Question about Cell Phones
Not chargeing . and without pulging charger it coming not chargeing .
  • 358 Answers
Hi, when a phone does not charge, it is usually a charger fault. When a charger get's damaged it does not allow the phone to charge.
When you replace the charger, problem solved.
Take care.
Posted on Oct 08, 2010
My tablets charger isn't charging my tablet
Hello, Make sure the plugin has electric. Change power cord and let charge. First you might try taking out the battery on the tablet and let set for at least 2 mins. and put back in. If neither works then you will have to call the customer support of the manufacturer and walk thru their trouble shooting procedures.
May 19, 2014 | Audio Players & Recorders
Studio 1737 wont recognize charger
Step 1:
If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Feb 15, 2013 | Dell Studio Computers & Internet
I just bought a 339 Metal series r/c helicopter and I haven't even used it yet because when I pulgged the charger from the remote up the LED lights would not come on... So I don't know If its...
Leave it on the charger for an hour. The lights can be turned on and off from the remote control. After an hour go through the start up procedure in the instructions.
Dec 25, 2012 | Toys
I had my digilife ddv-1100 for approximately three years and It no longer charges. If I pulg the usb in the light comes on but as soon as I disconnect it it goes right back off. What could be the problem?...
Almost certainly the battery. They don't last forever.
MY DigiLife DDV 7000 uses an NP-60 battery. I found some of these on Amazon by searching for "np-60", and paid about $1.50 each. You can also sometimes find batteries by searching on the Camera's model number.
My camera does not charge the battery from the USB lead. I have to use a separate charger.
Jan 05, 2011 | DigiLife DDV-M1 Flash Media Camcorder
My batter is not charging.
try removing the battery and reinserting it in to the socket.
make sure your charger has voltage recommended or stamped on the case. If not, then replace the charger.
Jul 10, 2010 | Compaq Presario C700T Notebook
Iphone 2g battery
You'll have to let the iPhone charge sufficiently for it to proceed further from the boot screen. You may want to leave the iPhone charging for atleast half an hour before unplugging it.
Jan 09, 2010 | Apple iPhone Smartphone
It's on but not charge
If the light on the adapter was flashing, I would certainly replace it first. You can buy recertified chargers from each computer manufacturer and save $$.
I would also check where the cord from the charger plugs into the laptop just to make sure nothing had gotten inside the jack plugin area and may be preventing it from seating correctly.
Dec 07, 2009 | Televison & Video
Cell Phones Logo
53 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
