Question about Parrot 3200 Ls Color Handsfree Bluetooth Car Kit
I have a Parrot 32 LS-Color which has been connected to my Blackberry Storm. I had to replace my car's battery recently and since then the Parrot isnt working the same as before. I think it is succeeding in connecting to the network but the display is now showing "call" all the time, and won't disconnect the phantom "call" when i depress the red button. It keeps making an intermittent "ringing" tone every few seconds (via the speaker system in the car) but it rings maybe twice, then pauses a few seconds and then does it again. I end up having to disconnect as it is interfering with the Kenwood stereo as well! Can I reset the Parrot unit without having to re-sync my phone to it? I've consulted the manual, but there is nothing in there to cover this kind of problem. The unit was in the car when i purchased it last year, so I didn't install it myself, and a friend updated it for me to sync my Blackberry to it, so I'm not sure what I do next. Any input would be appreciated please.
SOURCE: 3200 LS installed in '07 Chev Sub-Parrot Won't Power Off
try switching the red and orange wires. one is constant and one is switched. you can try by just reversing them at the inline fuses. hope this helps.
Posted on Jan 03, 2009
driveallnigh
  • 89 Answers
SOURCE: ANSWERING CALLS
Check to see that it isn't set to "call forwarding".
Posted on Feb 26, 2009
dancandoit
  • 436 Answers
SOURCE: My Parrot Ck3200 Ls has worked fine for the past
You will need to disconnect power from the main control box. this will reset the unit. you will need to check the power is wired correct as incorrect power will cause this fault. best take it to an engineer.
Posted on Oct 10, 2009
SOURCE: Problem updating Parrot LS-GPS
The Parrot manual states that the software update can be conducted via bluetooth (BT). I've managed to get BT connectivity both the laptop recognising the Parrot as a headset, and indeed it cts a PC speaker in the mode, and also from the Parrot linking to the laptop. But wehn using the Parrot Software update tool, and attempting to connect via BT, non of the displayed COM channels work. Authentication fails. The laptopn connection also only stays up for about a minute. Confusingly the Parrot also offers an update item in one of its menues, and supplies a 4 digit passowrd, but I can't see how this can be used. Any ideas?
Posted on Dec 25, 2009
  • 95 Answers
SOURCE: updating my parrot 3400 ls
You can make the proceed using Bluetooth dongle and a laptop or a bluetooth included to the laptop.
Just make a look:
http://www.parrot.com/uk/support/downloads/#software
Posted on Mar 26, 2010
Recently I replaced the battery on the steering control part of my parrot kit and it worked well for two months but now I have a blank screen on the visual display. What would have caused this ?
It sounds like the kit has had a software freeze, you will need to remove power from the Parrot Blue box and replace, if this works then I would also perform a software update.
Nov 26, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
How do i pair my blackberry with parrot 3200 ls, asking for numeric key
The first time that you switch on the 3200 LS-Color, you must pair your mobile phone with the kit.
1.Enable the Bluetooth mode on your phone.
2.On the hands-free kit, scroll through the menus until you come to Settings Pair with phone and select the relevant option for your phone. A 4-digit PIN code then appears on screen. Memorize it.
3.Then from mobile serach the 3200 LS-Color device
Once the search has finished, "Parrot 3200LS / Parrot 3400LS" is displayed on your phone.
4.Select the kit. Your phone prompts you to enter a code: key in the code shown on the kit screen and confirm on your phone.
5.The kit's screen displays "Pairing".
6.Once the data has been exchanged, "pairing successful" appears on the 3200 LS-Color.
Thank You
Oct 08, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Problem transferring contact list from BB 8330 to Parrot 3200 LS
I had the same issue with my Nokia phone a long time ago. To solve that issue I had to upgrade the Parrot's firmware with the laptop through bluetooth connection while in the car. I have done this a few times to get the most out of my parrot.
I recently got a Blackberry and had no issues with the contacts whatsoever. I do have to say that I dont have 500 contacts, but only 130.
If I were you I would try to update the Parrots firmware to the latest one available in the parrots website.
I am not sure if the parrots has a maximum contacts restriction. That might be also your problem.
Hope it helped.
Nov 26, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
My Parrot Ck3200 Ls has worked fine for the past few months but it recently has frozen with the message "shutting down" displayed on screen. The unit does not power down, even when the engine in the car is...
Sep 30, 2009 | Parrot Ck3200 Ls - Color Cell Interface...
Dec 27, 2008 | Parrot 3200 Ls Color Handsfree Bluetooth...
Blackberry voice signal problem
I recently found out all you have to do is reset the blackberry. Remove the battery and let it re boot. Problem resolved.
Aug 11, 2008 | Parrot Ck3200ls Lcd Color Display For...
Parrot 3200 Ls Color Handsfree Bluetooth Car Kit Logo
119 people viewed this question
Top Parrot Cell Phones Experts
Andrew Wright
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
