Question about Remington Health & Beauty
Battery in my Remington R720 is no longer holding its charge. How do I change the battery?
Helpful, thank you Roger. What you say applies to the R730i too. I found that I had to loosen the 3 screws under the shaver head so I could lift it up a bit to be able to get the beard trimmer out.
The tricky part was finding the exact spot to insert a screwdriver to remove the cover plate on the bottom. On the R730i, hold the shaver looking at the charging connector so the writing is the correct way up and the base looks like a pyramid with a domed top. Insert your screwdriver just to the left of top centre, near the edge of the silver trim that runs up the side of the case. If it were a clock face, it would be between 11 and 12. It isn't the silver trim you need to pry off but insert in the tiny gap in the blue plastic just under the trim.
Posted on Nov 22, 2015
They are a pig to change, but if you want to do it and you have the facilities and the patience, here's what you need to know:
You require 2 off AA cells with solder tags. The originals are 1600mAh and so you should obtain replacements of at least this capacity. I obtained 2000 mAh batteries.
There are four hidden screws which you need to access. At the base (where the charger plugs in) you need to remove the cover. Insert a thin screwdriver blade in the side furthest away from the connector (on the side of the base) just to one side of the centre. With luck the cover will pop off with no damage, but if you do damage it it really doesn't matter too much if it can't be refitted later. Beneath this are the first two hidden screws. Remove them. Then remove the trimmer - first open the shaver head and remove the cutter assembly by pulling it up from the pivot. Press the trimmer slide inner arms towards each other and disengage the pivots.The trimmer itself can then be removed by carefully unclipping it. Then squeeze together the arms from which you have just disconnected the trimmer and the whole grey/brown assembly will come out revealing two more screws, which should be removed.
The back will then come off revealing the batteries. You'll need a sharp craft knife to cut through the blob of silicone attached to both batteries, taking care not to damage the temperature sensor embedded in it and soldered into the circuit board underneath. Cut through the battery solder tags (the cut ends can be more easily removed when the batteries are out) and remove the batteries. The ends nearest the shaver base are joined together by a short wire which is likely to also be embedded in the silicone - you'll now be able to get this out for reuse. The batteries have plastic tape to provide insulation on the terminals but this can be easily removed at this stage.
Solder in the new batteries - the red wire from the circuit board to positive on one battery, the white wire to negative on the other one. Link together the positive and negative 'other ends' nearest to the base - the idea is to have two 1.2V cells in series to give 2.4V. Insulate the exposed battery terminals with insulating tape.
Replace the back after checking that the motor runs indicating you have no problems. Reassembly is more or less the reverse of disassembly, making sure that the back cover gasket is properly in place.
Note you do not need to get access to the top of the shaver - other than removing the cutter block. You should now be in business!
Final note on charging: initially charge until the case gets noticeably warm - probably around half an hour. Then use the shaver normally until it cuts out - probably long after '0' is shown in the display. Then recharge until '60' shows in the display. Stop charging at that point. Don't leave the shaver plugged in - overcharging is the problem and it will shorten battery life if you charge beyond the point where '60' shows. Although if you have used larger capacity cells than original you'll get more than an hour on a full charge, it's kinder to stop a bit short. It really does make a big difference.
Roger.
Posted on Sep 14, 2014
SOURCE: Remington R 9500 razor needs a battery
well this is what the problem is i need to know how my wiring goes at the top of the 76's
Posted on Jan 28, 2009
mcdevito75
  • 1970 Answers
SOURCE: How to change batteries?
mcdevito75 here, There are 2 versions of batteries in Norelco shavers 1 system is where the batteries are soldered to a circuit board in which case you"d have to replace the shaver or find an appliance repair shop in your area, The 2nd is where you can replace the batteries your self but, you;ll need a set od torx screwdrivers available at any auto parts store, refer to Norelco online at Norelco.com for Battery replacement. Look for these torx screws on the back cover or by lifting the shaver head .
Posted on Jun 23, 2010
brector3
  • 1600 Answers
SOURCE: Will no longer hold a charge and will not work
it is fixable but you can buy a replacement for less that the repair. See shaveroutlet.com. Link below
http://shaveroutlet.com/remington-mb40-beard-mustache-trimmer-factory-refurbished-p-161.html
Posted on Jul 12, 2010
brector3
  • 1600 Answers
SOURCE: The battery on my Remington
The charging system in your trimmer is not designed for lithium ion batteries. Installing a lithium ion battery could cause fire and/or personal injury. You should always use the same type battery that came in the shaver originally
Posted on Oct 08, 2010
brector3
  • 1600 Answers
SOURCE: I need replacement batteries for a Remington MB
You will find the correct battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Posted on Nov 22, 2010
Testimonial: "Just what the doctor ordered....Thanks"
What is wrong with my Remington sp-29 razor. It will not take a charge
Batteries might be bad, after a few years and many charges batteries will no longer hold a charge.
Feb 11, 2015 | Remington Health & Beauty
Battery not holding charge very long
I've written up a complete step-by-step tutorial on how to replace the battery on a Remington MB-300 Beard trimmer: John Fixes Stuff How to Replace the Batteries in Remington MB 300 Beard...
Apr 06, 2014 | Remington MB-300 Beard Trimmer
My remington model mb-70 type A is no longer holding charge. Can I purchase a battery for this model?
You can have the battery replaced This needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
http://www.remingtonproducts.com/ConsumerService/AuthorizedServiceDealers.aspx
If you are in another country, go to the top right of the screen, mouse over the Country and select your country. Look for a tab for the Authorized Service Dealer search function.
Feb 19, 2011 | Remington MB-70 Beard Trimmer
Razor from full charge reduces to circa 42 minutes then discharges as you switch it on.
The battery needs to be replaced. This is the normal symptom of a battery that can no longer hold a charge. Supply your model number and I can provide more details
Feb 07, 2011 | Remington Health & Beauty
The battery on my Remington MB70 trimmer is no longer hold a charge. Can the battery be changed to perhaps an Li-ion variety?
Oct 07, 2010 | Remington MB-70 Beard Trimmer
Jan 26, 2009 | Remington Titanium SmartSystem R-9500...
Health & Beauty Logo
936 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
