Question about Sony Playstation 3 (PS3) Console
| am getting 8002f14 error when I am launcing app_home/PS3_Game what I havo to do??
  • 358 Answers
Hi,the PS3 YLoD can be caused by a number of things. Most commonly, it's a result of a hardware failure, overheating, dust build-up inside the system, and occasionally just due to loose cables.
Let's start with the easy stuff first to narrow down the cause. Follow the steps below:
1. Assuming you were playing your PS3 when the YLoD happened, move your PS3 into an open area with a lot of ventilation and let it cool down for 20-30 minutes. Once it's cool, try to turn it back on and see if that helped. If not, go to Step 2.
2. Unplug all of your cables from the PS3 including the A/V and the power cord. Also unplug the power cable from the wall. Now try to plug them all back in and make sure they are all secure. Turn the PS3 back on and check if it's working. If not, go to step 3.
How to Fix PS3 Yellow Light on Your Own
3. Get a vacuum with a hose attachment and vacuum out the vents on the system. Sometimes dust build-up alone can cause your PS3 to stop working properly. You might also want to take one of those cans of air and blow it in there to get some of the stubborn pieces of dust out.
If none of those solutions worked, the problem lies within the PS3 and you will probably need to take it apart to fix it. The most likely scenario is that your heat-shield overheated, the chipsets got shifted due to heat, and your solder could be cracked.
the causes of the yellow light of death
Here are some of the top causes of the PS3 Yellow Light of Death:
* Overheating - The unit gets too hot. Sometimes caused by too much dust buildup in the vents.
* Blu-Ray drive failure.
* Bad power supply.
* Hard-drive critical errors.
* Hardware malfunction on the motherboard - The solder starts to crack due to excessive heating and cooling.
if you have warranty then take it back if you dont then you can either try the repair yourself how ever this is not very easy to do and can cause more harm than good you will need special tools to take it apart and its not easy you also need an understanding of heat seal paste and heat sinks due to this being the part you need to remove and put back
i do the repair for about 25pound plus parts so if you are paying someone to do it then your looking at least that price, i only charge if the problem is fixed so try and get the best price you can.
let me know if you need further assistance ok
Posted on Oct 08, 2010
  • jersey mark
    jersey mark Oct 08, 2010
    You can also Just reconnect the blu ray drive. It worked for us! WOOT!
    the
    blue ray was the problem to me i disconect the blue ray and connected
    again and bang 100% no problem no need to mes with hdd or tumb drive.
How do you get rid this error on ps3 (80710004)?
After some research, I assume this is a streaming issue. My personal advice is to try a wired connection, or a router restart. If you still experience the issue after that, contact the PS3 Customer support @https://support.us.playstation.com/app/contact_options/
May 22, 2014 | Sony Playstation 3 (PS3) Console
How do I correct error code 8002F310
The error code your getting is saying that your PS3 is failing to update. You can disconnect your system from the internet, turn off automatice updates and try it manually or you can try loading the update through the PS3's safe mode. This link will show you how to get your PS3 into safe mode. https://support.us.playstation.com/app/answers/detail/a_id/1488/kw/Safe
Also, you can download the update onto a flash drive and load it onto your system from there. This link will explain how to do so.
http://us.playstation.com/support/systemupdates/ps3/pc_update/index.htm
Nov 04, 2013 | Sony Playstation 3 (PS3) Console
Ps3 error code 8002ad36
8002AD36: Log in to PlayStation Network has been reset.
This usually means connectivity issues with the internet.
You may want to connect with a wire if possible.
If using a router try DMZ your PS3 or connect directly to the modem and see what happens.
Ref: http://support.us.playstation.com/app/answers/detail/a_id/4084
Dec 17, 2012 | Sony Playstation 3 (PS3) Console
How do i get the game out of my ps3 when it flashes yellow and how do i fix it?
Welcome to Fixya
YLOD or yellow light of death (indicated by the flashing yellow light). When you are Experiencing Problems with the PS3 like this you mainly have 2 options to take.
Option 1
Send The PS3 to Sony
Almost all problems with the PS3 Sony can fix easily if not they will send you a refurbished model.
Price:
If your in warranty they will not charge you for this repair/replace.
If your out of warranty the Charge will be $150
Waiting Time:
4-6 weeks
Sony Contacts right here
Option 2
The PS3 Repair guide
When your suffering problems with the PS3 its often easy enough to fix it at home with a good ps3 repair guide. There famous for fixing major problems like:
The YLOD - Yellow light of death/ Red light error
The Disk Read error
The Hard disk Corruption error
The Red Screen of death - Serious error
PS3 Freeze up Error
PS3 No Signal Error - no display
FIX All error messages
But not everyone knows they can fix simple settings problems like all error messages and the no display error, av and hdmi screen problems and more.
Price: averages between $40 - $60
Wait time: instant download and repair within 2 hours
I really hope I provided you information to fix your problems with the PS3 and get back to gaming soon as possible.
Cheers!
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
Can a PS3 output a dvd movie to a projector? And if so, is it straightforward?
if its standard av cables than it would be the 3 colors pluged into the projector for hd projetion it would most likely be a hdmi cord the setting for hd are in video ps3 launces in last know configuration so standard would carry over
Dec 08, 2010 | Sony Playstation 3 (PS3) Console
Im having problems with my ps3.i turn it on and all i get is a red screen saying there is a serious error and i need to contact technical helpline.why is this and can it be fixed? please help
Yes this is the red screen error you will need to fix it but the better news is that you can fix it from home or you can use a good guide to fix it from home.
Jun 23, 2010 | Sony Playstation 3 (PS3) Console
I have connected my PS3 to the internet wirelessly before but I have recently moved into a new home. I consistently get the 8013013d Error code when trying to connect to the internet... But my room mate...
Hello :D
8013013D "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the conneciton drops Putting the PS3 into DMZ may help - otherwise check WPA key PS3 can't handle WPA2 only WPA or none
May 21, 2010 | Sony Playstation 3 (PS3) Console
Error Code: 80010514
it could be that you have something turned off in your Home Ps3 settings like under BD settings or any other settings that have to do with the disks or disk speed.
Oct 10, 2008 | Sony Playstation 3 (PS3) Console
Game startup error
call support and ask them (go online and look up ps3 support #)
Mar 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,208 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
