Question about Toshiba 250GB TOSHIBA USB 2.0 PORTABLE EXTERNAL 25 250 GB Hard Drive
Toshiba 250gb external hard drive used to working properly until it was scan after getting infected by viruses. Now it is not recognised by windows xp
  • 386 Answers
Hi Good day!! Check the cable maybe your cable has been damage..
Posted on Oct 08, 2010
Remove virus
Insert your USB drive in the appropriate USB slot in your computer.
If the Autoplay dialog box appears, select "Take No Action" and click the "OK" button.
Launch your anti-virus program, such as AVG Antivirus or Anti Malware.
Select the USB drive for the program to scan.
Click the "Start Scan" button or option.
Open the scan history for the USB drive when the scan is complete to see a list of viruses and warnings identified by the antivirus software.
If desired, select the options to "Heal All Infected Files" or "Move the Infected Files to the Virus Vault" to ensure these files are quarantined from your system.
Highlight each infected file in the scan history.
Write down the file name of each infected file identified on the USB drive.
Minimize the application's window.
Select "Run" from the Windows "Start" menu. In the Run window, type "e:/" at the command prompt to switch to your USB drive (or type the drive letter for your USB drive).
Press the Enter key.
Type "attrib -s -h -r -a *.*" at the command prompt to remove the system, hidden, read-only and archive file attributes.
Type "del ####.+++" where "####" is the file name of the infected file and "+++" is the file extension, at the command prompt line.
For example, "del terriblevirus.exe" will specifically delete the Terrible Virus executable file. Repeat for each infected file on your list identified in Step 4.
Close the command prompt window; that is, exit the Run utility.
Maximize the window for your anti-virus program (which is still open) and repeat Steps 2 to 7 until no virus is detected on your USB drive.
Exit the anti-virus application.
or Click start click on my computer you should see your usb drive right click then select format.
another way is to control panel administrative tools computer management disk management Right Click on your drive select format
Oct 22, 2013 | Toshiba Computers & Internet
Tip
Make ESET NOD32 Anti-Virus Auto Scan Flash Drive
Everyone doesn't want computers infected with a virus. The question is, where the virus entered into the computer. There are two possibilities, may be infected from the Internet or external device (flash drive, memory cards, external hard drives, etc). Flash drives are external devices that are often used. When we insert the flash drive to the infected computer, flash drive will be infected with the virus. In a flash drive that is infected, will form the autorun.inf file. Autorun.inf files will work automatically, every flash drive is inserted. Setting the default operating system is windows autorun when inserted an external device. Autorun windows, used by the autorun.inf, to enter into the computer. To protect your computer from viruses, there are a few things done:
1. Update anti-virus
2. Setting anti-virus in the guard position
3. Turn off windows autorun
4. Make anti virus auto scan flash drives
Turn off autorun Windows
Win Xp : Press START - run - regedit - HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer - NoDriveTypeAutoRun - Value Data - Type = ff - OK
Win Vista / 7 : Press START - Control Panel - Hardware and Sound - Autoplay - uncheck "Use Autoplay for all media devices" - SAVE.
Using software USB Safely Remove. Open software USB Safely Remove - click View - Options - Global Autorun - After device plugging - click Add process to launch list - click browse, open directory C:\Program Files\ESET\ESET NOD32 Antivirus\ecls.exe - Open - then double click the drive letter, to add parameter %DriveLetter% - then, on the tab File name and parameters, write /log-file=c:\report.txt /log-rewrite /aind - OK. Then. click Add process to launch list - write "C:\report.txt" - then unchecked "Wait for the process to finish" and "Launch the process for drives only" OK - FINISH.
on Sep 26, 2011 | ESET NOD32 Antivirus
Userinit.exe application error
Hi again:
I would suggest that you may have a virus / spyware infection that has infected this windows file.
If you can boot into SAFE Mode ( reboot the computer) and when the screen goes to the black background with white writing start pushing F8 - keep doing so until you get a screen that gives you a list of things you can do -
ie:
restart windows normally
safe mode
safe mode w/networking
use the arrow keys on the keyboard and choose to boot into safe mode.- may take a couple of minutes
once there i would suggest running virus / antispyware scans as well as running a BOOT SCAN (a type of virus scan that scans the hard drive before it gets into windows)
NOTE on running virus/spyware scans - ALWAYS QUARANTINE the file infected - DO NOT DELETE - if you delete a critical windows system file you will cause windows to completely crash and in that instance you would have to reformat the hard drive and reinstall everything.
Jan 02, 2012 | Computers & Internet
Hi, I haven't used this drive (Toshiba 250GB
If retreiving data is not your expertise, I suggest you take it to a local computer guy and extract it. The drive could possible be corrupt or password protected. Try best buy.
Jan 23, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
Backing up information(songs pics )
try trendmicro.com and use housecall online..
Oct 13, 2008 | HP Pavilion dv6000z Notebook
Partition external 250gb drive
why would you want partition it??? XP will recognise the 250. Partition was useful for win 98, but pointless excercise with XP.
Aug 07, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
HD PROBLEM
Have the same problem with
TOSHIBA MK1234GAX USB Device
Did You solved it?
Jun 13, 2008 | Computers & Internet
Western digital my book 320gb not recognised
Try first disconnecting all USB ports and power plug for half an hour, this will get rid of eventual problems caused by electrostatic charges on usb channels.
If it does not work, this means that the virus has corrupted your Windows System, probably the root hub is defective.
In this case you will have to reinstall windows, either using recovery, from disk or partition, or using a Microsoft windows setup disk. Save all your data before reinstalling.
Regards
Jun 01, 2008 | Western Digital My Book Essential 320GB...
Toshiba 250GB TOSHIBA USB 2.0 PORTABLE EXTERNAL 25 250 GB Hard Drive Logo
254 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
