Question about Vacuums
I just purchased a deni 3500 to processe my deer meat. i stuff the 1 lb. game bags with sausage. to my supprize this machine is a #5 grinding head. where can i find a 2 in. stuffing tube to fit this grinder so that i will be able to stuff these bags ??
  • 10,865 Answers
Hello. Here is the link to the parts you seek. http://www.thegourmetdepotco.com/store/store_manufacturer.asp?manufacturer=93
Joe
Posted on Oct 08, 2010
My 1 month old Oreck upright is not sucking in anymore. Worked fine for about 3 weeks. Now it just seems to push stuff around. I'm not sure if it is the bags? Ordered what I was told to order.
The intake tube could very well be clogged. Its pretty simple to disassemble. This happens commonly on Oreck, all you need is for something stiff to get lodged sideways in the tube then everything builds up around it.
Nov 28, 2015 | Oreck Vacuums
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
Miele not sucking
1. Check if the bag is full. Yes. Change bag.
2. Check the head. Clean head.
3. Object stuck in the hose. remove hose from the vacuum. Remove extensions from the Head end. Poke garden hose down the hose from the handle end.
4. If all else fails. Read the destructions.
Jul 05, 2014 | Miele S318 Bagged Canister Vacuum
Motor making grinding noise and burning smell
A bit too late I fear. There is either grit from an overloaded dust bag in the motor or the brushes have worn out. Spares and not expensive.
Jun 10, 2017 | Hoover H3044 FloorMate Hard Floor Cleaner
How long to cook chicken sausage on the George foreman
this depends on how thick the sausages are. For sausages that are about 1 - 1 1/2 inches thick it will take about 10-15 minutes. the best way to tell if a sausage is done (chicken or pork) is to insert a meat thermometer into the end of the sausage about 3 inches deep. When the meat is done it will read 160 deg F.
May 03, 2011 | Vacuums
How to stuff ground meat into sausage casings using a Moulinex meat grinder?
There ia a special fitting that is used for sausage making. It is a tube with a flange on it that should clamp onto the ground meat outlet. Check with your local agent.
Feb 26, 2011 | Vacuums
What kind of bag for the epic series 3500 sr
"U" (upright) style bags, available at any Aerus Electrolux store, or from their consultants. These are the genuine bags made only by Home Solutions. Generic bags WILL decrease the lifespan of the motor.
Contact your local dealer. Free home delivery.
http://www.aerushome.com/storelocator/
Nov 15, 2010 | Electrolux Epic 3500 Vacuum
I would like to know how i get the very bottom piece off my vacuum off so I can put a new fidder hose on it? The hose is black and it is only about six inches long. its lacation is on the very end of the...
You don't have to take the vacuum apart.
Assuming this is an Epic 3500 or similar upright Electrolux:
1. Lay vacuum on it's side.
2. Gently pull hose from power head. It's not screwed in so that should be easy.
3. Unscrew it from the upper portion of the machine by turning the hose clockwise. Turning counterclockwise tightens it.
4. Remove it.
5. Screw one end into upper portion of vacuum by turning counterclockwise.
6. Insert other end of hose into opening in power nozzle. Some manipulating may be necessary for proper fit, but this is all that's needed.
Sep 22, 2010 | Electrolux Epic 3500 Vacuum
Kirby Sentria doesn't pick up visible dirt
As far as picking up - I suspect that your belt is not properly installed. Watch the video manual HERE. in the first halve of the video there is an instruction how to properly instal nozzle.
You have to turn the bag about 30-40 degrees countercloclwise so plastic protrusions on the tube top adater (ones that keep bag attached to the tube) will allign with cuts in bag cardbort so you can pull the bag off the adapter. If you will take a look at the new bag - you will see what I am talking about.
Dec 08, 2008 | Kirby G6 Bagged Upright Vacuum
Electrolux 6500 can't open canister
This is what I used to open my vac... Note - the white plastic strips under the bumper clips into the case at the front end (to help these instructions, you may also want to put a thin flat blade screw driver between the white plastic strip and the case, @ the inboard most point)...
If you want to open the machine, the two bumpers on either side, that say ELECTROUX hold the egg shell together. This is the process....
1. remove the bag, leave the bag cover open
2. lay the vacuum on its side on the floor with the bag cover to your right hand side.
3. place screw driver blade flat against the bumper on the opposite end from the bag cover, near the cordwinder cover, strike the screw driver firmly with a hammer, this will unlock the bumper and it will slide off toward the bag end of the machine.
4. turn the vacuum onto the other side, and follow the same process.
5. after both bumpers are removed you can get into the vacuum.
http://www.howtomendit.com/answers.php?id=57063
Aug 30, 2007 | Electrolux Epic 6500 Vacuum
Vacuums Logo
47 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
