Question about Logitech Z-340 Computer Speakers
New hard drive in my computer. Do I need a disc for my speakers to work?
  • Logitech Master
  • 32,281 Answers
No, but the audio driver needs to be installed as well as the other device drivers specific to your computer.
Posted on Oct 08, 2010
My disc drive cannot be found by my computer, light blinks, sounds like it works but my pc still ignores it. A friend said i need a new case including the electronic...where can i get it???
A computer website. But, this will only work if your drive works in a computer as a hard drive. Connect it to your computer using the relevant leads (SATA or IDE) and see if it works, You will need to remove it from the original case first. The controllers in hard drive portable cases is the weak link in these pieces of hardware.
Sep 19, 2013 | Toshiba HDD2H92) 500 GB SATA Hard Drive
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
Barracuda7200.10 320 my computer tell me that there is no harddrive i need the drivers for it
You don't need drivers just:
Right click on My Computer,Manage, Disc Management from there you can see new disc the right click on that disc and create new volume and format disc.
Feb 26, 2010 | Seagate Barracuda 7200.10 320 GB ATA-100...
Disc drive stopped working
A hard drive can stop working just like any other electronic device when it becomes faulty.
First go into the BIOS configuration and check if the hard disk is detected. If not it could be faulty.
Next re-seat the hard drive, it just may need connecting again to make proper electrical connection.
If it still does not work, then remove the hard drive and plug it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external USB hard drive nor can you open the folders and files then the hard drive is definitely faulty.
To get the laptop functioning again, replace the hard drive, install Windows on the new hard drive together with the laptop's device drivers and your programs.
Dec 11, 2009 | Compaq Presario Notebook
New hard drive will not recognize speakers, no sound at all.
you need to go to the computer makers site and find make and model and download drivers for the sound.
Aug 28, 2009 | Western Digital Computers & Internet
Its saying that there is no disc drive on my notebook and it has worked before, help me fix this!
You computer cannot find your hard disk. The hard drive could be faulty or the hard disk controller has failed.
Reseat the hard drive (remove it and install it again), this may fix your problem with the connector on the motherboard.
If reseating doesn't work, the hard drive may be faulty, remove the drive and insert it into a USB hard drive adapter and plug it into a working computer's USB port, if this computer see your hard disk as an external drive and you can see the contents of the hard drive then it is OK and the fault most likely is the controler in the laptop.
If you cannot see the hard drive then the hard drive is faulty. To get your laptop operational again, you need a new hard disk and need to install Windows on the new hard disk together with your programs etc.
Apr 27, 2009 | Acer Extensa 4620 Notebook
No Appearance of external hard drive or symbol on My Computer
hese drive do not usually come partitioned and formatted (as different systems need different formatting)
to do this you need to go into logical drive management to partition the drive. (right click on my computer, select Manage then when the mangement screen comes up select logical drive manager, you should then be able to see your unpartitioned drive which you should then be able to partition and format)
if drive is not detected, remember that these devices need "powered" USB ports, which makes use on some laptops and some ports on PCs difficult as some ports are "low powered" ports, which means the drive can not draw enough current.
this can be resolved by using a "powered" USB hub, to supply the extra power.
Sep 05, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Hard drive replacement w/system restore disc
After installing the new hard drive, you'll need to boot the computer from the recovery disk and follow the instructions to format the drive and install windows. You'll also need to install drivers from the driver disk after Windows is up and running. If the computer won't boot from the recovery disk, you'll need to access the "setup" utility and set the CDROM drive as the first boot device. To access the setup utility, press the Delete key after turning on the power. I hope this helps!
Mar 11, 2008 | Dell Dimension 8200 PC Desktop
Computer speaker installation
I may have disconnected them and I need the disc to download so they will work- they worked earlier today and now they do not
Sep 25, 2007 | Cyber Acoustics CA-2016 Computer Speakers
Logitech Z-340 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
