Question about Xerox Phaser 7750DN Laser Printer
Tray feed rollers search-HELP!!!
Can someone give a part number for the standard tray feed rolls for a WC 255/265 7750 7760 etc? having a hard time locating a usable site to locate them.
    President:
  • 2,072 Answers
Https://www.partsdrop.com/store/
Call here and talk to Britt. He will get you everything you need.
Tell him Rick said Hi.
Posted on May 30, 2008
  • 21 more comments
  • Rick Kasper May 30, 2008
    Just google search " the parts drop" or copy and past the link there.
    You can also google " the parts drop" . They are normally the first one listed.
Our infoprint 1125 is on a ibm mid range computer system & is accessible to 9 users. when we print an envelope, the printer asks for a manual load of the envelope, how do i change this to automatic...
It's been my experience with these machines that envelopes are always fed through the manual feed tray.
The Tray 2 cassette's pick up assembly is different than the manual feed,
it has 2 rollers that have a wide area they can pick up while the manual feed has just 1 single roller.
If you remove the tray cassette and look under the printer you can see the two rollers, these would probably have a hard time picking up a standard size envelope.
Also the tray would have to path the paper up and would have to bend it through the paper path which can cause problems with the flaps on the envelopes.
Best method is to use the manual feed tray and to also have the back cover open so that the envelopes path straight through the printer without being curled.
(I've seen these in a ton of places ranging from small business to banks and they always have the envelopes in the manual feed)
Jun 08, 2011 | IBM Infoprint 1125 Laser Printer
MFC-9840CDW Laser Printer: I have a Brother MFC-9840CDW laser printer it is o...
Wipe the paper feed rollers with a clean rag wetted with plain water. You can also replace the feed rollers, search for "paper feeding kit" for this printer. Should be $20 to $30.
May 18, 2010 | Brother MFC-9840CDW Laser Printer
I have an Easy Share printer dock series 3 that has paper loaded
To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the feed roller clean. IMPORTANT: Unplug the power before cleaning the feed rollers.
  1. Unplug the AC power cord from the power outlet.
  2. Remove the paper tray from the printer, and leave the paper tray door open. IMPORTANT: Do not use cotton or cotton swabs to clean the feed roller.
  3. Lightly moisten a lint-free cloth with water.
  4. Use the moistened cloth to gently wipe clean the surface of the feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
  5. Let the feed roller dry fully before plugging the AC power cord back into the power outlet.
  6. Insert the paper tray into the printer, then press the Print button to resume printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Hp p3005n keeps getting paper jam error in tray 2 like every other page it prints and there is no paper jammed. I replaced the printer with a new one and get the same annoying error. So when you printing a...
I had the same problem, the transfer roller rubber was completely slick and would not pick up paper (it would also make a clicking sound).
Replaced it and the problem went away.
Jun 11, 2008 | HP LaserJet P3005n Printer
Jams
First of all, the feed rolls may be very slick, try cleaning them several times with fantastic or 409. They are probably very smooth and just spinning on the paper.
The feed clutch or motor, depending on the model, may be bad and not driving the feed rolls.
The paper tray may not be lifting the paper stack to the rollers.
Jun 03, 2008 | Xerox Office Equipment & Supplies
Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Mar 21, 2008 | Canon FAX-L1000 Plain Paper Laser
Paper will not feed
What you need to do is remove the tray, and look for the feed rollers and clean them with either alcohol or a soapy cleaner like Fantastic.
Clean them a few times, make sure they are dry then try again.
That may solve it completely, or your rollers may be slick and need replaced.
When those rolls get dirty, it's like trying to drive on ice. You just slip. Also, if those rolls are needing replaced, I wouldn't be upset with the refurb work. Sometimes those rolls fake you out. They appear and to touch feel perfectly fine, but try and feed a piece of paper, and it just won't.
If you can, look into the paper tray with a flash light, and see if they are turning. If they are, then dirt or slick rolls is the only problem you have.
Mar 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Pickup Roller not turning for upper tray
I think it is not a problem with the parts you mention, I think it may be that the printer is not getting told to feed from manual bypass tray (tray1) (ie driver setting)
what software are you using, is driver correct, what operating system, what are you tring to feed from bypass just standard?
I have fixed hundreds of these and the parts you mention I doubt is the fix
There are options on how this tray behaves available, in driver
tell me more and I'll help you
Nov 30, 2007 | HP LaserJet 2100 Printer
Xerox Phaser 7750DN Laser Printer Logo
125 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
