Question about Microwave Ovens
Microwave model UMC5200BAB display is locked. After power reset per instructions display shows error code -SE- or -5E-. Somtimes pressing Stop for few seconds bring the clock back and it work fine for a while. After few hours it would beep and it would show -SE- or -5E- again. Can you advise potential source of problem and course of action? Thanks.
  • Microwave Ovens Master
  • 9,047 Answers
"SE" error means you have a shorted membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs
Posted on Oct 10, 2010
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
I have a se or 5e code what is it
Thank you for your post, friend!
I understand that your Frigidaire microwave is displaying the error code "SE" or "5E". I have researched and the error code seems to be "SE" which means keypad is stuck. In order to remove the error code the keypad would need to be replaced.
Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this helps to some degree. -Matt
Sep 26, 2014 | Frigidaire Microwave Ovens
Error code showing
Unless there is grease or moisture on the control circuit board, error code "SE" means you have a shorting membrane keypad.
On this model, the membrane keypad is not available as a separate part, so the control panel frame assembly (which comes with a new keypad) would have to be ordered and replaced. It's actually a pretty simple DIY repair.
It is part number W10258189 and you can get it for about $129 (subject to change) from the Pros here.
There is also a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad as per the photo below.
keypad_connector.jpg Some connectors have a lock.
Then move your circuit board into the new frame. Be careful, the display is made of glass.
Dec 03, 2013 | Maytag Microwave Ovens
I have a Maytag Microwave/Hood MMV4203DS00. Twenty minutes after its last use as a microwave oven, the Vent Fan spontaneously went on and the Display Shows: VENT...FAN..--5E-- (or SE?). The microwave...
The frame assembly is part number W10258190 and you can get it for $67.98 (subject to change) from the Pros here. You can also order the thermostat (part number WB27X10567 ) from them.
Their is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays have a lock:
positivelock.jpg Then move your circuit board into the new frame. Be careful, the display is made of glass.
Sep 01, 2013 | Microwave Ovens
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Mar 20, 2012 | Samsung Microwave Ovens
SAMSUNG MICROWAVE MODEL NO IS CE1031LAT PROBLEM IS SE ERROER IS COMING WHAT IS A SOLUTION AND HOW T OSOLVE
while I start the m.oven beep sound arise and display -5e-, and then stop automatically .
Aug 08, 2011 | Microwave Ovens
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Quit working
SE probably means a sensor error.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Otherwise, it may have a problem with the control panelm such as moisture or contamination or a bad connection.
Let us know if the hard reset doen't fix it, and please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 12, 2007 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
758 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
