Question about Linksys SPA922 IP Phone
SPA 922 showing "SOS failure phone in recovery mode"\r\nIt is not showing the IP address also to upgrade firmware
2 Suggested Answers
TechyDrood
  • 2072 Answers
SOURCE: i have Linksys spa-942 phone. its display not
Easiest way to troubleshoot this would be with a second phone. Plug another phone into the line, if the phone works then you know the problem is with the original phone. If the other test phone isn't working then it would be either the cable running from the phone to the wall, the wall jack, cable running from wall jack to the PBX or VoIP modem.
Comment back if you need further assistance.
Posted on Aug 18, 2011
How can I reset SPA to factory default?
I'm not sure about the 922, but other SPA phones can be reset without an admin password: hit the menu button, press 14 on the keypad, and OK the reset.
Apr 16, 2015 | Linksys SPA922 IP Phone
I cant test my 7941g because i keep getting a small bullseye on the bottom left corner of the screen
Your phone is trying to connect to a TFTP server address to download a firmware and/or config file update. You need to figure out what IP address it is trying to connect to (You may have to use wireshark or another packet sniffer to determine this).
Once you know the IP it is trying to connect to, you'll need to set up a small network with a TFTP server running on that same address, and feed the phone a firmware update and/or config file. It will likely not fully boot unless it gets a firmware update.
Cisco Phone 48V Power Supply
Dec 05, 2012 | Cisco 7941G IP Phone
Cisco SPA504G Firmware update issue
You need to make sure that your laptop and IP phone are on the same network subnet. For instance, if you IP phone's IP address is 192.168.2.24 than your laptop must be on the same network addressing scheme, such as 192.168.2.23.
<a href="http://www.ciscopowercube.com">Cisco CP-PWR-CUBE3</a>
Sep 07, 2012 | Cisco SPA504G IP Phone
My Cisco IP Phone 7945G keeps rebooting after I did a factory reset. Is there a way to fix this?
According to Cisco, when initiating a factory reset procedure certain information from the IP phone is erased while other information is reset to the factory default value, as shown in the list below:
Information Erased:
  • CTL File (Certificate Trust List)
  • LSC File (Locally Significant Certificate)
  • IP Phone Call History (Calls Received, Placed, Missed etc)
  • Phone application
Information Reset to Default:
  • User configuration settings (ring tone, screen brightness, sound levels etc)
  • Network configuration settings
t is highly advisable to follow the firmware upgrade procedure in a non-working environment to ensure other phones are not affected (in case of an accidental reboot), and to avoid the freshly factory reset ip phones obtaining the working environment's settings.
Please use the link below and follow the instruction http://www.firewall.cx/downloads/cisco-tools-a-applications/cisco-ip-phone-a-ata-firmware-downloads.html
Aug 28, 2012 | Cisco 7945G IP Phone
WRT300N: does not boot, all leds are lit
Solution 1.
How can I reset the Linksys WRT300N to factory defaults?
Hold the Reset button on the Linksys WRT300N for about 30 seconds.
What is the IP Address, Username and Password to log in to the WRT300N?
IP Address: 192.168.1.1
Username: none
Password: admin
You should also know the configuration of your ISP provider after reset. You'll need to re configure your connection from modem to router.
Solution 2
How do I upgrade the Firmware on the Linksys WRT300N?
# 192.168.1.1 -> Administration tab -> Firmware Upgrade sub-tab. Click "Browse" and browse to the firmware upgrade file on your computer. Click "Start to Upgrade". Do not reset or power cycle unit while it is upgrading.
Username: none
Password: admin
Apr 10, 2011 | Linksys WRT300N Wireless Router
Looking 4 a TFTP server for upgrades
There must be a tftp server on your network, that must have files on the server that are needed top upgrade the firmware. Ask your admin, as they will have the IP address. I can refer you to a tftp program you can install on a server, if need be.
May 27, 2009 | Hitachi IP-3000 IP Wireless Phone
I have to power cycle modem as I keep loosing IP address
Depending on the internet provider, most IP addresses are set for a certain amount of time before the lease on them is up, in most cases the modem automatically renews the lease and the modem keeps the same IP address. In some cases, when the lease expires, the modem receives a new IP address from your ISP's dhcp server. In rare cases, the modem does not receive an IP address due to either a failure in the hardware (of the modem, hence faulty modem, time to replace) or the firmware on the modem needs to be upgraded. To upgrade the firm ware on the modem, a call to your ISP's tech support should solve that.
Mar 24, 2009 | Cnet CWR-905 Wireless-N Router
Power light keeps blinking and cannot log into WPN824 router
Firmware upgrade is very important. You have to make sure that you were able to do it properly.
You have to do a hard reset on the router. Press and hold the reset button for 30 seconds while the router is turned on. Try to see if your computer is able to get a valid IP address. If not, set up a static IP address on the computer and see if you can ping the router, if not then the router has gone bad.
You have to replace it.
Feb 10, 2009 | NetGear RangeMax WPN824 Router
Information About Management Mode for Firmware Recovery
What is Management Mode? If you encounter an irrecoverable condition with the WRT54G v5, you can use Management Mode to recover the router by uploading a new firmware image. In Management Mode, the router will have just enough functionality to load a newer firmware. You should be able to recover the router is most situations. When will the WRT54G v5 enter Management Mode? The WRT54G v5 will enter Management Mode when: * The router's firmware is corrupt (for example, when the router's Power light is blinking), OR * When the router has been reset incorrectly using the following steps: 1. Unplug the power cord. 2. Press and hold the Reset button. 3. Plug power cord back in (Reset button still held in). 4. Wait about 5-10 seconds. How do I get out of Management Mode? * To get out of Management Mode, simply unplug the power cord from the back or router for ten (10) seconds and plug the power cord back in (without using the Reset button). If the router's firmware is complete and without error, the router will start up normally. If the above does not work, try: * Download a local copy of WRT54G Version 5 firmware that you can use for recovery. Visit http://www.linksys.com/download to download the latest firmware. After unzipping and extracting the firmware file, click on the Browse button from the Management Mode page, select the firmware file, and upgrade the firmware. After this, Reset the router normally (by holding in the Reset button for 10 seconds) and the router should exit Management Mode. How do I enter Management Mode manually to recover my router? NOTES: * The PC that will be used for the recovery MUST be connected to the router via a hardwired Ethernet cable and not a wirelessly connected computer. * Be sure that you have a local copy of WRT54G Version 5 firmware that you can use for recovery. Visit http://www.linksys.com/download to download the latest firmware. * In most cases, the router will be able to provide an IP address via DHCP when in Management Mode. If your PC does not automatically receive an IP address from the router, you will have to set up a static IP address for the upgrade. See Answer ID 534 for more information. * When the router is forced into Management Mode, the Power light will blink. 1. Unplug the power cord from the back of the router. 2. Hold down the Reset button. 3. While holding down the Reset button, plug back in the power cord to the router. 4. Continue to hold the Reset button for five (5) seconds. After five (5) seconds, release the button. 5. Wait for about one (1) minute. Then, on a computer connected to the router, launch a web browser (for example, Internet Explorer or Mozilla Firefox). 6. Type in the router's IP address of http://192.168.1.1 into the Address field and press the [Enter] key. 7. The Management Mode - Firmware Upgrade interface should appear. NOTE: If you accidentally enter into Management Mode, you can exit by simply unplugging the power cord from the router and by plugging it back in. 8. Click Browse and locate the firmware file. 9. Click Apply to start the firmware upgrade process. 10.Once the firmware upgrade process has successfully completed, an "Upgrade Success" message will appear to confirm that the upgrade has ended. 11. Unplug the power cord from the back of the router and plug it back in -- this will restart your router using the new firmware.
Feb 16, 2006 | Linksys (WRT54GC) Router
Linksys SPA922 IP Phone Logo
840 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
