Question about Toshiba Satellite A100-S8111TD Notebook
Laptop will not boot
I have an old Toshiba Satellite Laptop (an A10-S177; Part No. PSA10U-01SVS7). It interfaces with a field instrument and is specific with the instrument, so replacing it is not a good option.
Yesterday while in the field, a corner of it got wet. After drying out, it will not boot.
When on battery power or housepower, the charging light flashes yellow in a repeating pattern of 5 - 2 - 1.
Any help you give me would be most appreciated. Note that the product model selected is not my particular model, but the closest I could come to it.
Thanks,
Brent
  • technical2 Oct 26, 2008
    My Toshiba Satellite A100 began to slip from my lap and I grabbed it very quickly / rapidly or slapped it between my hands to save it, however it will not fire up only a seies of 11 -12 yellow flashs on the battery symbol??? any help
    Scholar:
  • 139 Answers
Try to remove the ram then hard drive. now remove the batteries then insert the ram back without the hard drive, power yr system directly from yr wall sucket without batteries n see what happends. i think i should power on. other wise try using a dissferent ram on it.
thank uy
Posted on May 30, 2008
Cannot get into the setup. tried F2, F12 and F8. Nothing. Any help into how to enter the setup?
try F1 when you turn the laptop on and you see the post screen start opressing the F1 key
Feb 19, 2011 | Toshiba Satellite A10-S177 Notebook
Bios passwor reset
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using Kill CMOS software from Hiren's Boot CD to reset the BIOS.
Feb 09, 2011 | Toshiba Satellite A10-S177 Notebook
Why does Toshiba satellite a10-S177 have 1gb ram limit? Motherboard? BIOS? Or just that 1GB SODIMMs weren't invented yet?
Motherboard
More specifically the motherboard chipset.
The motherboard chipset is the Northbridge chip, and the Southbridge chip.
{In reference to the motherboard chipset technology used for this laptop}
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Northbridge chip handles the faster capabilities of a computer.
The Northbridge chip determines what Processors can be used, what Ram Memory can be used, (Plus the amount), and High-speed graphics.
AGP and PCI Express being High-speed graphics.
A graphics card inserted into a PCI expansion slot is not High-speed graphics.
Neither is Integrated Graphics.
The Southbridge chip handles the slower capabilities of a computer.
{CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short}
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The motherboard chipset for the Toshiba Satellite A10 series of Notebook PC's, is an
Intel 852GMV.
The maximum amount of ram memory supported is 1GB.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4-M.2FPentium_M.2FCeleron_M_Mobile_chipsets
http://www.intel.com/assets/pdf/datasheet/252407.pdf
Regards,
joecoolvette
Dec 16, 2010 | Toshiba Satellite A10-S177 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          DOWNLOAD DRIVER PSA10U-01SVS7 SOUND DRIVERS
          You can download any/all the Windows XP or Vista sound drivers for
          your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Use this link: -
          http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
          Mar 20, 2010 | Toshiba Satellite A10-S177 Notebook
          After applying SP3, my Toshiba Satellite A10 is slow to start. It boots OK but there is constant disk activity for 5min and it is unresponsive during this
          OK after one upgrades to SP3 often it takes ages for the pc to do it's "Housekeeping" I find that it is best to let if do what it will over night and next morning it should be all OK. Also even after you have upgraded, go to windows Update and let is go through, because there were some fixes that needed to be applied after. Also make sure you do not have any applications that defrag, or similar running while this is going on.
          Jan 28, 2010 | Toshiba Satellite A10-S177 Notebook
          My touchpad scrolling doesn't work, what to do?
          “Hi let’s see if we can fix this problem”
          I. “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
          II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
          III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver”, click (OK), this will ensure that the application take effect.
          Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
          Hope this Fix it.
          Dec 06, 2009 | Toshiba Satellite A10-S177 Notebook
          How to cheng bright ness toshiba lap top a10 s703 thanks
          to cheng bright ness toshiba use "fn" key and then use f8 or f7 key
          Mar 09, 2009 | Toshiba Satellite A10-S177 Notebook
          No Audio device found on Toshiba Satellite A10-S177
          Try downloading the AC97 HD Audio Codecs and reinstalling over what you have.
          Post your results or any additional errors back here.
          Mar 02, 2009 | Toshiba Satellite A10-S177 Notebook
          Sound device (no sound)
          Hello!!
          Just reinstall he sound drivers from ur motherboard cd!! It works!!
          Cheers!!
          Feb 23, 2009 | Toshiba Satellite A10-S177 Notebook
          Toshiba Satellite A100-S8111TD Notebook Logo
          48 people viewed this question
          Top Toshiba Computers & Internet Experts
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
