Question about Cell Phones
My iphone2g suddenly lost volume. I checked thevolume control and sounds. When I adjust low to high volume the phone sounds fine. But no sound when incoming calls.
    Problem Solver:
  • 12 Answers
First make sure you have all current software by going to settings-general-and about, if its not the current software download the most current software through itunes, with the most current software of itunes also, you can also try doing a reset of all settings by going to settings-general-reset all settings, if those do not solve the issue it would be classified as a device issue
Posted on Oct 08, 2010
The volume on my acer aspire 6530 is to low although the control
if you have external speakers, try adjusting the volume there!
If you don't, then click on 281bf5a1-868f-4ef8-aedd-d25642705e45.png icon, click 'Mixer', adjust the levels.
Or click on Start, write in "Sound",4b2d9ebd-91e4-43cf-8490-3de18c6bc30c.png
Adjust the settings for device/s you use to hear sound.
Dec 18, 2013 | Acer Aspire 6530-5143 Notebook PC
My Akura TV has suddenly lost most of its volume power, everything else works fine.
i have an akura combi and the sound has just gone off , the remote is going up and down the volume scale but still no sound, please help.
Aug 12, 2012 | Televison & Video
I have checked and the speakers are working however I suddenly lost all sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 05, 2011 | Dell Computers & Internet
How do i get the Audio to work?
  1. Check the volume control located on the front or side of your computer to be sure that it is not set at the lowest level. If the problem is not resolved, proceed to Step 2.
  2. Step 2 Right-click on the "Volume Control" icon located on the Start menu taskbar and then select "Open Volume Control."
  3. Step 3 Remove all checkmarks beside "Mute" in the Master Volume and all other visible categories. If the sound problem is not solved, proceed to Step 4.
  4. Step 4 Right-click on the "Volume Control" icon and select "Adjust Audio Properties."
  5. Step 5 Go to the Volume tab and adjust the "Device Volume" by moving the slider within the range from Low to High.
  6. Step 6 Click on "Speaker Volume" under Speaker Settings and move the slider within the range from Low to High to reset the left and right speaker volume. If the sound problem is not solved, proceed to Step 7.
  7. Step 7 Go to the Hardware tab and highlight the device with the sound issue and then click "Troubleshoot." Follow the prompts until the issue is resolved.
Mar 02, 2010 | Computers & Internet
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/PCS1400-_E
I got this info off of page 60 from your manual.
CUSTOMIZING YOUR PHONE VOLUME
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Ringtone
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
K800i - NO RINGTONE OR SOUND AT ALL FROM PHONE
Even though the phones profile is not set to silent. the volume on the standard profile could be switched off ! go into the profile settings to check that the volume for your current profile is switched on and up. if the problem persists, seek help from Sony Ericsson And/or your Mobile Phone Carrier
Oct 23, 2008 | Sony Ericsson K800i Cellular Phone
SOUND PROBLEM
Good Morning
If you set the volume up, and there is a problem with audio, I recomend,
1) reconnect your speakers and press well the conector, (green)
2) see if sound came from output connector using a headset.
3) buy new speakers.
depending on the model of your current spk. check one from creative, they have some good Spk. that work fine for years.
Jan 11, 2008 | Audio Players & Recorders
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
Cell Phones Logo
51 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
