68, Voortrekker Street 321 - 3rd floor, Navada New Redruth ALBERTON
Posted on Aug 27, 2009
  • 1531 Answers
SOURCE: corner broken off Frigidaire FEC30S7EC glass counter top stove
the top off these units can be purchased but a more exact model number is need. i can get you a part number and a place to purchase it they run about 208.00 dollars plus taxes if applicable and shipping.just need exact model number for example ( FEF366ABA ) there are alot of different verisons.
Posted on Sep 19, 2009
How to disassemble a zoom focus flashlight
Ultrafire/CREE XML XM-L T6 LED 1600LM Flashlight Torch ...
? 27:39
https://www.youtube.com/watch?v=lsPdC-xgxTU
Oct 15, 2013 - Uploaded by Richard Lloyd
Here is a link to this CREE XML XM-L T6 LED 1600LM flashlightat ... 1600LM Flashlight Torch Lumen Zoomable Review/Disassembly/Mod.
CREE Flashlight - How to Fix Frequent Problems - YouTube
? 8:04
https://www.youtube.com/watch?v=zJpQAvum0bM
Dec 21, 2010 - Uploaded by motorbiking
How to repair your flashlight if the LED stops working, if it changes mo... ... Mini Cree Led Q5 Ultrafire Flashlight Torch Adjustable Focus Zoom ...
Disassemble HausBell CREE Flashlight (replace battery ...
Jan 19, 2016 | Cameras
Won't work after changing batteries
If the flashlight was working properly before you changed batteries, it's most likely that some tolerance is off by just a smidge so that you're not getting quite the right contact to close the circuit. You can make a thin wafer out of aluminum foil that's folded over and over onto itself and use that as a shim to increase pressure on the battery cartridge. That may be all you need.
If there is a switch on this light, as opposed to a simple screw on/screw off pressure connection, I would try checking continuity in the switch to make sure that is working correctly. Many manufacturers cut corners on the fit and construction of their flashlight swtiches, so a part can go out of alignment quickly and easily, causing failure of the switch until you can nudge those parts back in line.
Nov 25, 2012 | Leatherman Led Lenser L7 Flashlight
How come flashlights are called flashlights if they don't flash?
In the early days of flashlights, the battery life was very short. So if you needed to use a flashlight, you would turn in on only for a second and then shut it off. Hence, the term flash-light.
Jul 09, 2012 | Camping, Backpacking & Hiking
How to get the head off the makita Ml140 14.4 volt flashlight?
I'll assume it is the same as my similar 18v makita. There would be spring loaded posts that extend out of the main body into the torch head. these act as both contacts and axles for the rotation.
Remove the lens cover, the reflector, the bulb, and the bulb holder.
There should be a metal strip or wire going down the side to where the posts I mention enter. Shine a light down to see. once everything is out of the way, you can slide a narrow spoon handle (or knife or anything that fits) down the gap to push back the spring loaded posts. There may be channels in the plastic to help with this.
once you've got the post down, pull off the head.
I solved my flickering, by bypassing the circuit board, as all a torch need is a battery, a switch, and a bulb rated to match the battery (check your bulb to be sure)
here is a link to my previous solution, (with photos)
Check out this solution to the Makita 18V Lxt Lithium Ion Rechargeable...
Mar 24, 2012 | Makita ML140 144 Volt Flashlight
I had two maglite flashlights, 1 is a (2)D cell light and the other is a (3) D cell light . I went to replace the batteries and I can not get cap off the back ends of both. I think the batteries may have...
the batteries will only go out the bottom -- any attempt to remove the top pieces will most likely result in damage to the light itself. to help in the removal of the BOTTOM cap -- you can try and use a little heat from a propane torch ( not much ) and if you place the end cap into a vise you should be able to get both hands on the top part and give it a good twist. -- if the batteries are if fact corroded in there, get a 2x4 and place it on the gound and tap the flashlight down on it,, this may or may not shake them loose,, all just depends on how long they have been in there. good luck.
c...
Jan 01, 2011 | MagLite Mag-Lite& Flashlight
How do you change batteries stanley 3 in 1 tripod led flashlight
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
Dec 08, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
How do i open eveready dolphin torch for battery
You need to twist the black bulb end off in the direction of the arrow labeled open. The best way I found was to place the yellow end between my legs to hold it in place.
Sep 23, 2010 | Camping, Backpacking & Hiking
How do I open an Eveready Dolphin MINI torch for fitting batteries
twist the top of the torch, the model I had was with 2D batteries.
Aug 10, 2010 | Camping, Backpacking & Hiking
How do I get swelled and leaking battery's out? of my 4 D cell mag light, the one on the end came out but the next one is stuck. I tried a few drop of vinegar to neutralze and thin the alkalie goo,...
I found some info on this site...
http://cr4.globalspec.com/thread/14899/Leaking-battery-stuck-in-Mag-Lite#comment150608
"Sadly, when a dry cell leaks, the leaking chemicals react with the torch casing, as you have noted.
With all Maglite torches I have ever seen, you can remove both ends of the cylinder which encloses the batteries.
In this situation, get a broom handle or wooden dowel, just a bit smaller than the torch battery diameter, and after soaking the cylinder/switch assembly cylinder in hot water (boiling if you can) for an hour or two, give that inserted dowel a few taps with a large hammer or mallet.
Normally the leaking battery comes out easily, providing you let it soak in hot water long enough to soften the corrosion products.
Once you have gotten out that battery, leave cylinder soaking overnight, and use an old toothbrush to remove the last of the oxide etc , and allow to dry thoroughly.
As a tip for next time - to save you all this bother: Oil or grease the inside of the torch cylinder, and re-coat with oil (silicone grease is best), each time you replace batteries.....smiley-cool.gif"
hope this helps you.
Jan 19, 2010 | MagLite Camping, Backpacking & Hiking
Cameras Logo
220 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
