IBICO 2700 I need to replace the rollers on my machine. I need to order the rollers and I will need instructions for removing the the old rollers and installing tte new. Can you assist me?
  • 1,326 Answers
What make is a BBICO 2700 and dose it cross with any other model? Need more info.....
Posted on May 30, 2008
Nordictrack 1750 Drive roller installation problem
In order to remove that roller you need to do two things. 1. Take the drive belt off the roller and motor pulley. Just press it to the side while you move the motor, it will start to walk off. 2. Loosen the rear adjustment bolts with an Allen wrench. Loosen both bolts till they are almost out of the roller. Once the belt is loose you can take the front roller out.
Jul 27, 2017 | Exercise & Fitness
I have a Ibico el12 ii laminator and need to know how to use it. I cant find the instruction manual for it at my new job i put the sheets in as it shows but it labinates the first 1/2 inch then goes no...
You need to put your document in a carrier to prevent the heat from buckling the pouch before it makes it into the rollers. I've had a similar problem in the past before I remembered to use the carrier.
Jul 02, 2009 | Office Equipment & Supplies
How do you replace ibico 1022 calculator ink roller
Open the couver above the pinter, you will see on right side a brown or black plastic saying "pull up".With a bit of force it comes up and than change it with a new one and pressed down. GOOD LUCK.
Nov 21, 2008 | Office Equipment & Supplies
Ibico binding machine
I have sold some Ibico machines, depends on the model some are only designed to punch a few sheets such as 6 to 10 booklets. Need the model.
Jun 24, 2008 | Office Equipment & Supplies
Ibico 2700 laminator
I need to replace the rollers on my IBICO 2700 laminator. I will need to order the new rollers can you help?
Apr 24, 2008 | Office Equipment & Supplies
Replace Fuser Gear Xerox XC1040 Copier
Call a tech!. You first remove fuser assy from machine. One green screw to loosen and then you figure the trick out to get it out. Then once its out remove cover 2 screws I believe. Remove the lamp gently, you can do this with out unscrewing anything. Then remove the little clip on end of heat roller, simple spread clip and replace gear. It takes a tech about 10 min.
Feb 13, 2008 | Office Equipment & Supplies
Ibico Binding Machine User Manual/Instructions
I found the IbiMaster 400 manual!!! The key was finding out that Ibico was sold to General Binding Corp. (GBC). I went to the GBC web site and it linked me to Acco. I called Acco and they promptly sent me an old, scanned PDF of the manual. The very helpful POC at Acco was:
Kaye.Eldridge@acco.com
Jerry Quinn
Sep 28, 2007 | Office Equipment & Supplies
148 people viewed this question
jasbo
jasbo
