Question about Neff H5430 Convection Microwave Oven
What M1,M2 does it mean? - Neff H5430 Convection Microwave Oven
Model # JMV8208BAS
On a GE or Hotpoint, it usually means the keypad is defective. On some other brands, it means there's a sensor error.
May 16, 2016 | Microwave Ovens
Symbol meaning lg
please download your owner manual, go to www.fitness.manualsonline.com or www. retrevo.com and see the symbol meaning.
God bless you
Dec 13, 2013 | Microwave Ovens
Healslo Ax-M1
go to www. retrevo.com or www.manualslib.com and download for free.
God bless you
Nov 13, 2013 | Sharp Microwave Ovens
Needing a manual for a Bellini Halogen Oven KHC-M1
It should have come with an owner's manual.
If not, contact the dealer from which she purchased the oven for the manufacturer contact information.
May 22, 2013 | Microwave Ovens
Lad indicator is showing S-E what does that mean? It is also not working
"SE" means you have a shorting membrane keypad. More info here.
Aug 30, 2012 | Microwave Ovens
My microwave is 18 months old, only and it does not heat anymore nor does the turntable turn, what could be wrong?
HELLO,
THIS MEANS THAT YOUR WAVE HAVE DEVELOP MAIZE PROBLEM OR ELEMENT PROBLEM WHAT THIS MEANS IS THAT THE MAIZE HAS BEEN DISCONNECTED FROM IT POSITION BASS ON THE HEAT WHEN USING
SOLUTION TO YOUR MICROWAVE PROBLEM
PLEASE NOTE THIS
THE MAIZE MENTION ABOVE MEANS WIRE AND WHILE THE ELEMENT MEANS THE HEAT PROVIDER
UN SCROLL YOUR WAVE TO LOCATE THE MAIZE TRACE FROM THE ELECTRICITY DOWN TO THE ELEMENT YOU WILL SEE THE TRACE OF DISCONNECTION FROM THE ELEMENT THEN REPOSITION THE LOSS WIRE AND THEN COUPLE IT BACK HAS IT WAS.
AFTER ALL THIS THEN YOUR MICROWAVE WILL THEN CARRY OUT IT FUNCTION AGAIN
PLEASE MAKE SURE THAT YOU MICROWAVE IS NOT PLUG TO ANY FORM OF POWER SUPPLY
GOOD LUCK AND THANKS FOR USING FIXYA .
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It has an f3 code on it what ledoes it mean
F3 means fault code number 3, I think this is Power Supply, or Magnetron.
Feb 09, 2010 | Samsung MW1030WA Microwave Oven
H97
Hi there..
If it is displaying error H97, this means that the invertor(power supply Panasonic part number: Z606YM300BP,) is not functioning. The magnatron may also be faulty.
You can get a new invertor on ebay.UK from here
Here is some more information about the part. The microwave may also have a faulty magnatron. If you are unsure, then you should get someone to look at the unit for you before you go buying parts.
BEWARE... VOLTAGES INSIDE MICROWAVES CAN KILL
Panasonic part number: Z606YM300BP, supersedes all previous versions of the inverter used with the 2M261-M32J This Inverter is now available at a lower cost, it used to be £60.00 plus VAT and delivery trade price.
This inverter is fitted to many of the more recent Panasonic inverter type microwaves such as the NNC596S .Some microwaves such as Bosch and Siemens also use this inverter as they are rebranded Panasonic ovens. These ovens are upmarket models, some include advanced functions such as steaming and are normally well worth repairing.
The inverter as fitted to earlier ovens with the 2M236-M42 and 2M236-M1 is also available.
An inverter microwave oven is one without a high voltage transformer You will know you have one as it is not extremely heavy at one end. This type of microwave uses a high power DC converter, called an inverter, to produce the high voltage and filament voltage required by the magnetron.
If you purchase this item for replacement in your microwave then we recommend that you do this only if you are qualified and aware of the dangers of tampering with electrical equipment.
Failure of the magnetron is common and at times the inverter can fail as well. Sometimes the inverter fails on it's own. If your microwave blows the 10 amp mains input fuse as the cooking cycle starts then you probably need a new inverter. An instruction sheet with basic guidelines on fitting will be provided but please do not purchase this item unless you are confident about fitting it. We only accept returns if the inverter supplied is defective which is extremely unlikely.
If you have one of these ovens that is not cooking then it is worthwhile looking at the magnetron. It often shows signs of distress through overheating.
As well as the inverter failing it is also possible you could also have a defective magnetron,
Good luck and thanks for using FixYa
A FixYa rating would be spot on for this information to you.
regards
robotek
May 07, 2008 | Microwave Ovens
Neff H5430 Convection Microwave Oven Logo
111 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
