Question about Canon EOS 30D Body Only Digital Camera
Turn Camera on however, will not auto focus or manual focus veiwfinder is very dark to look through
  • 10,515 Answers
his model has had problems associated with internal focal lens and focus drive motor.Optical unit(lens assembly) will most likely be in need of replacement and alignment.
First off,I will suggest to reset the camera to factory settings.This will insure that you are not in a manual focus mode and allow all auto functions.If problem still exists,I will suspect that service and lens replacement will be needed.The most cost effective repair route will be to contact mfg for a repair estimate,if warranty does not apply.I do feel that repair on this model should be economical.Contact Canon factory service at 1-800-OKCANON.
If you want to get it repaired from a 3rd party at a substantially lower cost, you could consider :-
http://www.teleplancamerarepair.com/Canon_EOS_30D
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 08, 2010
Rewind sound when switched from auto focus to manual focus
Probably a problem with the af/m switch so that even though switching to manual moves the connector out of the way (pulls it into the mount) the af motor continues to run. Remover the bottom and then the front cover and check the switch.
Jan 23, 2014 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Digital camera won't focus
I see your camera has a focus area. If you have a subject with enough contrasting parts in this area, the focusing should work fine.
You must know that not every subject can be focused on as quick or as good as you would like. If there are little contrasting lines in the subject, or when it is getting dark or there are dark and light parts in the focus area, that don't belong together, every camera can have problems to focus correct. Changing the ISO settings won't change anything for the auto focus.
But special when you try to shoot in almost dark places, you camera will have lots of work to focus and in most cases it won't work at all.
You could try to place an object with light and dark lines, on the same distance as the object you want to picture. Then by pressing the shutter half, when focusing on the object with much contrast, you can look if the camera can focus. If it is in focus, keep the shutter pressed half way down, while moving to the object you want to shoot a picture of. Once you have every thing in the frame as you want it, press the shutter complete.
Dec 27, 2013 | Vivitar Vivicam 5388 Digital Camera
My Canon Rebel XS will not auto focus correctly. It sounds like it is trying to focus, but only flashes and will not focus or take the picture.
Those quick fast flashes usually mean the camera is trying to find contrast to take the photo but it can't. The scene might be to dark and the camera can not set it's focus and there for cannot take a picture. Move the camera slightly from left to right on the subject and see if it can manage to set focus. It's normal for the camera to give out these quick flashes as it is trying to find some sort of contrast in the subject, turning on a room light might help this?
Now when you manually focus, then the camera does not have to use it's built in auto focus sensor and will let you take a photo when you manually focus on the subject.
Sep 30, 2012 | Canon Rebel XS / Eos 1000D Digital Camera...
How and When to use AUTO FOCUS and MANUAL FOCUS of my contax t2 camera?
There are no rules or conventions for this. It is totally up to you to chose which method to use.
Sometimes when taking images in close up where a leaf or stalk may invoke autofocus to lock onto the wrong object to get a clear pic, then select manual so your subject is in focus
Depth Of Field is also associated with focusing, autofocus does not always deal well ith DOF situations. It might be better for you to get a simple book on digital photography to help you understand how to get the best results from your camera
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Contax T2 35mm Point and Shoot Camera
Lens will not auto focus with flash up
Not sure of you camera model, but the flash will fire momentarily when you try to focus indoors as there is not enough light for the auto focus to work. This is so the camera can determine a distance from the subject to the camera. This is called focus assist (ref to your manual). It will work outdoors as there is enough light and contrast for the focus to work.
Kit lenses included with the camera are notoriously known not to focus well in dark conditions.
Oct 11, 2009 | Nikon D60 Digital Camera
Camera xsi rebel 12.5 megapixel won't focus with
Most entry level SLR cameras will struggle to focus in low light, especially with the kit lens. By rights the flash should popup and emit a flash pulse to help focus. This is called focus assist. You might have to consult the manual to check if this function is turned on or not.
Oct 09, 2009 | Canon EOS Rebel XSi Digital Camera
It seems that in darker situations the camera won't focus
there has to be enough light for the camera to see what to focus on .. the sound you hear may be the camera trying to focus .. in some cameras you can increase the ISO setting to allow it to work in reduced light .. i sometimes use a small led flashlight at close range to get enough light in dark situations .. you can also go to manual focus .. your camera might have a laser or LED light built in to assist in auto focus .. you have to go to the proper menu and turn that on ..
here is some good specific tricks and info on your camera
http://www.kenrockwell.com/nikon/d40/users-guide/index.htm
Aug 20, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Quantaray 70-300
Sounds like the aperture inside the lens is broken. You shuld send it in for service.
Aug 07, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
My d40 has a image in viewfinder, will not take picture.
What lens are you using with the D40? Is it an AF-S lens? And is the Mirror Lockup on? Chech the Custom Settings menu. If mirror lockup is on, turn it off.
Feb 14, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Veiw finder(eye piece ) out of focus pictures are fine
Use the diopter adjustment to refocus the viewfinder to your eye.
Point the camera at a sign or something with writing on and half press the shutter button to focus then move the little adjuster at the top right of the viewfinder until the image in the veiwfinder is in focus
Jun 22, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 30D Body Only Digital Camera Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
