Question about Epson EMP-S3 Multimedia Projector
"release the operation lock",setting to unlock
Fuel door won't open on a 2008 g8 pontiac
Fuel Fill Door Description and Operation
The fuel door latch actuator shares the circuit with the driver door latch assembly. The body control module (BCM), upon receipt of a lock switch lock or unlock signal, will switch the appropriate door lock actuator, as well as a fuel filler door release actuator control circuits to battery positive voltage. The opposing side of the door lock and fuel filler door release actuators is connected to ground by the I/P fuse block through the other door lock actuator control circuit and the doors, along with the fuel filler door release, will lock or unlock as commanded.
Circuit/System Testing
  1. Ignition OFF, disconnect the harness connector at the fuel door release actuator.
  2. Test for less than 1 ohm between the control circuit terminal 1 and ground.
  3. ?‡'
    If greater than the specified range, test the control circuit for a short to voltage or an open/high resistance.
  4. Test for less than 1 ohm between the control circuit terminal 2 and ground.
  5. ?‡'
  6. Connect a test lamp between the control circuit terminal 1 and control circuit terminal 2.
  7. Ignition ON, command the doors to LOCK and UNLOCK by using the door lock switch. The test lamp should illuminate while commanding the LOCK and UNLOCK states.
  8. ?‡'
    If the test lamp remains OFF during either command, test either control circuit for a short to ground.
  9. If all circuits test normal, test or replace the fuel door release actuator.
Component Testing
  2. Install a 15A fused jumper wire between the control terminal 1 and 12V. Momentarily install a jumper wire between the control terminal 2 and ground. The fuel door release actuator should perform the LOCK/UNLOCK function.
  3. ?‡'
    If the function does not perform as specified, replace the fuel door release actuator.
  4. Reverse the jumper wires. The fuel door release actuator should perform the UNLOCK/LOCK function.
Remove the rear compartment side trim (right) panel. Refer to
Rear Compartment Side Trim Panel Replacement .
Apr 06, 2016 | Pontiac Cars & Trucks
My hatch won't release from the remote or the door switch. No solenoid sound at the hatch. How do I get it to open if it's not a bad fuse?
There are actually three relays , an there are controlled by the BCM - body control module !
When a door lock switch is activated in the lock or unlock position the BCM will receive a voltage signal on either the door lock switch lock or unlock signal circuits.
The BCM, upon receipt of a lock switch lock or unlock signal, will switch the appropriate lock relay control circuits to battery positive voltage. This will energize the appropriate lock or unlock relays. The relay will supply voltage to the door lock actuator lock or unlock control circuits to one side of the lock actuator. Since the opposing side of the lock actuators are connected to ground through the other lock actuator control circuit and the normally closed contacts of the lock or unlock relay, the doors and liftgate will then lock or unlock appropriately.
Three relays are used to operate the locks. DRV DR UNLCK relay, PASS DR UNLOCK and DR LCK relay. This is done to isolate the driver door lock actuator so it can be unlocked by itself using the keyless entry transmitter.
Rear Hatch/Gate Description and Operation
The liftgate can be opened by operating the switch on the instrument panel. Battery voltage is supplied to the liftgate actuator through the body control module (BCM). The BCM will pulse the liftgate actuator when a release input is received through the key fob, or the instrument panel switch.
Door/Lift gate Latch Assembly
  1. Install a 20-A fused jumper wire between the control terminal 3 and 12 volts. Install a jumper wire between the ground terminal 2 and ground.
  2. Verify the actuator turns on & off.
If the function does not perform as specified, replace the applicable door latch.
Oct 01, 2015 | 2006 Pontiac Torrent
Cannot unlock my husbands tsa lock we are in argentina
To set/reset combination on TSA Cable Lock
TSA Cable Locks come preset from the factory to 0-0-0. Set the combination to 0-0-0 or your already chosen combination. if different than 0-0-0. To set the combination, use a pointed device such as a pen to press in on B. While pressing on B (do not release B until combination is set), pick your 3 digit combination.
Once all 3 dials are set to the combination you want, release B. Your TSA Cable lock Is now set to your combination. TSA Lock will NOT be locked at this new combination - turn one or more dials and your lock will be locked. To unlock, follow instructions above.
Please make sure to remember your combination!
You can also use the video below:
http://www.youtube.com/watch?v=OfchUwkEckI
Good luck..
Aug 26, 2011 | Locks & Locksmithing
I cannot hear any sound out of my Polaroid TDX-01930B television.
Hello
First make sure that the "Mute" function is OFF. If it is set to "ON", no volume will be there.
Your TV has a volume lock function included [Global Volume Lock].
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
May 06, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
I locked out the phone and do not remember my password
Before you get all hairy about the answer, remember that you have asked the question in a PUBLIC forum. If you get step-by-step instructions, everybody will be able to hack a locked phone in a Panasonic system and FixYa has a pretty good hit ratio in a search engine.
The feature you have activated is probably electronic station lock. It's set by 77 xxxx xxxx #. The xxxx is a 4 digit password that you key in twice. You unlock the set by dialing 77 xxxx , the password you used to lock it.
However, the operator can lock and release each extension from the console. The instructions are in the system OM (operating manual or user guide). In fact, an operator locked station can't do anything.
Carl
Jan 08, 2011 | Panasonic KX-T7030 Corded Phone
How to program key fob. I have the fobs.
Transmitter Programming Procedure
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on the transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of the transmitter.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation.
Good luck
Jun 25, 2009 | 2002 Chevrolet Tahoe
PROGRAMING ALARM REMOTE ON 95 TAHOE
Here it is straight from Alldata:
  1. Ground pin G of the Data Link Connector (DLC).**Bottom left pin**
    • Receiver will respond by locking, and unlocking doors within 2 seconds.
  1. Press any button of the first transmitter to be programmed.
  2. The control module will respond by locking/unlocking doors and activating rear window release.
  3. Press any button of the second transmitter to be programmed (if used).
  4. The control module will respond by locking/unlocking doors and activating the rear window release.
    1. Remove the ground applied to the reprogrammed connector.
      1. Transmitter operation is verified locking and unlocking the doors and activating the rear window release
Dec 23, 2008 | 2007 Chevrolet Malibu SS Sedan New Cars
How can i program the key less?
  1. Close all the vehicle doors.
  2. Insert the ignition key into the ignition lock cylinder.
  3. Press and hold the DOOR unlock switch.
  4. While holding the DOOR lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
  5. Release the DOOR unlock switch. The doors will lock and unlock to confirm the program mode.
  6. Press and hold the LOCK button and the UNLOCK button simultaneously on one keyless remote. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
  7. Repeat the previous step to program up to four transmitters.
  8. Turn the ignition switch to the RUN (one more click forward) position in order to exit the keyless entry transmitter mode.
  9. Operate the transmitter functions in order to verify correct system operation.
Dec 03, 2008 | 1999 Chevrolet Astro
Fuel Filler Cover lock
You may have too much lock cover pressure on the release pin did you load test the release motor by putting your finger on it and see how much pressure it can push?not too much pressure though.Sorry earlier comment sent to wrong place
Oct 18, 2008 | 2003 Volvo XC90
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
Mar 15, 2008 | Polaroid FLM-2632 Television
Epson EMP-S3 Multimedia Projector Logo
513 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
