AT&T Blackberry Curve 8300 Smartphone Logo
Posted on Oct 08, 2010
The loading clock keeps on appearing on my screen
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Oct 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
4151
Points
36
For this issue you would perform a back up and restore by using the blackberry desktop manager which you can download from www.blackberry.com
  • brewology_08 Oct 08, 2010
    ok i will try that..thank you very much
1helpful
2answers
How do i set the clock on my renault megane dci expression?
Look at the dashboard screen. On the bottom right there is a black button poking out oft he plastic screen cover. Press and hold this for a few seconds and the time will start to flash. Then keep pressing the button until the correct hour appears. leave it for a few seconds and minutes will start to flash. keep pressing until it is correct. Leave the button alone and the time will be set.
This is assuming that you want to change the clock on a Scenic II?
Hope this helps
Knen,ore range model 790.74239310 clock panel light does not display the time
Does it appear momentarily when you press the clock key? If so, then you probably have the "energy-saver" feature turned on. To turn it off (so it "wastes" energy by displaying the clock all the time), press and hold that key. When you first press the key, the clock time will display... (Keep holding that key!) Then in about 7 seconds, the display will go blank.... (Keep holding that key!) Then in about 3 more seconds, the display will come back on. Now you can let go of that key, and the clock time will continue to display.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
How to change am and pm in kadio KD3809
Kadio Digital Clock Am Pm setting/ 24 hour format /12 hour
LONG PRESS MODE BUTTON- KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
When it starts blinking just press the DOWN BUTTON to make PM appear on the screen.
Thanks.
Apr 01, 2013 • Radio
1helpful
I need a manual for the 00593W weather station. Please?
Push and hold the "-" button on the main unit until "P" displays on the screen. You'll now set the time zone so the system can automatically set the clock. The screen will begin cycling between the time zones. Push the "Set" button when the correct time zone appears.
Games do not work
more then likely, there was an error with the internal clocks and on a date change they failed, causing the ps3 to not load or read a disk, blu-ray or game.
4helpful
We want to reset the clock from am to pm or start beginning questions all over again.
1. Turn on the TomTom unit. 2. Tap the screen to bring up the menu. 3. Tap the "Change Preferences" icon 4. Keep hitting the arrow to go to the next page. Clock setting is on page 6 of the preferences dialog. 5. If the Set Clock option is greyed out, you will need to perform a system reset and then perform these steps over again.
To reset the system, start with the power off. Then, hold down the power button for about 15 seconds, until you see the TomTom logo appear on the display. When the logo appears, release the power button. After this reset, you should be able to turn the unit back on and proceed with your setup from scratch.
2answers
Can you tell me when the network driver in Windows gets loaded. I read some where that it does not get loaded until you get to screen in XP Pro. Is this true?
The network drivers do not load until you boot to Windows. I'm not sure what you mean by the XP Pro Screen but you have to be at the desktop level to have them load.
A good way to test when they've loaded is to go to your network connections after you're fully booted and right click on your connection. Choose properties. Check the box that says: Show icon in notification area when connected.
Two little computers should then appear in the right side of the system tray by the clock.
When you reboot, those will not appear again until the drivers have loaded.
Debbie Mahler
MICE Training, Technology & Education
5helpful
How do i change the clock on a sts 2008 cadillac w/navigation sys
Had the same problem...hit CONFIG...then Vehicle on the left side...when the Vehicle screen
shows all the info on languages....hold your finger on the clock in top right corner. The clock
adjust screen should appear. I could never get the clock adjust screen because I was just
touching the time...you have to keep your finger on it until the screen comes up. Hope this helps.
Gary
Virginia
4helpful
Ss 5000 sound spa
Atomic clocks are tricky. The clock defaults to PST.
Turn OFF the atomic time feature (The little radar icon will disappear) Make sure that you have clicked the DST/TZONE button on the back of the clock to YOUR timezone (a P,M,C,or E icon will appear on the front screen.) Then turn the atomic feature ON and hopefully - all is well!
1helpful
Centrios DVD Recorder
Setting the clock
1. Press SETUP in no disc mode or full stop mode,MENU screen
appears on the TV screen.
2. Using v select SETUP MENU, then press ENTER or >,
BASIC SETUP is highlighted.
3. Using v to select “Set Clock ”, then press ENTER or >,
“Set Clock Setup ”screen appears.
4. Press</>/^/v repeatedly (or numeric buttons) to set the
date and time.
5. Press > to select “Done”or“Cancel ”, and then press ENTER ,
BASIC SETUP returns.
6. To exit, press SETUP.
7. Press POWER to turn off the unit, the clock appears on
the VFD display.
link to manual http://www.centrios.com/content/support.aspx?language=en-CA#
Top AT&T Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
