Question about Pride Jazzy Select 6 Indoor Power Wheelchair
My chair was going along fine and then suddenly ground to a halt with just one red light constantly flashing at a steady rate. There is no drive! If you press the horn button a second light comes on but they still flash and if pressed again all five lights come on and remain flashing. This chair had been fully charged only 24 hours before and hadn't been used in the interim. Please advise.
    Novelist:
    Champion:
  • 232 Answers
If the scooter was sitting unused for a long period of time, the gel inside the batteries may have gone solid and will not allow a full charge. You may need to replace the batteries due to the damaged cells. If you know the brand of controller that is on the scooter, you can look up the lights codes here:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Posted on Oct 08, 2010
Only two red lights show after some traveling.
It takes 5-6 full charges to brake a battery in. The first charge is 90%, then it increases. Also make sure that the caster and anti tilt wheels are free of dirt and any restrictions. Make sure that you don't exceed the weight capacity - most chairs are 300 lbs on a flat, hard surface.
Mar 14, 2013 | Health & Beauty
Constant flashing lights,all three of the red, all of the yellow and one green. The chair was not at a full charge. I traveled approximately 20 feet, then I turned the chair around. Next ,I turned the...
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Oct 29, 2010 | Jet 3 Ultra Power Chair
I just gave my mother in law the jazzy 1103 ultra power chair... when you put it on.. the lights flash and the chair creeps along.. it happened all of a sudden.. it wont speed up.. this was donated so I...
tam The batteries need to be replaced. With the lights flashing indicating low voltage and the chair just creeping means weak batteries. With a donated chair you do not know how long the chair sat without being charged. You need to purchase 2 U1 batteries. If there is a battery warehouse store near you or an Interstate battery store check with them because your cost will be less than going through a provider. Hope this helps you
Sep 26, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Apr 30, 2010 | Pride Jazzy Select 6 Indoor Power...
Will not turn on after charging
Sounds like it's time for new batteries.
Jul 18, 2009 | Jet 3 Ultra Power Chair
The battery is charged but the lights just flash and chair doesn't move
Make sure the charger is unplugged from the chair and that the chair is in gear. There's two levers that place the chair in freewheel, or neutral so you can roll it around. Place these in neutral, then back in gear firmly. If still flashing, turn chair off, wait three seconds and turn back on, then push on the horn button three times. This will take it out of sleep mode. Still not going, you will need to check all clip-on connections to make sure they are tight.
I am assuming that all of the lights are flashing constantly. If it flashes a "fault code", you will get a series of flashes from 1 to 10, then a pause, then a set of flashes. Count the number of flashes and it will tell you what the fault is for that number of flashes in the owners manual. If it is just two red lights flashing constantly, you have a set of dead batteries.
Good luck.
Jul 11, 2009 | Pride Jazzy Select 6 Indoor Power...
Blue light flashing light, red light on
The flashing means that the toner and/or the imaging drum is empty or missing (printing halts on these errors). Lights on steady means low toner.
Jun 24, 2009 | HP LaserJet 2550n Printer
Goodman GMP050-3
If you do not have two furnaces hooked together, you have a bad circuit board or an improper ground or neutral wire.
Dec 09, 2008 | Goodman GMS90703BXA Heater
No picture
These sets have had, unfortunately, bad picture tubes. The gun welds tend to break loose over time.
Mar 02, 2008 | Sony KP-43T70 43" Rear Projection...
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
275 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
