Question about Samsung Televison & Video
Fan error model No samsung HLR4667 it give me fan stop error and set shutdown. is this set has a defective fan?
  • 4,234 Answers
It is possible that some debris has entered the fan and is preventing it from spinning fast enough to be detected. Try opening up the back and blowing out the fan area. Check to be sure that the fan spins freely (with the power off/unplugged) and try again. Let us know how you make out.
Dan
Posted on May 29, 2008
Why does my Samsung rv520 shut down after 30 min
Overheating? Are the airways clear and is the fan clear?
Feb 28, 2015 | Samsung RV520 Laptop
Hp computers erors fan samsug tv 55 eror 002
To fix fan error change the fan to start with. In the computer if the error persists then it's a fault on the mother board.
I would not know the error with your TV without having the service manual to look it up. More often the power supply section gives problems in these sets. Sometimes the fault can be in another board. Board substitution is the best way to find the defective board.
Aug 22, 2014 | Samsung DLP HL-P5663W 56" TV
SAMSUNG DLP HL-R4667
It sounds like a bad color wheel (see photo) which will give a fan like or high pitched sound.
Very common on these sets and can be a do it yourself repair.
You Tube has complete video instructions for replacement for most of these models.
The wheel turns at over 12,000 rpm (very small part) and the bearings in the motor fail causing a fan like or whine noise.
If it fails all the way and shatters (it can) set will not even make it on---set is monitoring the wheel and if not at right speed or stops almost instant shutdown will happen.
see the photo and let me know if questions--replaced a lot of them and your description is classic.
Mar 19, 2012 | Samsung DLP HL-P5663W 56" TV
A message on the tv says check fan # 2, then the tv goes off after about 1 minute to 5 minutes.
defective fan causing shutdown. Fans run around $70. A tech will know what to do.
May 27, 2010 | Samsung HL-S6187W 61 in. HDTV
I have Samsung HLR4667 and when I turn it on
It the colors wheel,don't do this ur self,it very dificult to take out and replaced,best repair by the shop.
Jan 13, 2010 | Samsung HL-R4667W Rear Projection...
Samsung HL-P5063W DLP No. 1 fan problem
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
Nov 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I am getting an error code SC 534 on my Ricoh Aficio MP 6000.
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound
B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error - replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error - Replace duplex fan
D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error - replace the IOB
D027/D029 SC 534 Second duct fan error - check connections and harness to fan
D027/D029 SC 534 Second duct fan error - replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
Jun 13, 2009 | Office Equipment & Supplies
I have a Samsung RS21DPSM side by side fridge under 2 years old and the other day a loud noise was coming from fridge Sounds like a fan as when you open fridge door it grinds to a stop) compartment and...
There is a design problem with this model. The fridge section is icing over due to a design defect and the noise you can hear is due to the fan on the motor driving against the ice. Eventually the motor will be stopped from running and the fuse will blow in your plug. Contact Samsung and they should replace the defective parts with a fix.
May 11, 2008 | Heating & Cooling
Trying to replace lamp fan
First let make sure it's the Lamp fan. What many people think is the fan, And by the way there are three fans in this model, What sound like a fan is in fact a color wheel. So listen to the set as it starts up, these Samsungs make certain sounds when they start. First after you hit the power button you get the "Samsung Tones" from the speakers, second ALL the Fans start 1 to 2 seconds later the color wheel starts then stabilizes, third you may here the lamp fire. So if the sound takes two to three seconds after you turn the set on it's the color wheel BP96-00250A Now when it shuts down its like this First the shutdown "Samsung Tones" then watching from the back after a few seconds the lamp will shut off, then the color wheel stops but all the other fans remain on for about 2 minutes. I've worked on thousands of these and in only one or two was the problem a fan. but on the other hand I have enoghf bad color wheels I was able to make a pertty inpressive Christmas decoration
Feb 05, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
105 people viewed this question
Jerry Greenberg
Jerry Greenberg
