Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Coffee maker RIVAL MODLE CM800
By bosser on May 29, 2008
Will not make coffee does not heat at all. lights for no and off work clock & programmer OK
Same Problem
May 10, 2009
-   Mr. Coffee ECM21 E & C Maker, 6 months old, used occasionally yet 'mysteriously stops brewing on the "Coffee" side.
Exterior Dials appear to work fine and light as they should, the Espresso side works fine, however, as I side above the coffee pot side neither brews nor does the plate heat. Opened it up to find a part attached to the plate with detachable wires EXTREMELY blackened, corroded or possibly shorted out. I have been hunting for a manual for two weeks to identify this component attached to the plate without any luck. -   SF_Mvandyke
Best Solution
posted on Jun 02, 2008
Helpful)
Bob from LI
Rank: Guru
Rating: 85%, 737 votes
Several possibilities:
  • bad thermostat
  • bad timer
  • bad element
You can check all the items except the timer (if electronic) by disassembling the unit and using a multimeter. The thermostat is a black button about 12 mm (1/2 inch) in diameter with two wires. The heater is usually part of a casting and has connectors on it. Also, cycle all connectors to defeat corrosion.
Was this helpful?
Yes
No
Solution #2
posted on Aug 17, 2009
Not Rated)
ReldvS
Rank: Guide
Rating: 92%, 4 votes
Mine did this too, check for a hidden Zehner Diode. Mine came inline before the heating element. I thought it was the thermostat or the element but turned out that the diode failed and i was able to bypass it for a sec, and i mean literally a sec, and turn on the mach. Heating element heated right up, which is all i wanted to see. Looks like once i determine the value of the diode, i should be able to replace it and coffee maker will most likely be fine again. :) I think i can read the numbers, and it looks like 1250v 10A for mine, you should examine the casing of diode closely and you may find numbers on it.
Comments:
Aug 17, 2009
- Wrong value on Zener Diode. looks more like 10a 250V....hard to read LOL
Aug 17, 2009
- May also be called the Thermal Fuse.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
which style of the bodum french press' is best, the chombard, brazil, or kenya?
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
mr coffee modelDRX20 Hot Plate bracket broke (plastic cracked) hot plate fell down
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
