Question about Linksys Wireless-G Broadband Router
How to generate a network key for Dlink Wifi Broadband?
  • Linksys Master
  • 32,281 Answers
The encryption key is set up in the router's wireless settings.
For these details and to secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Oct 08, 2010
Authentication problem on android ipad
You will get an 'authentication' problem trying to connect to this dlink 600 or any other wifi services/routers that are 'protected' and encrypted using WEP or WPA or WPA2 security (e.g. not public or 'OPEN' network): apart from the SSID, you will need to set your android tablet or ipad to use the WEP or WPA or WPA2 PASSWORD/PASS KEY to successfully connect (you get it from the Wifi/Router administrator).
Apr 06, 2014 | D-Link DIR-600 Router
Unable to connect my blackberry to wifi. it says unable to authenticate network.
Try a hard reset: With power ON, remove the back cover and pull out the battery. Wait about a minute then replace the battery and cover. Power up and wait patiently through the long reboot 5 minutes.
Also check the wifi encryption is compatible with your phone?
Maybe an option to goto a cafe with a wifi hotspot and try logging in there ... does that work?
cheers.
Oct 22, 2013 | D-Link Dlink Dir-600 Wireless Router...
I purchased my wireless G 2.4 GHz broadband router a few years ago, and would like to allow my guests to use my protected network; however I don't know my key. How do I find out what my key is so I can...
Hello ,
Its better you can get into your wifi setting by 192.168.0.1 or 192.168.1.1 and check whether the key is visible in characters, coz in most of the wifi setting it used to be in this type * . So if it appears like that you can dissable your security settings for sometime. And when you get into your wifi setting it may ask for your password , the default one is USER ID: admin Password: password or admin
Oct 18, 2010 | Linksys Wireless-G Broadband Router
I am not able to connect my iphone to my home wifi (which uses dlink-DIR 615). I am able to connect my iphone with other unsecured wireless networks. But, mine is a secured one (WPA). Do I have to change...
No, just like when you set up a wireless connection for the first time with a home network, you need to input the network key. As long as you have the key handy, it should work!! For example, when I connect my iPhone to home network, I see my network name "553c" and I "touch" that and it asks what kind of security it has (unless this has changed, my iPhone is 1st generation) so I pick WEP (you will pick WPA of course : ) )and then it prompts for the network key. Hope this helps!!
Mar 27, 2010 | D-Link DIR-615 Wireless Router
Need my wireless SSID Name & Network key
The SSID is simply the name of the WiFi Network, the Network Key or WEP/WAP Key, is generated when you first setup a WiFi point, For the first time you must copy this key to a document & use it when you try to first login, to the WiFi network. So the only place that information can be found is in the WiFi's setup.
Feb 16, 2010 | Computers & Internet
Switch compatibility problem.
I think you need to go from the leased line to the ROUTER first. The switch you said was unmanaged...so as far as I can tell there is NO IP for the DLINK. If that's the case your router needs to be before the switch and after the modem.
Mar 10, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Dlink dir-300 wireless router connection problem!
first coonect your wifi router witjh your laptop with ether net then go to this link
http://192.168.0.1
then type user :admin and password also admin or blank
then go to dhcp then enbale it with auto .
then disconnect your cable from laptop.
then go to my network places then find wireless network then simply conect your network.
thtas it.
Nov 10, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Configuring DLink Wifi router for Reliance broadband
quick questions
1. how did you setup your modem?..is it via PPPoA or PPPoE
2. can you please provide the model number of your modem
thanks
Apr 24, 2008 | Linksys Wireless-G Broadband Router
Verification and signal problems
Hi Sir F,
You don't need to do a re-install of the DLink WiFi adaptor since I believe it is running as it should (as you posted). All that is needed is to configure it to exclusively select only your NetGear WiFi Router. This could be done in the DLInk Wizard (Start/All Programs/DLink.../) set the DLInk to connect only to the SSID of your NetGear. Though it may pick up your neighbors WiFi, the DLink will only acknowledge the presence of the other WiFi but connect only and always to the NetGear.
A couple of other things that may help improve your WiFi connection. Use static IP add in your PC to match that of the NetGear, disable wireless security (WEP or WPA) but rather enable MAC filter and input that of your PC's WiFi Networking Card.
Should you need a more detailed instructions, pls post back the model of your router and the make/model of your PC as well as your OS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 07, 2008 | D-Link Air DWL-122 802.11b Wireless...
Linksys Wireless-G Broadband Router Logo
42 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
