Question about HHP Computers & Internet
We have HHP Quick Check 850 Barcode Scanner , when power button is pressed , only LED lights are displayed but LCD screen Dose't showing anything , Also there is no light flashing while button is pressed for scanning.
  • 188 Answers
SOURCE: LCD display
Could be a lot of things: here is general tips for no backlight:
First if there is a suspend switch (usually right below the LCD sticking out of the notebook) make sure its not pushed down.
second: Did the LCD have a red tint before it failed? if not its probably the inverter. If it did then its probably the backlight, but its best to test the inverter using a known good LCD first.
If you dont have one, then any repair shop that deals with laptops4.gif should be able to diagnose this pretty quickly (you shouldnt pay more than a 1/2-3/4 hour labor to take apart and diagnose.
if it really needs a backlight, it is a very difficult thing to replace the backlight - i see more people break the screen or electronics on the LCD trying to replace a backlight. always try an inverter first which is only about $20-$50 for the dells.
Its usually comparable in cost to buy an LCD ($100-$200 for the part on most models) than replace the backlight (150-220 is the typical labor charges i have seen. Just find out the part number of the LCD to match up a replacement. Try Bliss which sells screens on ebay - nice company to deal with and has a wide variety of screens,
http://stores.ebay.com/BLISS-COMPUTERS-LCD-SCREEN-STORE
Hope this helps!
Posted on Dec 21, 2007
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
bandana_gyrl
  • 181 Answers
SOURCE: my scanner on my f300 printer won't scan
It sounds like the issue is software related. When the light is flashing it is sending the file to the computer but then nothing is happening. You either have not installed the software or you need to uninstall and reinstall.
Both require you to download the most recent drivers - don't use the CD unless you do not have a highspeed internet connection. Just click on the link and enter product name and the OS and choose the most recent full feature software and drivers.
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
Posted on Aug 07, 2008
SOURCE: The scanner is scanning but no data is transmitted to the PC
I also purchased a Symbol LS4071 and when I connected this scanner (purchased at a great discount through eBay) to my computer using the keyboard wedge (with a ps2 connection - the round connector - the connector is split like a "Y") I received the error message that my computer could not recognize this external hardware. I went to barcodediscount.com and ordered the usb connector for this scanner as usb connections are usually recognized. The part # for this connector is STI85-0200R. It cost 72.55 with shipping, but I received the scanner at such a wonderful price that I thought I'd chance it and try it with a usb rather than a keyboard wedge connector.
The computer immediately recognized the usb connection, and the usb connector comes with a manual with codes to enable proper scanning, but still no luck getting the data into the computer. So I called Symbol's technical support department. The technician told me to remove the rubber "boot" at the bottom of the hand held scanner (not the scanner base) by pulling on the front of it (where the 2 little round circles are). It's tough to remove, but keep at it. Then gently remove the battery and unplug it, then plug it back in and reattach the base. He said this would reset the battery. Voila!!!! Sucess!!!!
If your scanner's keyboard wedge connection is recognized (a little popup window will say that it is a Symbol barcode scanner and that it is installed and ready to use), try taking the battery out and putting it back in to reset it. Hopefully this will also work for you. Symbol's technical support # is (800) 722-6234.
Posted on Mar 23, 2009
thesuperdude
  • 97 Answers
SOURCE: scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Posted on Apr 02, 2009
Green light but won't start
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Jun 14, 2014 | Neato 945-0041 XV-21 Robotic Vacuum...
SCANNER BEEPS BUT DOES NOT ENTER DATA SCANNED AT/PS2 KEYBOARD WEDGE BARCODE AND STILL DID NOT WORK
Try to test its entry from for example notepad... it might be that the program you are entering data to has issues.. Regards
Sep 21, 2011 | HHP IT3800 Handheld
When recalibrated the scanner result reads "Scanner Gain Too Hi! ERROR!"
Product Identification & Processing Systems (PIPS) is one of the world's oldest Quick Check bar code verifier solution providers. We continue to support (and repair!) the product line, even though it is retired. We even have new units still available for sale. I'm sure we can assist you. Call 212-996-6000 or email verify@pips.com for assistance.
Jun 07, 2011 | HHP Quick Check 810 Series Bar Code...
Bought new cords for scanners and when plugged in the light comes on but will not read anything
have you tried using another code, sometimes new cord can still be faulty. if you try another cord the same problem comes up then the scanner port might have develop fault
Mar 03, 2010 | HHP Hand Held Products IT3800LR-12 Barcode...
HHP 3800 barcode scanner won't scan/read - I think
Ok I have found some info here what you need to do is download the correct driver from this site, install and you should be fine. HHP 3800r? is that the right one? http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=165
This one below is for the HHP 3800r ?
http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=140
Feb 07, 2010 | HHP Hand Held Products IT3800LR-12 Barcode...
Laser not working, screen won't show, beeps continuously.
i think i can help u with this, if u unscrew the unit and carefully unhook ur the cables in side then will see two Philips screws, unscrew them and unhook the display cable its on the side
now gently try to take the board out and put it back on then hook the display cable back and screw the board back and for the scanning
unhook and re hook ur scan cable that will make it work,i hope that will solve ur problem
Jun 11, 2009 | HHP Dolphin 9550 Barcode Scanner
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
Problem with scanner
I have it connected to keyboard port as they instructed.
Sep 02, 2007 | HHP 3800 (015305) Handheld
Actually HHP IT4410 LR
Have you tried reinstalling the drivers? Or downloading the latest driver from the manufacturers website? My father had the same problem with his scanner, and all he did was reinstalling the drivers and it worked fine afterwards.
Apr 10, 2007 | HHP IT4410HD
Computers & Internet Logo
87 people viewed this question
Top HHP Computers & Internet Experts
David Payne
David Payne
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
