Question about Acer (99.N5982.21D) for Aspire 5100 Keyboard
My keyboard,usb,and touchpad dont work.even f2 in to bios.help!!!!!!!!!!!.how to ubgrade my bios
  • 2,574 Answers
Have a dell latitude D620 that is password protected in such a way as to prevent even the F2 and F12 keys to function. Can you supply a way around this please
You may have a USB keyboard that is not recognized by the BIOS on powerup, but is later recognized by Windows when that starts running. Try connecting a keyboard with a PS2 connector, enter F2 on startup and set the BIOS to enable USB devices in BIOS. If this still doesn't work, then keep a PS2 keyboard around in case you ever need to activate F2 or F12.
Oct 24, 2013 | System Integration Business 160gb for Dell...
New system. Cannot enter bios with F2 key, apparently keyboard is not working, but works well in another computer. I tried bios switches 1_2 default and 2_3. With 1_2 it goes directly to PXE_E61 error,...
hallo there, tried the DEL key? (instead of the F2, some Bios of them use older input for F2, DEL sends same key. )
Also, please count how many short, how many long beeps mopbo gives when booting.
Also: try to connect with PS2 keyboard. Possible no correct keyboard connection or even worse, when its a wireless keyboard need tyo pair keyboard with receiver first.
Also possible: is the keyboard not IBM compatible?
As said: try first to use default PS2 keyboard, theyre cheap and most of the times problem is directly solved.
If that does not solve your problem, count the beep codes and tell us please, could be some other problem, ( wrong memory, memory not placed correct, voltage problems etc etc etc)
the bios codes would help us to help you fasst.
Greetings
Ganimidis
Mar 13, 2011 | Intel DP45SG Motherboard
Hi people! here is one for you-anyone have a clue how to redo windows on a notebook, without a working keyboard or touchpad? the keyboard controller failed 2 years ago-I came up with a work around 2 have a...
power off ur pc disconect power adapter re conect
conect ur usb keyboard hit power button press F2 to inter Bios see there is usb keyboard support enable.
save & exit id could be work..
Jan 31, 2010 | Acer Aspire 5100 Notebook
Aspire 5100 Kepad and touchpad not working
have k/b and touch pad been disabled in BIOS?
Oct 30, 2008 | Acer Aspire 5100 Notebook
Touch pad possessed.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
For extra USB ports, purchase a USB hub($15 -$20). That way you can add at least 4 USB ports to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite touchpad & keyboard stopped working
As I understand your keyboard is now working and your usb mouse. But the touchpad does not work.
Have you or someone opened up your laptop recently? If so it is possible the touchpad was not connected properly.
Can you please post the exact name of your laptop. I'll see what else I can figure out for you.
Oct 03, 2008 | Computers & Internet
Touchpad and keypad problem
if it does'nt work at all, use a usb mouse to do this proceedure.
Go to my computer, right click>properties>hardware tab>device manager, then look down the list for mice and pointing devices, click the '+' sign and right click on your touchpad and select uninstall, do the same on the keyboard line and then restart the pc, remove usb mouse.
Both touchpad and keyboard will be reinstalled and then ready to use again
Sep 08, 2008 | Acer Aspire 5101WLMi Notebook
Acer Aspire 3004 keyboard and touchpad error
Just resolved same problem on Acer Aspire 5000 by removing the battery, then goto device manager and disable "Microsoft ACPI-Compliant Control Method Battery" you can then put your existing battery back into the latop with any problems with the keyboard and touchpad. Mad solution I know but it worked for me
Jan 22, 2008 | Acer Aspire 3000 Notebook
Acer (99.N5982.21D) for Aspire 5100 Keyboard Logo
165 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
