Question about HP PSC 2210 All-In-One InkJet Printer
Printer settings for port/path
For some reason I keep losing cababilities to print. APOLLO PROGRAM
Its set for LPT1 as the port but I cannot remember the path Help please
    Guru:
  • 731 Answers
Hai
1.Click on STart - >Control Panel ->Printers and faxes.
2.In the installed printer list if u see the HP printer ICON, check whether u see a small Check near the printer.
3.If there is no check mark on HP printer, right clcik the printer and click "set as Default printer".
4.Disconnect and reconnect the USB.
5.Restart the PC
Thanks
Riz
Posted on Jun 01, 2008
I have a retail store with 7 x Win 7 Workstations. i have 1 x Epson Tm-T88iii thermal receipt printer connected and installed on lpt1 port on my 1 workstation. We use a Dos application for our sales. The...
Hi, details below for creating a ersistent connection from LPT1: to you \\computer\\printername printer. Do the following on the other workstation that is not printing.
Use the net.exe command to establish a persistent connection.
To do this, use the following syntax at a command prompt:
net use lpt1 \\printserver\sharename /persistent:yes
where printserver is the print server that is sharing the printer, and where sharename is the name of the printer share.
For example, to map LPT1 to a printer shared as Laser1 on a print server that is named Pserver, follow these steps:
1. Click Start, and then click Run.
2. In the Open box, type cmd, and then click OK.
3. Type net use lpt1 \\pserver\laser1 /persistent:yes, and then press ENTER.
4. To quit the command prompt, type exit, and then press ENTER.
Note In Windows XP, non-administrative users cannot map an LPT port to a network printer path when the LPT port exists on the computer as a physical parallel port.
Apr 12, 2011 | Epson TM-T88III Thermal Printer
NOT PRINTING OUT OF DOS PROGRAM
The problem is, the DOS program tries to print to LPT1, which is your parallel port. We need to redirect this to your USB Port. First, you have to set up printer sharing: Go to Control Panel | Printers | Your printer and share the printer. Assuming that you share it with the share name "MYPRINTER" and the computer is called "MYCOMPUTER", then type go to Start | Run and type in: NET USE LPT1: \\MYCOMPUTER\MYPRINTER /PERSISTENT:YES That should do the trick, unless there's a driver problem, which is unlikely for a dot matrix printer. If that doesn't work, let me know and I can troubleshoot further.
Sep 09, 2007 | Panasonic KX-P2130 Matrix Printer
How to use HP Laserjet 2300 dn offline. This printer is a network printer
Thank you for contacting FixYa with your inquiry.
This printer can work very well via a standard printer cable directly connected to your computers LPT Terminal. Most of Microsoft's current Operating Systems already have the LaserJet J2300 drivers built in and will automatically install when connected.
To confirm your connection to go to your computers printer setup and ensure the driver is configured to print from LPT1 port and click on print a test page. (Start/Settings/Printers/LJ2300 - Right Click on properties then click on the tab for ports. The general tab should have a button to print test page)
The network card that comes with your printer (Jet Direct Card) will not be used with this method nor will the Ethernet cable be required.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Dec 14, 2010 | HP LaserJet 2300dn Printer
My printer refuses to print. The Red Status light came on so I checked and found there was a paper jam - cleared that. Can get green light to come on if I press the job cancel button but still cannot get...
Perform a Factory Reset
Turn the printer power switch OFF on the right side of the printer. Check that the front cover is closed.
Turn the printer power switch ON while holding down the GO button until the Toner, Drum, and Paper LEDs are lit.
Release the GO button. All LEDs will be off.
Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the Ready LED will be lit.
Print a Test Print Page
Print the Print Settings by pressing the GO button three times.
- If the Print Settings pages do not print, check for alarm lights on the printer. Clear the printer error before trying to print again.
- If the Print Settings pages print, the problem is isolated to printing from your computer. Verify the printer cable connects from the back of the computer directly to the printer. If the cable has become disconnected, loose, or connects through another device, the printer may not be able to print.
Check the Printer Driver Properties
Follow the instructions below based on the operating system installed on your computer.
Windows 7:
Click on the Windows icon => Control Panel => View Devices and Printers.
Right mouse click the Brother printer. Left click See What's Printing. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
Click Properties from this Printer menu list.
Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
Click the General tab and Print Test Page button. The Windows test page should now print.
- If the Windows test page prints, try printing from a program.
Windows Vista:
Click on the Windows icon => Control Panel => Printers or under Hardware and Sound click Printer.
Right mouse click the Brother printer. Select Run as administrator and left click Open. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Windows XP and 2000:
1. For Windows XP Professional, click on Start => Printers and Faxes.
For Windows XP Home Edition, click on Start => Control Panel =>Printers and other hardware => Printer and Faxes.
For Windows 2000, click Start => Settings => Printers.
2. Double-click the Brother printer to open the print queue. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
3. Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
4. Click Properties from this Printer menu list.
5. Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
6. Click the General tab and Print Test Page button. The Windows test page should now print.
Nov 01, 2010 | Brother HL-5240 Laser Printer
I want to print from a dos program set on lpt1 to a usb printer -how?
The information at this link should help http://www.dos2usb.com/download.htm Its a program that redirects your print jobs to a USB port.
May 02, 2009 | Computers & Internet
Reg. Installation of Apollo P-1200 Printer on Windows XP
This driver is provided by Microsoft and is included with the Windows XP os.
Installation instructions:
1: Click START, then click on PRINTERS & FAXES
2: Click on ADD A PRINTER
3: At Welcome screen click NEXT
4: Select LOCAL PRINTER (if printer is attached directly to computer) and click NEXT
5: Choose LPT1 (in most situations) or a different port if not LPT1 then click NEXT
6: Select Apollo in left window
7: Select Apollo P-1200 in right window
8: Click NEXT
9: Type name for printer or accept default name
10: Click No to "Do you want to print test page".
11: Click FINISH
12: Test printer by sending a print job to printer.
If you experience problems after installing this driver, please consultthe printer user manual for proper lpt bios settings. eg: spp, ecp,etc. and change the lpt pc bios settings to match manufacturer'ssuggested settings. quote.gif Jerry K View Public Profile Send a private message to Jerry K Find all posts by Jerry K reply.gif
Mar 04, 2008 | Pitney Bowes Hewlett Packard HRK-300 Black...
Printer not printing from computer
Hello:
To resolve this situation try the following:
1) re-install a driver. Goto HP.com and download a anew driver. COmpletly uninstall the old one.
2) Force your deskjet to run a self test...disconnect the cable from the PC...power off the unit...hold down the print button...turn unit back on.
3) try a new cable
4) Download a manual here
I hope you are up and printing soon.
Good luck to you my friend,
Seek PC Repair
Feb 10, 2008 | Compaq Presario 5000 PC Desktop
Printing,hp deskjet3420
Hi Malcom,
The HP3420 is connected to your PC through the USB port and not through the LPT1/parallel port.
You have to change the port setting. Go to Start, Printers, right click on HP3420, click on Properties, go to the Ports tab, check/select USB, OK.
Alternately, you may have to re-install the drivers for the HP3420 and allow the program to Search for the printer connection. Clicking on the button Stop Searching will auto install it again to LPT1.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 25, 2007 | Computers & Internet
Printing
Is the printer connected via USB or a printer cable to the LPT1 port? Make sure the Port setting in the properties of the printer are set to the correct port. If the printer is plugged into the USB port but the properties say it is on the LPT1 port. the cpmputer will think it is sending something to the printer but the printer doesnt know it.
Apr 03, 2007 | HP DeskJet 940cxi InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
14 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
