Question about JVC Cameras
SR- DVM700 There is no display on front panel and the machine will not switch on
  • 231 Answers
Dear sir,
the first suspect is your battery,which is running in low battery....kindly recharge the battery for few hours with the original charger,because the charging volt varies from battery to battery of the same brand and using this universal charger is definitely going to harm ur camera very worse,kindly go for the original charger and charge the battery and then put your camera on........
if still the problem is the same ,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest jvc service centre .
thank you...take care
thank you.....take care................
Posted on Oct 08, 2010
Unit powers off when dv cassette is inserted
so if the tape is faulty, the deck will sense the tension and auto shut off, or if one of the micoswitchs that detects that the dv tape is spilling tape, it may stop. unplug the machine and after a min replug in and try again
Aug 15, 2012 | JVC SR-DVM700 DVD Recorder/HDD Recorder
Jvc sr-dvm700 stuck in "please wait" when powered up
iT MAY BE A DV CASSETTE WAS INSERTED AND HAD A TENSION PROBLEM THAT CAUSED THE PLAYER TO CHEW TAPE . PLEASE SEE IF JVC SERVICE CENTRE IN LONG BEACH CAN REPAIR IT ( GOOGLE FOR THEM) . ANOTHER OPTION IS TO MANUALLY OPEN THE UNIT YOURSELF-
REMOVE THE MAIN POWER CORD OFF .
YOU WILL REMOVE 8 SCREWS TO REMOVE THE TOP COVER OFF - 2 ON EACH OF THE SIDE , AND 4 AT THE BACK , , AND GET THE TOP COVER OFF, THEN YOU CAN PEEK INTO
THE DV TAPE DRIVE TO SEE IF THERE IS A TAPE CHEW UP MESS , IF YOU ARE OKAY TO DESTROY THE TAPE , CUT OFF AND MANUALLY EXTRICATE LOOSE TAPE WITH A FORCEPS , , THEN FORCE EJECT THE TAPE BY TURNING THE BLACK GROOVED GEARWHEEL ONTHE RIGHT FRONT OF THE TAPE DRIVE - BY PUSHING IT INWARDS INTO THE SLOT , YOUR TAPE WILL MOVE UPWARDS , THEN PUSH THE WHITE PIECE ON TOP OF THE TAPE TOWARDS THE TAPE DRIVE DOOR , THE TAPE SHOULD NOW COME OFF THE DOOR , PULL IT OUT .IF THERE IS AND DVD LEFT IN THE DVD DRIVE , YOU CA MANUALLY REMOVE IT BY TAKING OFF 4 SCREWS AT THE TOP BLACK ROOF OF THE DVD DRIVE , AND REMOVE ANY DVD HELD INSIDE .REPLACE THE SCREWS BACK ON THE DVD DRIVE AND THEN CLOSE THE TOP COVER OF THE UNIT .
POWER BACK THE UNIT ON AND SEE IF IT RESETS ITS STATE -
NOT FINDINY ANY PLAYBACK MATERTIAL IN THE DV OR DVD DTRAY - IT SHOULD GO TO OFF , SWITCH OFF THE UNIT FROMTHE FRONT SWITCH AND THEN UNPLUG IT. RESTART THE UNIT AFTER 1 MIN AND IT SHOULD BOOT PROPERLY AS LONG AS FIRMWARE IS NOT CORRUPTED ON ON-BOARD HDD.. PLEASE CHECK IF THE REAR HDD COOLER FAN IS NOW WORKING GOOD LUCK . PLEASE RETENSION ANY DV TAPES BEFORE PUTTING THEM INTO THE PLAYER . EVEN DV HEAD CLEANING TAPES CAN CAUSE ISSUES . JVC WILL NOT ADMIT IT .
Jul 07, 2012 | JVC SR-DVM700 DVD Recorder/HDD Recorder
Skematik JVC SR-DVM700
there are two rya video outputs on the back, try the other one
May 11, 2012 | JVC SR-DVM700 DVD Recorder/HDD Recorder
Need driver for JVC-SR-DVN700
does not exist, when connecting to windows, cancel the request to install drivers, as there are none, and just use as av tuner, works for me
Mar 19, 2011 | JVC SR-DVM700 DVD Recorder/HDD Recorder
I have an SR-DVM700EU that would not power up. I have replaced multiple failed components in the switchmode power supply, and it now works. The unit would power up but stop someway through the booting...
Did you replace ALL the electrolytic capacitors in the power supply? Generally, whenever there are several faulty components in this part of any circuit, it is a good idea to replace all of the caps as well as checking for leaky diodes and faulty IC regulators.
My guess is that the SMPS still has an intermittent partial fault, which is preventing the unit from staying on. I would recommend that you check the ICs in that circuit, replace as required (if you haven't already done so). These can be 3-pin or 5-pin regulators, but they are voltage rated, so obtain the correct types for this model if you do decide to replace them.
I hope the fault hasn't spread to the microprocessor on the main board - this can be expensive to replace if faulty. I would recommend that you re-check the power supply again - thoroughly. Touch up potential dry solder joints if necessary.
If the unit still misbehaves after all of this; perhaps it's time to consider submitting it to a workshop, get a quote (and a second opinion) on the likely cost(s) of repairs, then you can make a decision afterwards as to whether or not you wish to go ahead and get this fixed for good. It's up to you.
Mar 11, 2011 | JVC SR-DVM700 DVD Recorder/HDD Recorder
JVC SR-DVM700 Recorder
When I contacted JVC tech support their answer was this "On page 54 of the manual it describes how to connect to a DV device. This would be the same way to connect to a computer, but we do not guarantee operation".
Not much help if you ask me, but at this time there does not seem to be a problem to them and thus no real solution.
Sep 25, 2008 | JVC SR-DVM700 DVD Recorder/HDD Recorder
Dubbing hdd to dvd
I had the same problem I thought it was me!! Dooh but sent it back and JVC very kindly replaced the DVD unit, I believe free of Charge and after is was out of warranty by a few months.
Well done JVC on this one.
Aug 08, 2008 | JVC SR-DVM700 DVD Recorder/HDD Recorder
JVC Help
outputs display blurry image when using hdd and dvd setting. outputs give great picture when using dv setting. please help.
Aug 05, 2008 | JVC SR-DVM700 DVD Recorder/HDD Recorder
Cameras Logo
62 people viewed this question
Top JVC Cameras Experts
Michael Galve
Michael Galve
Parshiv Luthra
Are you a JVC Camera Expert? Answer questions, earn points and help others
