Question about Dell PowerEdge 2950 (becwfk1_6) Server
Dell poweredge 2950 failing to boot. displaying no boot device available. we use this system for scanning purposes. it act as a server. at first i thought it was a USB card but after replacing a new one it has continued displaying message that NO BOOT DEVICE CONNECTED. I checked the hard drives but they are all working.
  • 60 Answers
SOURCE: dell poweredge 2600 server recently
Did you experience a power event? Go to BIOS (F2), and make sure that RAID is Enabled. If RAID got turned off (power event, BIOS reset), then it will give you that message. If RAID is already enabled, then you may need to repair your operating system. If something else happened (drive failures, drives removed, etc.), then the array may be completely gone. Call Data Recovery services if it is critical you retreive the data.
Posted on Aug 14, 2010
  • 58 Answers
SOURCE: PowerEdge 2600 does not boot up ?
you need to set the boot device order. Usually F12.
or you can go to bios with F2 or F10.
your cd-rom is wrong you need the Instalation and Server Management CD. I think it's possible to download this cd at their site.
good luck
Posted on Dec 07, 2007
  • 46 Answers
SOURCE: Problem in reboot the server in domain
Perhaps there is a IP conflict?
Why not set up DHCP with IP reservations for your servers? I have no idea how big your setup is. We have a few of these servers at my work and have experienced no problems.
Also i believe this server may have 2 network interface cards, make sure you have the IP set to the correct adapter, and dont plug them both in with the same IP address.
How long have you left the server at "applying computer settings" before plulling the network cable?
Posted on Jan 25, 2009
  • 13433 Answers
SOURCE: Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
http://support.dell.com/support/downloads/
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
Posted on Jun 03, 2009
  • 5 Answers
SOURCE: Does Dell PowerEdge 4600 Server support DVD ROM
I am working on one of these now and yes, it should boot from DVDROM. Be aware that it is a notebook style drive and there are no onboard IDE or SATA controllers, so once the drive dies you're in for a wallet hit. Same goes for the floppy drive which is integrated with the DVDROM. Even worse, the presence of the broken floppy usually means a USB floppy drive won't help when loading windows drivers at install time.
Posted on Jun 07, 2009
Error E2011 Memory Config
It sounds like the servers have different memory modes selected :)
Mar 04, 2014 | Dell PowerEdge 2950 (becwfk1_6) Server
My server poweredge 1800 failed how can i remove data? and the server was configured raid 5
The obvious is to repair it, but if you have another identical server you can place drives and access data. The replacement should boot as failed server. Make sure to track drives and slot location. Shuffling may cause major failure. It may want to stripe itself again and cause data loss and defeating the purpose.
Aug 31, 2012 | Dell PowerEdge 1800 Server
My dvd rom will not read my iso image cd for a boot. but it will read factory made cd.. help i need to update my raid controler i have at dell 2950 server running MS2003
If you have a spare USB flash drive lying around, you could try using http://unetbootin.sourceforge.net/ with the ISO image. Then, hit F11 while the 2950 is booting and you should be able to select the flash drive.
If that doesn't work, see if you can find updated firmware for your DVD-ROM on http://support.dell.com or if it's an aftermarket install go to the OEM's support site.
Failing that, maybe try different media. If you're burning to a CD-R, try a different brand (and avoid CD-RW discs.) If you're using a DVD-R, try a DVD+R.
Oct 14, 2010 | Dell PowerEdge 2950 (becwfk1_6) Server
How to use the smart start cd to install dell poweredge 2950
Smart Start is an HP utility. Dell has a similar one called Systems Build and Update Utility (SBUU) or Systems Management Tools and Documentation (SMTD - much larger download and includes SBUU).
You should use the DVD version if possible, and if you are installing 2003, it should have SP2. If it doesn't, then you can use nLiteOS.com to integrate the Service Pack into your installation media.
Aug 14, 2010 | Dell PowerEdge 2950 (becwfk1_6) Server
No video output
Turn off machine un plug all power cables.
To access the jumpers, remove the cooling shroud by lifting the release latch and sliding the shroud towards the front of the system
Lift up the memory module airflow shroud for easy access to the jumpers
This will rest the password and then you will be able to rest the server.
Hope this help you.
Nov 09, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
My powerdege 2950 dell server doesn't display anything on screen and doesn't respond to mouce or keyboard keys I've tried to shut it down fremoving the power supply for more than 2 hours and when I start...
g_cic14
If the server is not posting then most likely you are having a hardware problem. If you let me know the light that you see and where they are I can tell you what is wrong.
Issken
Sep 28, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Windows - Delayed Write Failed
This points out to a problem with one of your hard drives. Run CHKDSK on all drives you have, & if any problems are detected on any drive, run CHKDSK /F on that drive.
Apr 04, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Windows 2008 Server not able to installed (with RAID)
tripathi_g
The CD may not be the operating system CD. What is the full text on the disk and what are you trying to do.
Issken
Mar 23, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Dell PowerEdge 2950 (becwfk1_6) Server Logo
1,658 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
